LED Puddle lights for Platinum & 1794 * DIY
Discussion in 'Lighting' started by BlueBottle, Sep 30, 2016.
  1. Sep 30, 2016 at 10:23 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    If you have a Tundra with the OEM puddle lamps, you may not even know you have them because they are so dim! I didn't know until I read it on here that my truck had some lol.
    After searching for LED's for them, I realized the assemblies are sealed and you can NOT change the bulb! I know some people were successful on cutting the lens open, replacing the bulb, then glueing the cover back on. I don't like cutting stuff, so I ran into this website that sold complete replacement assemblies.
    http://drivebright.com/home/shop/led-puddle-light-pack-bright-trax-v4-extreme-toyota-mazda/
    Order came pretty quick. About 2 days via USPS. packaging was pretty good.
    They give free license plate LED's but I didn't install them since I already had some.
    962C196A-19E1-4E98-B91F-999CF9D2FB4C_zps_1201c496504474b5a680d7e93ccfa1ee637b86db.jpg
    OEM on top
    FBC1BDB8-EE78-408E-A495-5A8DCD9285A9_zps_b82d9e9290286d2859a1821a33159e5078b29ca9.jpg
    E052D09C-C674-4BE3-AD6A-4DF0D69F6547_zps_47c29de8621060c3335d9844192503da18db3e9e.jpg
    Directions to replace the stock units :
    1. Tilt mirror up and you can see the clip you have to release to drop one side out(down)C244CDDE-DD5C-42DC-A13E-DE046EEAF4BA_zps_70c8ed91be29baa4895d6c5dd1dc12805cf295d2.jpg
    2. Once you release one side, it will look like this 5832A76A-51FB-4880-ABFB-5C2E404D6C67_zps_d445e378201bfbe6ed332eb7e3c3e309a2711ae6.jpg
    3. Pry the opposite side with a small flat screw driver and it will pop out 56E4EE01-4C0A-4E19-B740-1BA9125818DC_zps_11325c5d898e557010dc6140870197713ae491ea.jpg
    4. you can now just pull the entire assembly down & Unplug the two plugs 04BC2C59-E172-43BB-BE92-981C018A7EB0_zps_da0c69d5508b83a8c403e5f18efe034b848996b2.jpg
    5. Plug in the new assembly(make sure you push the connectors in until it clicks) 2BDB10C8-8937-4731-AB42-0F8B5201CA4D_zps_e24f882d6aab309f40eea0d2d38bb10ab40f8f96.jpg
    6. Test to make sure it turns on, put assembly up into mirror until it snaps in place79676E1D-F213-4881-82CD-6F6C10CB877C_zps_8e3d1d39e12d6dfe5ed01b0e378eaa9abd27a799.jpg
    7. Repeat on other side and enjoy that you have lights that work!!! *note:I took these photos on manual mode with the camera on the same settings so this truly depicts the lighting difference between OEM and LED replacements. F2.8 15 iso800 D0A8BC24-CF5F-410D-8D9D-328412B93B68_zps_5d4e3915c68af9a4a5c66f5133011ec636bb93db.jpg
    Conclusion : These are a great upgrade from the OEM lamps. They fit perfect. You can actually see now with these. They are a bit pricey but they do perform well and do include all new assemblies. Quick shipping and free set of license plate LED's!
  2. Sep 30, 2016 at 11:02 PM
    I really like those puddle lights. I'm thinking I could do that even with my tow mirrors. Nice pics/mod. Thinking others here will gladly copy what you did. Well done. :thumbsup::thumbsup:
    Trooper2 likes this.
  3. Oct 1, 2016 at 7:08 AM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    That's awesome! Nice write up! I like your detail with the camera settings so we can truly see the difference! Wonder how hard it would be to add these to a truck that doesn't have them from factory.
  4. Oct 1, 2016 at 7:15 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Do tow mirrors have these puddle lights too? It truly is nice to have when walking up to your truck at night.
    thanks, they do put out a lot of lumens
    Thanks, I could not find much information on these and these seem to be the only option we have if we want LED puddles.
    If you don't have factory puddles, it seems it will be a lot of work, unless you have the hole under your mirror already? If you have a hole under there, then all you would need to do is run a wire and tap it off the footwell light.
  5. Oct 1, 2016 at 1:48 PM
    boloson
    boloson New Member
    Great right up. Was just looking at my puddle lights yesterday & wanted some LEDs. I hate replacing Oem stuff if I had to permanently alter them however slight it might be
    BlueBottle[OP] likes this.
  6. Oct 1, 2016 at 3:22 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Very cool. Most likely will be doing this as soon as I wire the puddle lights up.
  7. Oct 1, 2016 at 5:14 PM
    Ryan Mc.
    Ryan Mc. New Member
    Ryan
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    Nice write up! Do all Tundra trims have this capability, wiring in mirror just no hole for the lights...?
  8. Oct 1, 2016 at 10:58 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    thanks, Im not sure if the wiring is there. Even if it isn't, It wouldn't be too hard to run a pair of wires to the footwell lamp and just splice it. Harder part would be cutting a perfect hole with the notches for the lamp. Doesn't seem worth it with all the hassles if your mirrors aren't prepped for it.
  9. Oct 16, 2016 at 11:03 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    nice write up. sub'd for future reference
  10. Oct 28, 2016 at 9:21 AM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    just ordered these. @BlueBottle your costing me money! and paypal...wow too easy to make all these random mod purchases! rant over thanks
  11. Oct 28, 2016 at 9:25 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    LoL. At least you will have lights that actually work now!
    If I'm going in debt I'm talking others with me too!!!! LoL
    Skippy, joonbug and 14tundra[QUOTED] like this.
  12. Oct 29, 2016 at 9:52 AM
    Tundra Fan
    Toby
    Ordered mine yesterday as well. :D
  13. Nov 2, 2016 at 9:11 PM
    Tundra Fan
    Toby
    I got mine today, and thanks to your write up, I had them installed in minutes (including the license plate lights). These are a much brighter and whiter light. I love them. Thanks Blue.
    Ordered led's for the whole interior yesterday also.
  14. Nov 2, 2016 at 9:13 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Just giving back to this great forum! I have learned a lot also and found no documentation on these any LED puddle lamps. check out my build thread, I just installed some VLED tail lamps.
    14tundra likes this.
  15. Nov 3, 2016 at 9:55 PM
    BB Stacker
    BB Stacker New Member
    So. Cal
    2016 White 1794 TRD 4X4
    Sway Bar, TRD Catback Exhaust, Morimoto LED fog lamps, running boards, paracord wrapped oh-shit handles, Bak-Flip bed cover.
    This is not making my non-addiction any easier!
    ChucklesToy and BlueBottle[OP] like this.
  16. Nov 5, 2016 at 9:37 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Got mine installed today. Makes a big difference!
    Before -
    After -
  17. Nov 13, 2016 at 2:55 AM
    Paulskie
    Paulskie New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
    Wow, what a great find. Thanks man.
  18. Nov 15, 2016 at 4:19 PM
    Tomminator855
    Tomminator855 New Member
    They're out of stock as today . Hope they getting them back soon , thanks @BlueBottle
  19. Nov 15, 2016 at 4:37 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    holy crap... i didn't even know i had puddle lights after a year of owning my truck lol. i think i need to do some looking around to find out why they're not turning on.
  20. Nov 16, 2016 at 6:08 AM
    PlatinumPro
    after some tinkering i learned that the aftermarket starter i use doesn't seem to turn the puddle lights on at all. one unlock with the factory fob and the dim little lights did their thing.
  21. Nov 16, 2016 at 7:07 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Is there a mod for those of without DEEP pockets that own a SR5? lol
  22. Nov 27, 2016 at 9:30 AM
    eatbeef
    eatbeef New Member
    S.E. Kansas
    2016 CrewMax Platinum
    None,,,,,, yet
    This is one of the options I've missed, didn't realize the Limited didn't have it at the time of purchase. I've looked at the bottom of my mirrors and there is a circle that looks more like a mold marking then a knock out but I've not had time to take the mirror apart to check. Do all mirrors have the knock out?
  23. Nov 27, 2016 at 2:37 PM
    eatbeef
    eatbeef New Member
    S.E. Kansas
    None,,,,,, yet
    Thanks RowdyRon, I figured it couldn't be that easy.
    NewImprovedRon likes this.
  24. Nov 27, 2016 at 4:38 PM
    thumper7799
    thumper7799 Bad Girls Drive Bad Toys!
    Erika
    2007 Nautical blue Tundra SR5 duel exhaust
    I had to go look at my mirrors and I have that access plate too. Going to investigate further during the day. That would be nice to install and have when it's dark.
  25. Nov 27, 2016 at 6:10 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Fine, I guess I'll have to do the mod myself lol
  26. Dec 21, 2016 at 9:46 PM
    Tundra Fan
    Toby
    Has anybody that installed the license plate led's that come with these had any problems with them? I noticed the other day when I got out to close a gate behind me that mine were flickering. I may have to buy a different set. Blue, I know you said you didn't use these because you already had some installed, which ones do you have?
  27. Dec 21, 2016 at 9:59 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I prefer to use LED's from superbright LED's. They never give me any issues. i think on my Tundra though, I tried some Amazon ones but I don't recommend them.. they look cheap. i would either use Superbright LED's or VLED's if I were you.
    www.superbrightleds.com
    www.vleds.com
  28. Dec 21, 2016 at 10:25 PM
    Tundra Fan
    Toby
  29. Dec 21, 2016 at 10:31 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Tundra Fan likes this.
  30. Dec 21, 2016 at 11:07 PM
    Paulskie
    Paulskie New Member
    Paul
    Second that. I've tried Amazon and ebay sets of LEDs and they let about 2-3 months and start to flicker.
