RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Apr 30, 2024 at 6:20 AM
    #1081
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  2. May 13, 2024 at 12:55 PM
    #1082
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    saw this video regarding the charcoal filters in air intake filter housings. Basically, removing it is a measurable difference on equipment but not enough to be noticeable to driver. at least on his test car.
    https://youtu.be/F1JmOKKAgyQ?si=DxByZ2jAKcAC8UNy
    bulldog93 and Blue Thunder like this.
  3. May 13, 2024 at 6:59 PM
    #1083
    RainMan_PNW
    Casey
    Clark County, WA
    I’ll take that 1% and love every minute of it
  4. May 13, 2024 at 9:00 PM
    #1084
    Blue Thunder
    Washington
    I noticed it…
    RainMan_PNW[OP] likes this.
  5. May 14, 2024 at 9:03 AM
    #1085
    Totmacher
    Daniel
    West TN
    Some
    We have over twice the displacement of engine in his test car. Might make a difference.
    RainMan_PNW[OP] and Blue Thunder like this.
  6. May 14, 2024 at 9:13 AM
    #1086
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    What a great video. No stupid fluff of showing each run on the dyno or road test. Just a clip and the results.
    Blue Thunder and bulldog93 like this.
  7. Jul 5, 2024 at 5:23 PM
    #1087
    RainMan_PNW
    Casey
    Clark County, WA
    Holy crap - it's been a while since I actually had a chance to do anything but drive it around.
    On June 27, I hit the milestone every 13-yr-old boy giggles about.
  8. Jul 5, 2024 at 5:25 PM
    #1088
    RainMan_PNW
    Casey
    Clark County, WA
    Then today, I installed a Costco Interstate AGM 24F battery. The factory original wasn't showing any signs of problems, other than a little bit of crust under the positive terminal, but I figured it was time. And I gain a little room on the sides to tidy things up when I finally get a chance to do that.
  9. Jul 5, 2024 at 5:29 PM
    #1089
    RainMan_PNW
    Casey
    Clark County, WA
    Also installed an EVC iDrive throttle controller.
    I got this one from @Squatting Pigeon as part of the Blueberry Cobbler demise, so I'm glad to have some part of the blueberry living on.
    I only got a little bit of time to play around with it today - tested it up to U-3 and also E-3. U-0 through 3 (so far) adds some nice pep to the first part of the pedal from a stop or a light - I was enjoying it. Sort of like Tow/Haul, but different too. The E settings definitely retard the response noticeably - E-3 feels like a neutered 4-banger. :rofl:
    Looking forward to playing around with it some more.
    Update 9/7/24 - decided to pull it out. I've got too many miles with the stock gas pedal mapping ingrained in my memory. Anything I tried with the "E" modes just felt retarded and slow, and anything I tried with the "U" modes was just super jumpy right at the top of the pedal.
  10. Jul 5, 2024 at 6:40 PM
    #1090
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    What did you use for attachment method? I have been using some Velcro for my Hike It x9 but thinking I need something a bit better.
    WillTunBlack20 likes this.
  11. Jul 5, 2024 at 6:41 PM
    #1091
    Dsptundra
    Austin TX Area
    Did this require you to change out the diode to pump the charging a bit?
    RobertD likes this.
  12. Jul 5, 2024 at 6:42 PM
    #1092
    RainMan_PNW
    Casey
    Clark County, WA
    Just some VHB tape.
  13. Jul 5, 2024 at 6:44 PM
    #1093
    RainMan_PNW
    Casey
    Clark County, WA
    “Require” - dunno.
    I’ve read all the threads, and the jury seems to be out on whether it’s needed, whether it damages other stuff if you do it, yadda.
    Right now, I didn’t do any diode swaps. I’ll watch it, but am also not super worried about it.
  14. Jul 6, 2024 at 4:48 AM
    #1094
    RobertD
    Robert
    DFW, Texas
    Good stuff! I live in U-3 and that is my happy place for daily driving. Gives me the pep I was looking for without any real down side. I had it in their Auto setting for a bit which I didn't mind for driving around town, but my driveway is sloped and when trying to reverse up hill onto the street, I kept finding myself spinning the tires no matter how hard I tried to not spin them.
    I was so skeptical of a throttle control making a difference, but it soo does. Makes me smile all the time. Have fun with it and let me know what setting you end up in.
  15. Jul 11, 2024 at 6:43 AM
    #1095
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Can you comment on the how secure these lights are mounted? I see they come with metal brackets, but are they just still secured to the plastic bumper cover and bezel? Any shake/rattle with this setup or are you using cable ties to manage?
    Thanks
  16. Jul 13, 2024 at 6:31 PM
    #1096
    RainMan_PNW
    Casey
    Clark County, WA
    They attach to the stock ROUND bezels the same way as the OEM (a clip and a screw), except there’s an additional bolt with a rubber cap on it that puts pressure on the back side of the bumper and holds things tight.
    I haven’t noticed any of the shake that I saw with the TRD Pro headlights/bezels.
  17. Sep 4, 2024 at 1:15 PM
    #1097
    RainMan_PNW
    Casey
    Clark County, WA
    Got some parts starting to trickle in from @memario1214 at HotShot Offroad…
  18. Sep 4, 2024 at 1:22 PM
    #1098
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Fancy
  19. Sep 4, 2024 at 1:25 PM
    #1099
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    You dumpin the front sway? I could be 100% wrong but I thought the CBs don’t work with the sway bar :notsure:
    TaquitoBandito likes this.
  20. Sep 4, 2024 at 1:25 PM
    #1100
    RobertD
    Robert
    DFW, Texas
    Nice! So are you lifting more than your current stance and thats why you are adding the coachbuilder ends?
  21. Sep 4, 2024 at 1:30 PM
    #1101
    RainMan_PNW
    Casey
    Clark County, WA
    No… aiming to be at the same spot as the TRD Pro Fox with the Westcott collar.
    Not that I’ve seen from the CB site.
  22. Sep 4, 2024 at 1:39 PM
    #1102
    Dsptundra
    Austin TX Area
    :popcorn:
  23. Sep 4, 2024 at 2:03 PM
    #1103
    1794TX
    Steven
    N.TX
    '20 1794
    Are you still running the TRD BBS wheels? They have +60 offset? I'd appreciate a short report on how the UCAs fit. My wheels have +50, and I've highly considered new UCAs since leveling.
  24. Sep 4, 2024 at 2:14 PM
    #1104
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    @TundraPHX has rock warriors and ICON Billets...
  25. Sep 4, 2024 at 2:17 PM
    #1105
    TaquitoBandito
    Joel (AKA Bif)
    I'm not sure that's from him. I see nary a corn kernel, a cat, or cat hair in the box.
  26. Sep 4, 2024 at 3:13 PM
    #1106
    RainMan_PNW
    Casey
    Clark County, WA
    Yes, keeping the BBS that are +60.
    I do have Bora 1” spacers coming, but will be checking fit/clearance with the wheels at stock setup as well. For science…
  27. Sep 4, 2024 at 3:14 PM
    #1107
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    The treats come in the next box... :spy:
  28. Sep 4, 2024 at 3:19 PM
    #1108
    RainMan_PNW
    Casey
    Clark County, WA
    That reminds me - I have a box I still need to open…
  29. Sep 4, 2024 at 3:30 PM
    #1109
    RainMan_PNW
    Casey
    Clark County, WA
    treats must be in the NEXT box...
  30. Sep 4, 2024 at 4:54 PM
    #1110
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Damn, wish there'd been a t shirt giveaway when I bought the Morimotos!
