DIY USB Cigarette replacement
Discussion in '2.5 Gen Tundras (2014-2021)' started by atrinh15, Apr 27, 2018.
  1. Apr 27, 2018 at 12:56 PM
    atrinh15
    atrinh15 [OP] New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    We have 4 cigarette lighter outlets and 1 USB outlet. So to fix that i replaced one of the outlets for a dual USB outlet.
    First I pulled the lower panel out with the 2 outlets and usb. Unplugged each plug to gain full access of panel. I than removed the driver side outlet in this demonstration but any of the outlets can be replaced.
    I than used a small flat head screw driver and pushed on the tabs inside the outlet
    Once removed should look like this
    After removing the outlet flip panel over and remove the cover to the outlet
    On my Dual USB outlet was a little bigger than the stock one. Depending on the one you order youll have to just test fit it.
    I bored mine out just to keep it a tight fit.
    By doing this i was able to slide the new outlet in. However if i wanted to go back to stock it was fine too cuz the cover still cover the hole up.
    I forgot to get a pic of the factory connector but this is after i split it. I could of cut it and put new ends on but like i said i wanted to keep it as original as possible.
    Red wire is 12v +
    Plugging it in with stock terminals
    Reinstalling panel and test it out.
    Works great might have to do the back one for the kids as well. Good luck ask any questions and if i can help let me know.
  2. Apr 27, 2018 at 1:11 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Great job! :thumbsup:
    geno0506 and atrinh15[OP] like this.
  3. Apr 27, 2018 at 1:11 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Awesome. @csuviper might move this to the DIY section.
    atrinh15[OP] and csuviper like this.
  4. Apr 27, 2018 at 1:40 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Done
    atrinh15[OP] and TXMiamiFan like this.
  5. Apr 27, 2018 at 1:57 PM
    atrinh15
    495-93 area
    Sweet thanks guys.
  6. Apr 27, 2018 at 4:57 PM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    Link to usb outlets used? I’m guessing it’s from Amazon. I like that you didn’t have to cut factory wires. Plug and play.
  7. Apr 27, 2018 at 6:00 PM
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    is it possible to remove lower panel without removing any other pieces of dash?
  8. Apr 27, 2018 at 6:36 PM
    atrinh15
    495-93 area
    Stroke250[QUOTED] likes this.
  9. Apr 27, 2018 at 6:38 PM
    atrinh15
    495-93 area
    Yes. But when you pull on the bottom piece the hvac setup sometimes pulls out too. Only clips. Do it when its warmer out or in the truck not to break anything.
  10. Apr 28, 2018 at 7:22 AM
    jaredmillerdvm
    Anderson, SC
    Did u use pry tools? I was trying to remove it without removing anything else but was unsuccessful or maybe too scared to pull.
  11. Apr 28, 2018 at 9:11 AM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    If you don't own a set of the blue plastic pry pieces I would recommend picking one up. They are really inexpensive, and can be ordered online, or found at Harbor Freight. You'll definitely get your money's worth especially on your Tundy. It ensembles, and snaps into place like Lego's. :thumbsup:
  12. Apr 28, 2018 at 11:55 AM
    atrinh15
    495-93 area
    Yes like Skippy said get some plastic pry tools def worth long run. Work from one side and the bottom up either side. Remember to pull straight out like the clips look going in.
  13. Apr 28, 2018 at 1:23 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Looks OEM, excellent writeup! I plan to do that sometime.
    Totally beats my less than flush mount stubby inserts, although both ports here are 2.4A (total 4.8).
    Front "TRD red" lol:
    Rear black for the kids:
  14. Apr 28, 2018 at 1:59 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    This has been on my to do list for awhile. Good right up OP! I order two from Amazon. But I elected to get the dual 2.1amp ports for faster charging. 214A72BB-BA06-4888-9A5E-B2357D42BA8D.jpg
    chugs likes this.
  15. Apr 28, 2018 at 2:59 PM
    atrinh15
    495-93 area
    Yea those nice on the faster charging.
    1UPPER[QUOTED] likes this.
