DIY: Unistrut Bed Rails - Cheaper option than OEM
Discussion in 'General Tundra Discussion' started by csuviper, Jun 8, 2015.
  1. Jun 8, 2015 at 5:44 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    If you do not want to pay ~$200+ for the OEM bed rail system then a cheaper alternative is to use electrical Unistrut. It is virtually the same as the OEM bed rails except it is a little wider and i believe stronger.
    Rails-Unistrut
    3 sticks of 10' long Unistrut from a local hardware store: Link to website
    3@$16.34 = $49.02
    Installation Hardware
    (12) M6 x 1
    (12) 1/4" fender washers
    Mounting Hardware
    3/8” Unistrut channel nuts: Link to website
    3/8” Hex Head Bolts (length depends on what your attaching)
    3/8” Lock Washers
    3/8” Fender Washers
  2. Jun 8, 2015 at 7:02 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    I definitely like this. I already did the D-ring things on the bedside. Could have used the uni's, but D-rings are OK. Definitely need to do this.
    BravoDeltaRomeo likes this.
  3. Jun 8, 2015 at 11:00 PM
    csuviper
    Broomfield, CO
    I'll edit the pics of this tomorrow from my computer. Oh and edit the mounting options.
    Wynnded and Black Wolf like this.
  4. Jun 9, 2015 at 9:42 AM
    csuviper
    Broomfield, CO
    Updated description and pictures in the OP.
  5. Sep 22, 2015 at 1:18 PM
    Dastard
    Dastard New Member
    2012 Crewmax with towing package
    air bags, blisten 5100 rear
    Can you tell me where you got the m6-1.25 bolts?
    Thanks
    D
  6. Sep 22, 2015 at 2:28 PM
    Aurora CO
    Did you try ACE Hardware? My local Ace blows away Home Depot selection tens times over. The family that owns my ACE has been there since the 60's. Probably why selection is so crazy good when it comes to fasteners.
  7. Sep 22, 2015 at 4:49 PM
    csuviper
    Broomfield, CO
    I got mine at Home Depo. Ace does have more selection but I think Ace is more expensive too
  8. Sep 22, 2015 at 5:09 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Nice write up man, gonna do this very soon.
  9. Sep 22, 2015 at 5:20 PM
    csuviper
    Broomfield, CO
    Thank you. Cheap and provides a good mounting surface for tie downs, bed rails, bike mounts, ammo storage solution and more.
  10. Sep 22, 2015 at 9:14 PM
    Aurora CO
    Can't be more expensive if Home Depot doesn't have what you are looking for.....just sayin. Especially when it comes to hard to find metric sizes. Brian, I guarantee, if you come to my local ACE, you will understand what I'm talking about.
    D4x4TRD, Darkness and BashFab like this.
  11. Sep 24, 2015 at 8:21 AM
    Halfjap
    Halfjap New Member
    Reno, NV
    2015 White Tundra Crewmax
    I did this same DIY. I got the rails at Home Depot, the d-rings on-line, and the hardware at Lowe'sIMG_2060.jpg
    bulldog93 and ChucklesToy like this.
  12. Sep 25, 2015 at 3:09 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    My 2011 takes M6 x 1.0 bolts - NOT 1.25
    Brydro likes this.
  13. Sep 25, 2015 at 9:53 PM
    csuviper
    Broomfield, CO
    1 and 1.25 is the length. Were the 1.25 bolts too long and not able to fully screw in?
    No issues on my 2012
  14. Sep 27, 2015 at 7:02 AM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    1.0 or 1.25 is the thread pitch - not the bolt length.
  15. Sep 27, 2015 at 7:49 AM
    csuviper
    Broomfield, CO
    Oops your correct. Weird that the pitch is different between years.
  16. Sep 28, 2015 at 10:25 AM
    gene3x
    gene3x New Member
    Gene
    2015 Tundra 1794
    Sway bar, BA Muffler, Hypertech Int, sumo springs,
    Curious if there is a way to make them work with a flipbak cover on as well. Had to take mine off the side rails to make the cover work!
  17. Feb 9, 2016 at 1:53 AM
    decade
    decade New Member
    BC, Canada
    2011 Blue Tundra SR5 TRD
    - None.... (yet)
    Just wondering, will the toyota factory (tacoma) tie-down mount fit?
  18. Feb 9, 2016 at 10:57 AM
    csuviper
    Broomfield, CO
    Yes. I have one of them on mine.
    decade likes this.
  19. Feb 9, 2016 at 4:26 PM
    decade
    decade New Member
    BC, Canada
    - None.... (yet)
    This is an excellent thread. Instead of buying the Toyota's OEM, which is $250+shipping. And I like the idea of DIY, so you can customize the length the way you wanted.
    I went to the HomeDepot in Canada.... you know what,they didn't carry those parts. :( Guess need to cross the border sometime to get it.
  20. Feb 9, 2016 at 6:09 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Electrical supply stores all carry it.
    It is also known as SUPERSTRUT.
    decade[QUOTED] likes this.
  21. Feb 20, 2016 at 6:00 PM
    decade
    decade New Member
    BC, Canada
    - None.... (yet)
    I actually haven't problem finding the mounting bolt. Check out several local store, but they only have M6 x 1.0 or M8 x 1.25. Doesn't have M6 x 1.25.
    Mine is 2011 too. Did you say M6 x 1.0 work? Or should it be M6 x 1.0?
  22. Feb 20, 2016 at 6:45 PM
    csuviper
    Broomfield, CO
    M6x1 should work. Try it out and make sure it's not too short.
  23. Feb 20, 2016 at 8:50 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    It is definitely 6M x 1.0 thread pitch. The guys are confusing the pitch (1.0) with the length (which is 1.25).. That is why no one can find 6M x 1.25 bolts, there is no such thing.
  24. Feb 20, 2016 at 11:24 PM
    csuviper
    Broomfield, CO
    For the unistrut rails i added a fender washer
    WrigglingWilly and SprinterAE86 like this.
  25. Feb 20, 2016 at 11:32 PM
    csuviper
    Broomfield, CO
    Guys. Most likely i called out the wrong bolt. The only way to know for sure is for me to pull one out and go check it at Ace. Or measure pitch myself.
  26. Feb 21, 2016 at 9:06 PM
    decade
    decade New Member
    BC, Canada
    - None.... (yet)
    I can confirm that it is M6 x 1.0 thread.
  27. Feb 21, 2016 at 9:25 PM
    csuviper
    Broomfield, CO
    I ran by ace hardware where I got the bolts. Def no M6 x 1.5. Must have mixed it together with the M8 x 1.5.
    I tested one existing one I had in this before searching and purchasing the bolts to match.
  28. Feb 21, 2016 at 9:26 PM
    csuviper
    Broomfield, CO
    Updated OP
  29. Apr 1, 2016 at 3:02 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    May have to do this one. Need a good way to keep my Hi Lift jack from sliding all over the bed. Planning on having it on the front of the bed with a DuHa Humpster toolbox on each bedside, hopefully will have enough room to mount lights on the front Unistrut and a tonneau cover over top.
  30. Jul 13, 2016 at 5:34 PM
    sam_i02
    sam_i02 New Member
    Sid
    2010 Tundra Roack Warrior
    Lowes Canada carries it. It is called Power Strut and is located in the aisle with the electrical conduit. It is $15 for 10 feet, but I did not get it because it is the 2" version - a little bigger than needed. Westburne Electric carries the right size. Going to get mine in the next few weeks and do this mod to carry the bikes.
