2014+ Dash trim removal for painting or wrapping
Discussion in '2.5 Gen Tundras (2014-2021)' started by trdlife, Apr 13, 2017.
  1. Apr 13, 2017 at 7:03 AM
    trdlife
    trdlife [OP] Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Not sure if anyone has done a DIY for this or not so i figured I would make a post to help anyone. I am not a personal fan of chrome trim pieces, my rig is a Blacked out 15 PRO and i just dislike the silver & chrome so I decided to dive in one day at the shop. This is my 2nd go thru at this I vinyl wrapped it the first time but didnt do a great job so this time i went back in. For mine I simply used black plasti dip for the main portions and i did the A/c rings red.
    Tools:
    Plastic pry tools(can be found at harbor freight for around $10)
    Philips screwdriver
    10mm socket regular socket will work for all of it but if you have a magnetic socket that would best for the radio bolts.
    6 inch extension to get to back radio bolts.
    Flashlight
    Pocket driver(techs know) or small thin flat head(helps to undo clips & connectors.
    ***Disconnect negative terminal on battery**** Prior to work and let sit for 5 minutes.
    ^ Safety first i put this because you will handle an airbag assembly.
    Step 1: using pry tool pop cupholder ring off(if sticky you can wait and pull it out after the main console is off)
    2: Open center console and using pry tool pop out the cover around the shifter(it includes the little change holder)
    3: Under the shifter cover you removed you sill see a philips screw there are 2 pretty close but you only need to remove the one that goes to the center console. After the screw is out you can pull up on it towards the front cup holder and the back on, once its popped up slide it towards the assenger side and its out.
    Drivers side area 4: move the seat all the way back for some room. Remove the door guard it pops up(4 tabs hold it) then in the upper corner of the kick panel you will see a small plastic nut spin it off(shouldnt be more then hand tight and pull the kick panel off(had 2 angle clips)
    5: There are 2 10mm bolts that hold the lower panel in they are on the bottom corners 1 is to the left of the hood release the other is to the right next to the center console. remove both and then pull out on this panel start at the bottom and work your way up. not this just needs to be out of the way to remove other panels you can leave everything plugged in and let it hang or you can disconnect them and pull the panel completely out its your preference.
    6: Using pry tool remove left drivers side a/c vent & short trim below it
    7: Now on the right side of the steering wheel, remove the panel with you trac & tow/haul switches and disconnect them & remove the grey trim pieces above it.
    8: Removing the cluster cover. In the top of the cluster there are 2 clips, you simply push them in the center but not too hard you dont want to push the pin through and lose them then using your pocket driver pull the clips out. then pull out on the over enough for it to be loose you will notice it is still attached to the steering wheel this small cover is held in by 4 tabs it doesnt take much pressure to pull them apart and then you can remove the cover fully.IMG_0642.jpg IMG_0648.jpg IMG_0649.jpg
    now on to the passenger side: 9: remove the door guard & kick panel same as the drivers side.
    10: Now below the glove box you will see the passenger knee airbag. now the the left of the airbag there is a cut out which looks like it is a cover using your pry tool pop this cover out but done yank on it on the bottom side of this there are 3 tabs that you can see and you will need to squeeze them in to release and then remove the cover.
    11: There are (3) 10mm bolts holding the airbag assembly in, remove these and then the airbag can be removed and set on the floor, if you have a smaller shoe box of similar you can sit it in the floor and then the airbag on top of it to keep stress off the wires.
    12. Glove box removal, on the bottom of the glove box there is 1 10mm bolt on the right side and a screw on the left lower side of it(maybe 1 more bolt you will be able to see if anymore are present) now open the glove box and there are 3 screws along the top, remove all 3 then pull out on the glove box and remove it from vehicle.
    13: Now remove the upper long trim piece that the right hand a/c vent sits using pry tools it pops out straight and same for the longer grey piece below it.
    14: Climate control panel this panel is a little tricky to get a good pry point & when you pull this out it will also pull the lower panel with the charging ports & usb. both of these have just clips no bolts. so using a pry tool disengage the clips by pulling it out. once you get it loose and pull it back a few inches you will need to disconnect the climat control connector and then you get more room to pull back and disconnect the usb & charge port connectors. and once they are removed you will see a wire clipped into the large silver center trim if you look closely at the clip you will see 2 tabs in the center of it push them in and the clip comes out.
    15: radio removal. using the 6in extension and magnetic 10mm socket remove the 4 bolts at the bottom of the radio. then using a pry tool, pry the upper edge against the dash and at the bottom and the radio will pop out(2 clips holding at the top) Now pull the radio foward and disconnect connectors to radio, now will entune now all of them will need to be unplugged. see below
    16: Now for the last piece, just clips hold the large center trim on, just grab on the corners and sides and work back and for and it will come loose, but dont get too aggressive as you will need to unplug the 4wd switch(if equipped) once removed you are ready to customize as you wish.
    Once remove the for the a/c ring the 2 outside vents will have3 screws on the back of each holding them in. and the center vents have tabs holding them to the center piece(lift up on the tabs and pull on the vent and they come right out same method is used to separate the ring from the actual vent.
    RE-assembly follow backwards.
    Previously i had vinyl wrapped mine but being my first Vinyl wrap it didn't turn out very well for me & and i kinda wanted to go back to a more simple and clean dash look. So i simply plasti dipped the main center piece and the cup holder trim & shifter trim. and for the a/c vents i went with red to go with the dash stiching of the pro.
  2. Apr 13, 2017 at 7:05 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  3. Apr 13, 2017 at 9:25 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Tim, great effin job!! Looks badass!!:muscleflexing: I love that look! Great write up too. :thumbsup:
    trdlife[OP] likes this.
  4. Apr 13, 2017 at 9:32 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Thanks, I figured i could put my tech skill too use and help some fellas out, i see alot of people ask about how to put these pieces out. I was going to folow TIS on the disassembly but way too many steps, i said fuck that. My foreman came over during the middle of it and had to see what i was messing with now lol.
    Brian0414 likes this.
  5. Apr 13, 2017 at 9:40 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Yeah, I wanna take mine apart and do the same thing but I don't have the patience or an all day chunk of time to do that. I believe the Pro's come apart a little differently than the rest of us Limited's, SR5's and Platinums (At least from your write up the best I can tell they do) Almost the same though, close enough to use this as a guide. I especially hate when the sun reflects directly off of the shifter surround and cup holder chrome right into my eyes :mad:. Blinding!!!:annoyed:
    trdlife[QUOTED][OP] likes this.
  6. Apr 13, 2017 at 10:13 AM
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    Thanks Tim. Can the passenger "upper trim piece" (that includes the right AC vent) be removed by itself or does anything else need to come off first? Same Q for the glove box.
  7. Apr 13, 2017 at 10:44 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Great job!
    Thanks for the write up as well.
  8. Apr 13, 2017 at 10:51 AM
    PaRunnerd
    PaRunnerd No N00B, No Pro.
    Dave
    Lehigh Valley, PA
    2014 Magnetic Gray Tundra SR5
    Plenty planned thanks to all of you.
    Great write-up and an even better finished product. Thanks for sharing.
  9. Apr 13, 2017 at 10:58 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    That's freaking awesome!!
  10. Apr 13, 2017 at 10:59 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    yes it can be taken out by itself.
    Cat3ILS[QUOTED] likes this.
  11. Apr 13, 2017 at 12:49 PM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Thank you for this. I just ordered some vinyl to wrap up the interior.
  12. Apr 13, 2017 at 1:14 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    patience is the key for vinyl, and i do not have it apparently
    Cat3ILS likes this.
  13. Apr 13, 2017 at 1:26 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Great write up! You had more patience than I. Lol
    If it looked like this
    You're on the path to righteousness
    Cat3ILS and trdlife[OP] like this.
  14. Apr 13, 2017 at 2:12 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    First time i did it i wrapped it and i got impatient fast, this last time i did it at home so i could enjoy some adult beverages. heres what it looked like the first time i went thru the dash
    Bear[QUOTED] likes this.
  15. Apr 13, 2017 at 2:14 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    I didnt mind the first time so much since it was all out i could run and hide my dash cam wire thru there & the radar detector wire. side note the plug in the center dash speaker is a blank plug as long as you have auto dim mirror already( this plug is where the solar sensor would normally be. so you can pull the plug and run wires thru it.
  16. Apr 13, 2017 at 2:17 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  17. Apr 13, 2017 at 2:38 PM
    az1441
    az1441 6-0 G7s on the road
    Steeler Country
    2017 Toyota Tundra TRD Pro cement
    4" Readylift 35" Toyo M/T 20x9 0 BMF BATL Retrofit w RGB LED Halos and Strips
    sub
  18. Apr 13, 2017 at 2:47 PM
    az1441
    Steeler Country
    Love the idea of the red rings to match the small stitching and pro emblem accents
  19. Apr 13, 2017 at 3:13 PM
    Bear
    Bear
    Custer, SD
    Yep. This looks about right. :thumbsup:
  20. Apr 13, 2017 at 3:31 PM
    drhntr
    drhntr New Member
    Derrick
    New Hampshire
    2017 Cement Pro DC
    GoRhino 2.0 Diamondback Switchback 295/70/18 TOYO AT3 TRD CAI Window Tint
    Wow! great write up like the red accent to the vents wish I had the patience and skill to do this.
  21. Apr 13, 2017 at 3:41 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Thanks I appreciate the positive feedback. I knew when I pulled it all back off I wanted to go with black but I wanted to do something with the rings. I was goin to do a metallic red but decided to go with the bright red looked and matched everything better.
  22. Apr 13, 2017 at 3:44 PM
    Bear
    Bear
    Custer, SD
    I agree!! I will likely be doing this again, but with brighter red paint, and way better surface prep.
  23. Apr 13, 2017 at 9:32 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Thing i hate most about my truck is all the damn chrome inside. Its hideous. I wish i had time to do this. Thanks for taking the time to do the write up.
    trdlife[OP] and Voyagermike like this.
  24. Apr 13, 2017 at 11:22 PM
    Cat3ILS
    Read this a couple times...did you by chance mean as long as you "don't" have auto dim? My Plat has auto dim mirrors so just confirm that plug is blank? If so where does the sensor live?
  25. Apr 14, 2017 at 5:57 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Sorry I had this sensor confused. that plug is where the solar sensor goes and actually it is only there if you have automatic a/c, and with a Platinum i assume you do? This is my fault, so if you have auto a/c, the solar sensor is there, if manual a/c it is blank.
  26. Apr 14, 2017 at 6:00 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    This is also the sensor for auto headlights
    Cat3ILS likes this.
  27. Apr 14, 2017 at 10:00 AM
    Cat3ILS
    Good to go Tim thanks for the follow up. I figured it had something to do with the auto headlights too because they come on when I put my sun screen there when I park. Too bad though...would like to have another place to drop a feed.
  28. Apr 14, 2017 at 10:03 AM
    az1441
    Steeler Country
    What else did you make red. The little red accents in the pro to set off the stitching and embroidery is dope. With my front springs too it'll be sick
  29. Apr 14, 2017 at 10:21 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    I just did the vent rings red. I didn't wanna go overboard on the interior. I may do the silver trim in the door panels not sure yet
    az1441[QUOTED] likes this.
  30. Apr 14, 2017 at 10:24 AM
    az1441
    Steeler Country
    I totally agree. Just enough should make it pop.
