DIY / MODS / TUTORIALS
Discussion in 'General Tundra Discussion' started by T-Rex266, Feb 2, 2014.
  1. Feb 2, 2014 at 3:52 PM
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    The following list is a complete up to date list of all of the DIYs, MODs, Tutorials, add-ons and additions to your Tundra that are on this site. The list will be continually updated by @T-Rex266 and @csuviper as they are created. Thanks to @Tundra234 for categorizing the various mods. Keep checking back for more ideas for your future mods.
    Lighting
    DIY: Fog Light Mod
    Alternative 5 min anytime fog light relay mod
    DIY: Retrofitted Headlights
    DIY: Footwell LED Install
    DIY: 2007+ Aftermaket LED Backup/Reverse Light Install
    DIY LED light bar install
    Adding Fog Lights on Tundra without
    Headlight levelers Retrofit Mod
    DIY: Map Light Switch Replacement
    DIY: LED Bed Lights w/ Timer
    DIY Bed Light
    DIY Rigid TRD Pro Fog Light Brackets
    DIY puddle lights installed on factory side mirrors
    DIY: Baja Designs Squadron-R Sport, 14+ Mount Kit & Bezel
    DIY: LED DRL/Turn Signal Install
    "Raptor" LED grill mod
    HOW TO: Retrofit Install Guide (by EleDobleU)
    "Cyclops" Toyota emblem light
    LED puddle light replacement procedure
    Under-hood Lighting Mod
    Electrical
    DIY: Add Steering Wheel Controls
    DIY sPOD
    Rear-bumper battery posts
    DIY: Big 3/4 Wire Upgrade
    DIY: Trailer harness relocation
    AMP Research side steps wiring for 2.5 gen Tundras
    2018 headlight wiring info & diagrams
    Auto Fold Mirror Harness Install
    Audio
    Tutorial: How to remove the door panel and replace speakers 2007-2013 Tundra
    Tutorial: How to remove the door panel and replace speakers 2014-2021 Tundra
    Tutorial: How to remove stereo 2007-2013 Tundra
    Tutorial: How to remove stereo 2014-2021 Tundra
    DIY: Adding a subwoofer to the stock Tundra stereo
    Audio overhaul & sound deadening
    Cameras, Dash cams, & radar detectors
    Rear dash cam installation
    DIY: Valentine 1 Radar Detector installation
    Front/Rear Anytime Cameras and Audio/Video (w/ iPhone Mirroring)
    FRAC Front/Rear Anytime Camera Install Video
    USB and Wireless charging
    USB port for rear seat and hardwiring your wireless charger
    Wireless charger install
    DIY: USB Replacement CIG outlet 2nd Gen
    DIY: USB Replacement CIG outlet 2.5 Gen
    Always on USB port
    DIY: Wireless phone charging 2014+
    DIY USB Cigarette replacement
    Suspension
    Shackle installation
    DIY: Front Coilover Install
    DIY UCA install 2nd gen+
    DIY: Body Lift
    Exterior Appearance & mods
    DIY: Tinted Tail Lights
    Fix for uneven end cap gaps (3rd gen)
    Tint your tail-lights V2
    DIY: Fiberglass Eyelids
    DIY vinyl eyelids
    Painting calipers
    Color match tailgate handle
    Relocating Toyota Safety Sense (TSS) Sensor
    DIY: 2020 Tundra keyless entry remote start door handle swap.
    DIY: "Raptor" Lettering Install on Mesh Grill
    DIY: Mirror Cap and Door Handle Replacement
    Color Matched Bumper Swap
    DIY: Painted tail pipes
    DIY: Rear Differential Breather Mod
    DIY: Installing Lockable Fuel Door "CHROME"
    DIY wheel well liners
    DIY: Hidden Bedside Support Install
    Bed Mount Bottle Opener
    DIY: Battery Hold Down Install
    Interior appearance and mods
    DIY: Paracord wrapped "Oh S#!t" handles
    Adding interior grip handles
    2.5 gen dash trim removal
    DIY: Paint interior door handles/door trim
    DIY: Paint steering wheel trim panels. 2.5 Gen.
    Alternate Center Console Pistol Mod
    Center Console Firearm / Maglight Install
    Seat heater install on 2.5 Gen Tundras
    DIY: Phone Mount
    DIY: Glovebox Pin Switch Pin
    Replace Steering Wheel on 2.5 Gen
    Magnetic gun holder installation
    Rear seat fold down for double cab
    DIY Chrome shift console bezel removal: Vinyl carbon fiber wrap delete
    DIY: Floor Console for Tundras with Front Bench ($10)
    Cargo management
    Cargo Holder Ideas
    Swing case install
    DIY: Unistrut Bed Rails
    DIY: Bed Tie-Down Ring Addition
    DIY: Ammo Can Storage
    Tundra DIY Storage Drawer System
    Cavernous Crewmax underseat storage
    Budget CrewMax rear organizer
    DIY Maintenance
    DIY: Front differential and transfer case fluid change
    Changing Valve Cover Gaskets
    DIY: AIP & Timing Valve Replacement Write-Up
    DIY: MAF, Throttle Body and EGR Cleaning Write Up
    DIY: Re-usable Washable In Cab Air Filter Mod
    DIY: Serpentine/driving/timing belt (and pulleys)
    DIY: Rear hub grease cap
    DIY: Replace Side View Mirror Assembly
    DIY: Replace Side View Mirror Glass
    Tutorial: How to remove the door panel and replace side mirrors 2007-2013 Tundra
    Remove and reinstall front and rear bumper caps
    1st gen DIY steering shaft seal
    Protection
    DIY: ABS Sensor Guard Install
    DIY: Tailgate Anti-Theft Protection
    DIY: Door Sill Protection
    DIY: TRD Skid Plate Installation
    Wheels/tires, brakes, TPMS, & air compressors
    ARB Air Compressor installation
    Tire Pressure Chalk Test
    Wheel Balancing with Centramatics
    Disable TPMS
    Front Brake Job on a 2.5 Gen
    DIY: Replacing Front Brake Pads and Rotors
    Cab Mount Chop (CMC) also known as Body Mount Chop (BMC)
    Engine, Intake, & Exhaust
    Billet oil filter cap with drain valve installation
    Throttle Body Coolant Bypass with Ball Valve
    DIY: TRD Air Intake Install
    DIY: Fix for whistle after adding high flow air filter
    TRD dual exhaust install
    DIY: Radium Oil Catch Cans
    DIY 2.5 Gen Supercharger Install
    2nd Gen AC compressor install
    Convenience mods
    Automatic Traction Control Disabler
    Push-button / Remote start Mod
    Flash-to-Open Mod
    DIY: Auto-fold mirrors mod
    One-Touch lane changer Mod
    DIY: Upgrading to power fold mirrors mod
    DIY: OEM bed light and pop lock for tailgate
    DIY pop n lock
    Auto-Open Tailgate Mod
    DIY: 12Volts Remote Start Install
    Auto-AC Upgrade (2nd gen)
    Misc
    Additional possible Tundra mods
  2. Feb 13, 2014 at 8:11 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
  3. Feb 13, 2014 at 8:35 PM
    We need write ups!
    @csuviper....who just did his grill:)
  4. Feb 13, 2014 at 9:03 PM
    TruckyTruck
    Gary
    I wish I had taken more pictures of the brake controller install. I've been at this damn sound system install for way too long, but when I'm finished, I hope to do another write up or two!
  5. Feb 13, 2014 at 9:18 PM
    Please do. DIY are very valuable.
  6. Feb 13, 2014 at 9:28 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I will get on it as soon as I have time.
  7. Mar 13, 2014 at 8:19 PM
    csuviper
    Broomfield, CO
    You have some updating to do
  8. Mar 14, 2014 at 7:19 AM
    Yep...ill work on that
    Edit: Updated
    3/14/14
  9. Mar 14, 2014 at 9:38 PM
    csuviper
    Broomfield, CO
    Forgot my raptor lettering install.
    Soon to post:
    Oil change
    Grillcraft grill install
    Ultimate Bilstein 3/1 lift install
  10. Mar 25, 2014 at 11:08 AM
    csuviper
    Broomfield, CO
  11. Mar 30, 2014 at 8:24 PM
    Updated with trailer harness relocation
  12. Apr 25, 2014 at 9:05 AM
    csuviper
    Broomfield, CO
  13. Apr 25, 2014 at 1:33 PM
  14. Apr 27, 2015 at 7:56 PM
    @csuviper you should post the ammo can mod when you have a moment.
  15. Apr 27, 2015 at 8:00 PM
    csuviper
    Broomfield, CO
    Yea yea I know. I will try to soon.
    T-Rex266[OP] likes this.
  16. Apr 28, 2015 at 7:57 AM
    I like the trailer harness mod. Do it after work today. I want to do the bumper trim mod that you did to your truck. What's all entailed with that mod and what do you think about Relentless Fab's cab mount chop plate mod? Just realized the 07 trailer hook up is different than the 2nd gen hook up. I seem to recall the 07 mod thread but can't remember where. Not much different.
  17. Apr 28, 2015 at 1:59 PM
    csuviper
    Broomfield, CO
  18. Apr 28, 2015 at 2:26 PM
    Just use a small saw and trim both sides. After, push the liner in, and retap a screw from the bottom bumper into the liner to hold it in place.
    I haven't seen the relentless CMC plate.
  19. Apr 28, 2015 at 3:17 PM
    Sounds good. I will give it a shot. The CMC plates are pictured on Relentless' site. $25 for the set. Requires some cutting and welding. You gain over an inch more clearance.
  20. Apr 28, 2015 at 3:48 PM
    csuviper
    Broomfield, CO
    Updated the OP to add some additional DIY's :)
    Black Wolf likes this.
  21. Apr 29, 2015 at 6:46 AM
  22. Apr 30, 2015 at 12:52 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
  23. May 25, 2015 at 4:36 PM
    Has anyone done the anti theft tail-gate mod without a c-clamp? I believe there is a way..
  24. May 25, 2015 at 8:31 PM
    TruckyTruck
    Gary
    Nope. I just use a clamp and lock the tailgate. What else is there?
  25. May 25, 2015 at 9:45 PM
    csuviper
    Broomfield, CO
    The electrical for the backup camera makes it more difficult to remove, unless they just use wire cutters.
  26. May 26, 2015 at 5:27 AM
    Thought I read something before...I'll have to Google search.
  27. Aug 16, 2015 at 9:12 PM
    csuviper
    Broomfield, CO
    Added cab mount chop (CMC) aka body mount chop (BMC)
  28. Aug 23, 2015 at 11:55 PM
    Paulskie
    Paulskie New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
  29. Aug 24, 2015 at 10:12 AM
    csuviper
    Broomfield, CO
    Trying to link to only the tutorials on this forum. You are welcome to do a write-up here if you have done this? Try to use your own wording and add additional details and hints.
    forestcop1732 likes this.
  30. Aug 25, 2015 at 11:00 PM
    Paulskie
    Paulskie New Member
    Paul
    Thanks man
    Corrected.
