DIY: USB Replacement CIG outlet 2.5 Gen
Discussion in 'General Tundra Discussion' started by TTU19, Aug 28, 2016.
  1. Aug 28, 2016 at 2:14 PM
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Very happy to report that I got the USB port installed. Hardest part was figuring out how to get the existing cigarette plug out.
    Took the negative off the battery, parking brake and popped the tab to put it in neutral. Unscrewed the shifter and popped off the center console.
    That exposed the cigarette lighter plug.
    Took a little finagling but got it out.
    Put the new one in and it fit like a champ. Tightned the nut down and good to go.
    Next was to wire it in. It came with wire taps but the original harness had 2 red and 2 black. Wasn't sure what to use and on examination I noticed the prongs at the end of the new wire looked exactly like that of the original plug. Looked the right size so I used a razor blade to trim the plastic around the prong.
    Plugged them into their proper side and fit perfect.
    Battery back on to test it and I'm high 5ing myself, It Worked!!!
    Plugged in the phone and it's charging!!
    Wrapped it in electrical tape to make sure they stayed plugged in, zip tied the excess wire and put the console back together.
    Got it from Sparks Parts...
    http://www.sparksparts.com/accessor...ed-dual-usb-powerport-00016-00222?parent=1567
    geno0506, 040Tundra, iHacker and 2 others like this.
  2. Nov 1, 2016 at 11:09 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  3. Nov 1, 2016 at 1:05 PM
    Junior4888
    Junior4888 2007 Toyota Tundra Limited 4.7l
    Travis
    Moxee, WA
    2007 Toyota Tundra Limited Dbl Cab 4.7l
    sweet!!!!
    ChucklesToy and stefan702 like this.
  4. Feb 24, 2017 at 7:37 AM
    csuviper
    Broomfield, CO
  5. Feb 24, 2017 at 7:58 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Yeah, I'm sure that one would work as well. Just as long as it would fit the hole right, which it looks like it would.
  6. Feb 24, 2017 at 8:25 AM
    hdfanatic
    hdfanatic New Member
    Kevin
    Pearland, TX
    2017 Barcelona Red Platinum Crewmax 4x4
    TRD Pro wheels, Nfab
    This USB unit is now being installed at the port as an option, as least in the GST area. I have one installed in the back of the center console for the rear passengers. I assume this unit could also replace the cigarette lighters in the front (under the AC controls)?
  7. Feb 24, 2017 at 9:20 AM
    csuviper
    Broomfield, CO
    Probably going to save money and go with that one. Don't really want to pay $39.
  8. Feb 24, 2017 at 9:20 AM
    csuviper
    Broomfield, CO
    Yes you could replace the front ones. They should eliminate the stupid cig lighter anyway. Those that smoke can use a standard lighter.
    4x4_Angel, 040Tundra and TTU19[OP] like this.
  9. Feb 24, 2017 at 9:35 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    It's fine to have 1 I guess for different accessories and that is a universal plug, but to put 3 in the front is crazy. Plus everything is going to USB now. One thing I miss about my Chevy, is that it had an SD card reader. Toyota is probably 10 years from having an SD card, ha.
    NewImprovedRon likes this.
  10. Feb 24, 2017 at 1:37 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Of the ones they list, two of them are 4.2A (2.1 amps each). The other ones provide 2.1A only for the bottom, and 1 amp for the top. I'd go with one that provides 2.1 A for both outputs. Your devices will charge faster, and some devices (iPads) require 2.1.
    NewImprovedRon, 4x4_Angel and 831Tun like this.
  11. Mar 8, 2017 at 6:58 AM
    csuviper
    Broomfield, CO
    4x4_Angel likes this.
  12. Apr 10, 2017 at 6:49 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    I've been wanting to do this but was actually waiting for a "you seriously can't mess this up" type of right up. Mainly because I didn't want to break tabs or search for wiring. Great write up man. This will be next on my list so I can keep from plugging in a usb cigarette-lighter adapter. .
  13. Apr 10, 2017 at 7:20 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Thanks, yeah it was pretty easy once you get in to do it. I was the same way, did not want to use an adapter, and my other USB is being used.
    There is a video online somewhere on how to take that center console piece off. But just take the shifter off, and use trim tools if you have them to pry the piece up. Start at the top where it connects to the center console storage.
    AnonVet[QUOTED] likes this.
  14. Apr 10, 2017 at 7:24 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Sweet deal man. My wife is always running with no battery power because of all the social media crap so I get shit out of luck for a charging spot. I'll put an order in this week for one of these doodads and get it hooked up. appreciate the tips!!
  15. Apr 11, 2017 at 9:45 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I think I'm going to have to do this mod sooner than I thought, damnit! You guys and all your great ideas.
  16. Apr 11, 2017 at 9:52 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    This is a MUST, I mean, wth put 4 cig adapter plugs in the truck. Really? I think I may replace one under the radio as well.
    040Tundra likes this.
  17. Apr 11, 2017 at 9:56 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I agree with you Wes, 4 cig plugs, really??? Only one USB plug under the head unit.....:confused:
  18. Sep 21, 2017 at 6:26 AM
    mscroggi
    mscroggi New Member
    Agreed.. The USB under the radio does data, which is nice..but it needs to be in the center console. I dont know why Toyota exposed it for the truck when the data USB is hidden in other Toyota vehicles (my 2012 camry had the USB in the back of the dash console, you could plug in something and put it in the storage area and not see it). My scion had the USB plugs in the center console as well.
    For the cig powers under the radio.. I bought some super low profile USB adapters.. They are *almost* low profile enough to let the cig dust cap fully close.. They look like if they didnt have a tiny lip around the edge, they would sit deeper inside the cig socket. As an experiment, I am going to file off the little lip and see how it fits.. (being sure I have a way to get it out, if I stick it in there.. ) If it works like it appears it would, it could be an acceptable option without taking out the console etc, and the dust cap should close..
    Update:
    I gave it a go with mixed results.. I ground off the lip around the adapter.. It fit nicely inside a cig socket splitter I had. (I used it to hold the adapter while I worked on grinding the lip off). And it looked like it would be just fine.. But when I plugged it in to the 12v receptacle in the truck, it wouldn't go in as deep. The receptacle in the truck is shallower.. It was close but it did not allow the adapter to go deep enough to close the lid. So I popped off the little faceplate on the adapter.. It did go deep enough in the receptacle to allow closing the lid, but it looked kinda crappy to me.. It was functional... and with the lid closed you cant tell.. but it would bother me long term to leave it like that.. so I guess I will be replacing the receptacle sometime.
    TTU19[OP] likes this.
  19. Sep 21, 2017 at 6:40 AM
    ladywolf
    ladywolf New Member
    Kristen
    Clarksville TN
    05 S45 4x4 Double cab Jade Green Mica
    2.5" eibach coils/springs
    I wonder if that would work in a 1st Gen?
  20. Sep 21, 2017 at 6:56 AM
  21. Dec 30, 2017 at 10:50 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    @TTU19 , great mod, i have a question will this work the same way for the rear middle outlet, thanks.
  22. Dec 31, 2017 at 6:38 AM
    mscroggi
    mscroggi New Member
    Ely010606[QUOTED] likes this.
  23. Dec 31, 2017 at 7:56 AM
    Ely010606
    SPARKS, NV
  24. Dec 31, 2017 at 2:56 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Yeah, I would think it should work fine.
    Ely010606 likes this.
  25. Dec 31, 2017 at 4:27 PM
    Ely010606
    SPARKS, NV
    @TTU19 , Thanks, i ordered the usb , pretty stoked to give this a try.
    TTU19[QUOTED][OP] likes this.
  26. May 3, 2018 at 8:01 AM
    Yota18
    Yota18 Inferno Club
    Upstate New York (the real NY)
    18’ 5.7 TRD Off-Road
    Stock
    Save this for later
  27. May 3, 2018 at 8:27 AM
    mscroggi
    mscroggi New Member
    Off topic - Love those dogs !
  28. May 3, 2018 at 8:43 AM
    Yota18
    Yota18 Inferno Club
    Stock
    Thanks the pitty in front is my cousins great dog
  29. May 10, 2018 at 8:16 AM
    Yota18
    Yota18 Inferno Club
    Stock
    My plugs should be in today along with safe, so I’ll be doing this hopefully this weekend. How do you poop off the center console?
  30. May 11, 2018 at 12:17 AM
    Yota18
    Yota18 Inferno Club
    Stock
    And done!
