RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. May 14, 2025 at 7:16 AM
    #1381
    1794TX
    Steven
    N.TX
    '20 1794
    Any negatives with the wheel spacers? Are you rubbing anywhere? I'm rubbing the sway bar at full lock going forward, and I'm not sure how worried I need to be about that. Wheels are +50 offset with 35" tires - do you still have the 18" TRD wheels under your spacers? Geometry is tight in there, and I'm afraid backing the tire off the sway bar is going to have it hitting something else. Already removed the mud flaps and spats, and have a spacer on the bumper...
  2. May 15, 2025 at 5:53 AM
    #1382
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    @RainMan_PNW Do you have any clearance issues between the coilovers and tie rod boots?
    I can’t remember if I already asked you but apologies if I did already!
    RobertD likes this.
  3. May 15, 2025 at 5:54 AM
    #1383
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I’ll reply to both of you guys a little later today - been slammed
    TaquitoBandito, RobertD and 1794TX like this.
  4. May 15, 2025 at 7:30 PM
    #1384
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    @RainMan_PNW does your heated steering wheel switch light up when your headlights come on? I just installed mine and it comes on when the switch is activated but it doesn’t back light with the rest of the panel.
  5. May 15, 2025 at 8:40 PM
    #1385
    RainMan_PNW
    Casey
    Clark County, WA
    Only when the switch is activated
    I haven’t taken the time to open up the control box to see if the wiring can be modified to also use the illumination circuit.
  6. May 15, 2025 at 8:40 PM
    #1386
    RainMan_PNW
    Casey
    Clark County, WA
    No issues for me
  7. May 15, 2025 at 8:49 PM
    #1387
    RainMan_PNW
    Casey
    Clark County, WA
    So far, no real negatives other than more mass that I’m sure is contributing to mpg impact I’ve noticed since tires and spacers were installed. But it’s also not the ideal weather for driving for us either so not sure.
    I am still running the factory TRD Pro BBS +60 wheels.
    I no longer have any rub that I notice on the front sway bar, but traded it for a rub on the mud flap in reverse at full turn. I trimmed the bump that sticks out (over the body mount) and that helped but when aired down or in the right amount of suspension movement during the turn I still hear it make contact - I can see where I need to trim a little more on the plastic flap.
    Things I haven’t done are try to find a shop that will actually use the Icon UCA adjustments to dial in the caster so that I can push the tire forward a little more with the LCA, but I’m sure that either trimming or getting ARK mudflaps will be enough. The extra little increase to 35’s would be close though.
    Of course, I am also planning to remove the front sway bar at some point, so rubbing on it would be a non-issue.
  8. May 15, 2025 at 9:06 PM
    #1388
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    You need to do that... yesterday.
  9. May 16, 2025 at 4:30 AM
    #1389
    1794TX
    Steven
    N.TX
    '20 1794
    Thank you.
  10. May 25, 2025 at 10:57 PM
    #1390
    RainMan_PNW
    Casey
    Clark County, WA
    Final step of the radio install - mic hanger.
    I mostly blatantly stole the details from @BiggHertz except that I actually put a nylock nut inside the mic to help ensure the screw never comes undone.
    Grabbed a Mob Armor MobNetic Go setup to dissect for the mic.
    https://a.co/d/aJhTyeN
    Popped open the mic body (two #1 phillips screws) and you can see a hole in the inside that looks like it was made for mounting a normal mic hanger.
    Drilled through that hole with a 9/64" drill bit. Then grabbed a flat-head #8-32 screw 3/4" long and nylock nut.
    Tear apart the Mobnetic Go to pull off one of the magnets and mount it to the back of the mic, then put it back together and slip the rubber cover over the magnet (not shown).
    Then mount the surface mount plate to the wings on either side of the radio (I bought an extra one to mount on the other side as well).
  11. May 25, 2025 at 11:02 PM
    #1391
    RainMan_PNW
    Casey
    Clark County, WA
    Put some random little fish-eye mirrors on the main mirrors. Not sure if I like them or not, but they are there for now. I don't feel like they really give me much additional field of view except that I can sort of tell if my tires are within the lines on a parking spot.
  12. May 25, 2025 at 11:06 PM
    #1392
    RainMan_PNW
    Casey
    Clark County, WA
    Got the set of Baja Designs Rock Lights mounted and wired up on the roof rack.
    Details on the mounts are here.
    I loomed up the wiring for the rock lights with the chase lights just to keep things tidy, and they are connected in to my SwitchPro. I do plan on getting some shorter screws for them though, along with some nylock nuts. The BD kit came with a set of really short screws for their "roll cage mounts" and a set of really long screws - which you can see stick out a mile on the back side of these mounts.
  13. May 25, 2025 at 11:29 PM
    #1393
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    The magnetic mount is so nice and functional. Being around radios for over 30 years in the fire service, switching to a magnetic mount was so practical.
  14. May 26, 2025 at 7:02 AM
    #1394
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    this is the way…
  15. May 26, 2025 at 7:14 AM
    #1395
    RainMan_PNW
    Casey
    Clark County, WA
    But I do eventually figure out the right way
    ToyoMafia, Jim LE 1301, woods and 9 others like this.
  16. May 26, 2025 at 8:53 AM
    #1396
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  17. May 26, 2025 at 9:42 AM
    #1397
    RainMan_PNW
    Casey
    Clark County, WA
    I really need to get some of those
  18. May 26, 2025 at 9:54 AM
    #1398
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ll get one to you. Eventually.
    ToyoMafia, BillyB, Florida AF and 4 others like this.
  19. May 26, 2025 at 5:59 PM
    #1399
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    2-52 weeks…with expedited shipping…
    ToyoMafia, BillyB, woods and 5 others like this.
  20. May 26, 2025 at 6:02 PM
    #1400
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  21. May 27, 2025 at 5:48 AM
    #1401
    woods
    woods New Member
    2021 SR5 TRD Sport
    deleted my post, it's a little more aggressive and not looking to offend people here, or clog up the thread.
  22. May 27, 2025 at 6:08 AM
    #1402
    RainMan_PNW
    Casey
    Clark County, WA
    BiggHertz, TRDFerguson, Mater and 2 others like this.
  23. May 27, 2025 at 6:39 AM
    #1403
    woods
    woods New Member
    2021 SR5 TRD Sport
    I was reminded of my fun bumper sticker after seeing the rtrd ones.
    I'll re-post! Got sick of people thinking because you don't want to live in a city, you are automatically an idiot.
  24. May 27, 2025 at 6:49 AM
    #1404
    imgreenlantern2
    imgreenlantern2 New Member
    Snake Plissken
    Central Texas
    2021 Tundra TRD Pro Double-Cab
    285/70/18 Nitto Ridge Grapplers. RCI rock sliders Leer Tonneau Cover NSV Hood Mounted Lightbar. Suspension air bags for better towing.
    Never was a fan of Lezbo Green. Other then that looks great.
  25. May 27, 2025 at 6:53 AM
    #1405
    RainMan_PNW
    Casey
    Clark County, WA
    :fistbump:
  26. May 27, 2025 at 7:00 AM
    #1406
    RobertD
    Robert
    DFW, Texas
    Must only be called that on 3rd gens. Never once heard it called that before your comment. Learn something new every day.
  27. May 27, 2025 at 7:01 AM
    #1407
    1794TX
    Steven
    N.TX
    '20 1794
    :popcorn:
    Tripleconpanna, TRDFerguson and Mater like this.
  28. May 27, 2025 at 7:39 AM
    #1408
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Your hot take is shit.
  29. May 27, 2025 at 7:43 AM
    #1409
    Florida AF
    Logan
    North Florida
    :amen:
  30. May 27, 2025 at 11:45 AM
    #1410
    RainMan_PNW
    Casey
    Clark County, WA
    Good thing I’m not easily triggered.
    If “lesbo green” gets me flicking beans…glad I expanded my horizons past black and white.
    welcome to the thread. glad you found the time to reply to the very first post. Pull up a chair and catch up.
