2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Sep 6, 2017 at 5:31 PM
    thomasbus337
    thomasbus337 [OP] New Member
    2016 SR5 DC
    After looking over wire diagrams for my 2016 Tundra SR5 and the 2018 Tundra on TIS I have come up with the following text and created a few diagrams for my plans on a plug and play wire harness. I’ll update again once I’ve successfully assembled this harness. I’ve cross referenced the Toyota plugs and terminals and found a source online for most of the connectors. I’ll update this info again once I’ve successfully assembled this harness using these parts. The So far this is what I’ve got.
    The 2018 LED headlight has an 8-pin plug on the back, it has six terminals but to do this retrofit we will only be using five. The five wires will be for HI beam, low beam, Ground (which is shared for the headlight and the DRL/Parking light) and the DRL (red wire) and Parking light wire(violet).
    The headlight adjuster plugs and 168/194 side marker plugs are a direct fit. The amber directional 3-pin plug will fit on the new bulb/socket, but pins 1 & 2 will need to be swapped for the directional to function. You can’t swap over your original socket and 4157NAK bulb because they will not fit in the new housing which takes a smaller 7444NA bulb.
    If you have a LED unit like a VLED V3 Triton you will be able to reuse them. This bulb is a double filament bulb so SR, SR5 and Limited models could retain the amber parking lights if desired, but I would search the forums for directions on how to disable the stock amber DRLS which I have done already.
    I’ve drawn the pin outs so that when the 8 pin plug is plugged into the headlight, the pin in the top left corner will be pin # 5 with the wire exiting out.
    I’ve pulled the wire colors from the Toyota diagrams but please double check your wire color/circuit functions for accuracy.
    Wire Colors from Toyota Wire Diagrams
    2017 3-pin H4 Headlight Plug
    Hi Beam – RH-Brown LH- Light Green
    Low Beam - RH-White LH- Green
    Ground – RH-White/Black LH Black
    LED DRL 4 pin Plug
    DRL -Red
    Parking Light -Violet
    Ground white/black
    2018 8-pin Headlight Plug and 3 pin H4 Plug
    Hi Beam – RH-Light Green LH- Blue
    Ground – RH-White/Black LH White/Black
    LED DRL 4 pin Plug on 2014-2017 Platinum/1794 and 2018 lower trims with LED drl
    DRL -Red
    Ground white/black
    I hope this ends up being helpful to someone
  2. Sep 6, 2017 at 5:39 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  3. Sep 6, 2017 at 5:59 PM
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    ADS C/O w/clickers, ADS bypass rear, Icon UCAs, Toytech shackles, chrome delete, Pro grille, TRD dual exhaust dumped, de-badged, black LED tail lights. BHLM w/projectors, 295 70 18 Cooper STT pro on stock rims w/1.25" Spider Tracks. N_Fab bumper w/Baja Design fogs and ditch lights, 13" antenna x, RCI skid, All Pro sliders, ARB compressor
    Thanks @thomasbus337 . You're making me think about replacing my retro fits especially since after only a year the drl strip is beginning to fail.
    dcsleeper408 likes this.
  4. Sep 6, 2017 at 6:19 PM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2017 CrewMax ProKiller
    Follow my life on IG: PLC721
    I'd be willing to pay for a harness...as i'm sure are many other people
  5. Sep 6, 2017 at 6:48 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Sick! Excellent work!! Waiting patiently :rofl:
    831Tun likes this.
  6. Sep 6, 2017 at 6:58 PM
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Can't wait!!!
  7. Sep 6, 2017 at 7:30 PM
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    Let me know if you're gonna sell your platinum headlights.. I'm sure they're pristine and then I could retro those before repairing mine and selling 'em.
  8. Sep 6, 2017 at 7:31 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Once I get the 18's installed/working, I will sell the TRD Pros I have. Keeping the Platinums for a rainy day...
    831Tun likes this.
  9. Sep 6, 2017 at 7:34 PM
    Tophergt99
    Weston, Wisconsin
    In progress....
    When the led thing gets worked out I'll have some pros for sale. :)
  10. Sep 6, 2017 at 8:04 PM
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    Thanks for doing this. This will give me an excellent point of reference once the big brown truck show up.
  11. Sep 6, 2017 at 8:14 PM
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    @Roman you don't happen to have the part #'s for the Hi/Lo beam ground factory connectors and the DRL and parking light connector pictured above do you? I ordered the lights and what I believed to be the 8 pin connectors earlier today from your web site now I need to get the other connectors to dive right in to this when they arrive.
  12. Sep 6, 2017 at 9:39 PM
    BRTundra
    BRTundra New Member
    Tony
    Baton Rouge, LA.
    2017 Tundra Platinum 5.7L CM
  13. Sep 6, 2017 at 9:57 PM
    big_jarv
    big_jarv New Member
    2017 Tundra off-road
    Also subd
    saadi996tt likes this.
  14. Sep 7, 2017 at 4:33 AM
    SleeperTRDPro
    SleeperTRDPro The small package good things come in
    Austin, Texas
  15. Sep 7, 2017 at 5:09 AM
    Stig
    Stig New Member
    I would expect the output of the new Tundra led headlamps to be a bit less than a good hid projector retrofit. But better than the old halogen lamps.
  16. Sep 7, 2017 at 5:55 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @thomasbus337 my platinum only has 2 wires going into the amber signal because the platinums moved their park light to the drl strip on the bottom. So it doesn't have another wire to be swapped with. Have any idea how that will work out?
  17. Sep 7, 2017 at 6:09 AM
    thomasbus337
    2016 SR5 DC
    If your white/black ground wire is currently in the middle spot (pin 2) on the plug you'll have to move it to either outside spot (pin 1 or 3) depending which one is currently unused.
  18. Sep 7, 2017 at 6:31 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    On the platinum there is no wire on terminal 1 at all. So 2 would have to be loved to 1. Can the wires from the stock harness be de pinned and moved?
  19. Sep 7, 2017 at 6:39 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  20. Sep 7, 2017 at 6:46 AM
    thomasbus337
    2016 SR5 DC
    Yes, you should be able to insert a paper clip or a pin tool to release the tang on the terminal to pull it out and swap it over to the other spot.
    BlueBottle likes this.
  21. Sep 7, 2017 at 5:00 PM
    thomasbus337
    2016 SR5 DC
    I did some more research and found the part numbers for the male and female 3pin plugs for the parking light/directional sockets. With these you could make a small PnP harness to reconfigure the 2018 7444NA bulb/socket to work with the existing wires on the 2014-2017 so that re-pinning wouldn’t be needed.
    The other possibility is to use these plugs to do the swap listed above while also redirecting the parking light circuit to the 8-pin plug on the back of the LED headlamp for the “low” setting on the DRL strip. Then install an Add-a-Circuit fuse tap onto an ignition controlled fuse in the under-hood fuse box, run the wire to the DRL wire in the 8-pin plug and then you now have LED DRL’s on a SR, SR5 or Limited Tundra without having to splice into any factory wiring.
    The only catch is that you’ll have to cut the small gray wire under the dash by the flasher relay to kill the factory amber DRL’s on these models. I’ve included a diagram for each of these ideas.
  22. Sep 7, 2017 at 6:18 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  23. Sep 7, 2017 at 6:21 PM
    Tophergt99
    Weston, Wisconsin
    In progress....
    Would it work that instead of cutting the gray wire I switched out the flasher module to have the non DRLs?
  24. Sep 7, 2017 at 6:25 PM
    thomasbus337
    2016 SR5 DC
    I hadn't even thought about that, but I guess it would
  25. Sep 7, 2017 at 6:28 PM
    Tophergt99
    Weston, Wisconsin
    In progress....
    I can't remember the part number but I know that there is a module that has non DRL, I think it's from the Sequoia. I have it and no Drls :)
  26. Sep 7, 2017 at 6:32 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Great job!!!!!!
  27. Sep 7, 2017 at 6:36 PM
    Tophergt99
    Weston, Wisconsin
    In progress....
    Found the part#, 81980-0C020 works for up to 16 I think. Way better then cutting a wire.
    PROTX and iHacker like this.
  28. Sep 8, 2017 at 3:36 AM
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    You don't happen to have those part #'s handy do you?
  29. Sep 8, 2017 at 10:22 AM
    thomasbus337
    2016 SR5 DC
    I've got 90980-11020 for the female and male is 90980-11607. Unfortunately my Toyota dealer tells me that there is no stock of these male plugs in the US so they would need to be ordered and it looks like they could be months away! He is going to order some extra for stock so in the future they should be available. I found some on Ebay but they are almost double the price and would be shipping from Thailand.
    pvdubber likes this.
  30. Sep 8, 2017 at 11:13 AM
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    Thanks a whole bunch you made this whole process super easy on me. You did all the work in the design phase which is often times the hardest part when engineering something new. I will order them and get a PNP harness built as soon as they arrive. I cant wait to see these on my pick-up.
    sano502 likes this.
