2003 Corolla "Virus"
Discussion in 'Other Toyota Vehicles' started by Tundra2, May 23, 2021.
  1. May 23, 2021 at 1:34 PM
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    I bought this 2003 Corolla as a economical commuter with how things are progressing, and should progress through summer. Perhaps even longer than that. 4Cyl, 129k miles, $3,500 out the door. Long history of routine maintenance at dealers using Vin number to confirm.
    I'm not really going to "build" this out like I did my truck. This is just where I'm going to post maintenance records so I have easy access to them.
    Plans for right now include, but are not limited to:
    1. Oil change/filter.
    2. Transmission drain/fill.
    3. Top off fluids as needed.
    4. Headlight housings replacement.
    5. Possibly LED bulbs on exterior.
    6. Definitely LED bulbs on interior.
    7. Possibly a light bar somewheres.
    8. Anything else I can think of.
    Edit: Purchased with matching set of Bridgestone Encopia 195/65R15
    Dog piss not included with original purchase. +3 MPG.
    1. First picture with info (Page 1.)
    2. First oil/trans fluid change @129K miles Plus LED reverse lights (Page 1.)
    3. Previous impact damage underneath the car. (Page 1.)
    4. Broken interior stuff, and Headunit shots. (Page 1.)
    5. Trunk LED, and license plate LED. (Page 1.)
    6. Interior dome light LED, and shifter LED. (Page 1.)
    7. Center HVAC Bezel stack mod. (Page 2.)
    8. License plate holder repair, and Legal beagle intensifies. (Page 2.)
    9. First wash the lazy way. (Page 2.)
    10. Initial Light bar mounting idea as seen in the wild. (Page 3.)
    11. @empty_lord's Brake Upgrade suggestion. (Page 3.)
    12. Unashamedly Fangirling... (Page 3.)
    13. May 27th, 2021 Sunrise shot at 60 MPH. (Page 3.)
    14. Dealership records of repair. (Page 4.)
    15. Steering wheel cover. (Page 4.)
    16. PHM's 9012 HIR upgrade. (Page 4.)
    17. Cigarette lighter LED upgrade, and Rearview led replacement. (Page 4.)
    18. Gas station Vibes at 5:00 a.m. (Page 4.)
    19. How-to: cig-lighter LED upgrade requested by PHM. (Page 4.)
    20. More in-depth pics of Cig-lighter Upgrade. (Page 4.)
    21. Error Codes "CEL" (Page 4.)
    22. Cross-reference part numbers on MAF. (Page 4.)
    23. Price comparison: Autozone VS. Amazon. (Page 4.)
    24. EVAP hose replacement one. (Page 5.)
    25. Headlight restoration. (Page 5.)
    26. OEM turn socket conversion, and HVAC LED upgrade. (Page 5.)
    27. New Denso MAF install. (Page 5.)
    28. $10 DD LED flasher relay install. (Page 5.)
    29. New OEM window switch bezel. Grippin' Grain! (Page 5.)
    30. New Radiator fan/Overflow reservoir. (Page 5.)
    31. 1157 LED turn signal conversion. (Page 5.)
    32. Test fit light bar switch. (Page 5.)
    33. Wired in light bar switch. (Page 6.)
    34. Fuel spreadsheet. (Page 6.)
    35. Pensacola, Fl trip report, and stickerage. (Page 6.)
    36. Pensacola Pictures. (Page 6.)
    37. Fuel spreadsheet as of 7/12/21 (Page 6.)
    38. Scosche Low-Pro dash mount. (Page 6.)
    39. 4,773 Mile oil/Trans fluid change. (Page 7.)
    40. Blackstone Labs ATF Sample report. (Page 7.)
    41. Skyfire Pictures. 8/13/2021 (Page 7.)
    42. Shift cable boo-boo. (Page 7.)
    43. Shift cable Repair! (Page 7.)
    44. Oil Change with custom funnel. (Page 7.)
    45. 140K miles. (Page 7.)
    46. Oil change, and downstream 02 sensor replacement. (Page 8.)
    47. Driver window fell out of track. (Page 8.)
    EDIT: As of this edit, here's all the states that the car, and I have been to. 11/4/2022
  2. May 23, 2021 at 1:57 PM
    18" TRD Off Road Wheels
    Awesome, Noah! Really watch out for the deer, though.
    @empty_lord you're the master of resto on used rigs. Any suggestions?
    IsaiahCanada and Tundra2[OP] like this.
  3. May 23, 2021 at 2:16 PM
    Tundra2
    Noah
    Western Kentucky
    Thanks! I'm hopeful to get use out of it until 2024. :rofl:Deer permitting
    I pulled the transmission dipstick before I bought it. Fluid on the stick looked pretty dingy. I'm gonna go out to the local Wallace wurl soon, and pick up some valvoline type T-IV fluid. Try to change that, and the oil today.
    Oil looked like oil.
    GODZILLA[QUOTED] likes this.
  4. May 23, 2021 at 2:18 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Timing chain tensioner probably is leaking. There’s a chance the back of the head seeps oil.. but yea ignore that. Bug thing is regular maintenance. Get it up to date. They’re bulletproof cars
    NUDRAT, Tundra2[OP] and GODZILLA like this.
  5. May 23, 2021 at 2:19 PM
    empty_lord
    05 rollover special
    Use the larger oil filter for the oil. YZZF1 is what I ran on the car. Took ~4.3 quarts. Just put 4.5 in. Only use 5w-30. I ran Mobil one extended in it. Car never skipped a beat. Miss the 06 I had.
  6. May 23, 2021 at 2:57 PM
    Tundra2
    Noah
    Western Kentucky
    Good info! Much appreciated. I'll dive into it soon~ish.
  7. May 23, 2021 at 3:00 PM
    empty_lord
    05 rollover special
    Get some S model head lights from TYC or better yet OEM. replace the low beam with 9012 bulbs, and the high beam with 9011. Slight bulb tab trimming required, out performance any LEDs i tried in my 06.
    Prius wheels can be found cheap and are a nice upgrade from the OEM steelies youve got, wheels should transfer over and you might gain a WEE bit in MPG with the ultra light Prius aluminum (i have prius wheels on my corolla.. LOL)
  8. May 23, 2021 at 3:02 PM
    empty_lord
    05 rollover special
    i miss my little shitbox. RIP
    but corolla # 2 (and technically #3) are doing well
    Soupbean77, coldcanuk, NUDRAT and 2 others like this.
  9. May 23, 2021 at 3:12 PM
    Tundra2
    Noah
    Western Kentucky
    Great info! I honestly can't thank you enough!
    Two things I'll need today lol. Torque specs for the transmission, and oil drain plugs.
    Think its 3.5 quarts for gender neutral shift juice?
    I'll keep an eye out on skaggslist for prius wheels. Any extra MPGs I can squeeze out will be choice.
  10. May 23, 2021 at 3:15 PM
    empty_lord
    05 rollover special
    get like 5 quarts to be safe
    as for torque specs i think theyre around online somewhere. im not able to get on TIS today. so im not much help there
    Tundra2[QUOTED][OP] likes this.
  11. May 23, 2021 at 3:16 PM
    Tundra2
    Noah
    Western Kentucky
    I'll see if Autobones has a Haynes.
  12. May 23, 2021 at 6:45 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I went to the local junkyard to pickup a full size spare for the Pius. Probably find a set there if you have a yard local.
    Definitely going to need to add Raptor lights to that. :rofl: (you should just, well - 'cuz.)
    WFD473 and Tundra2[OP] like this.
  13. May 23, 2021 at 6:46 PM
    empty_lord
    05 rollover special
  14. May 23, 2021 at 6:58 PM
    Sbrow191
    Sbrow191 Jus Lerkin
    NC
    2006 DC Tundra XSP 4x4
    Smartest post I’ve seen in a while tbh.
    congrats!
    Redcon41318 and Tundra2[OP] like this.
  15. May 23, 2021 at 7:25 PM
    Tundra2
    Noah
    Western Kentucky
    Oil filter/change done, and Transmission drain/fill at 129,256 miles.​
    Old shift juice.
    New shift juice.
    Dick-less, and lip-less at Murfreesboro Toyota put the oil filter on with about 7 ugga duggas. I couldn't get it loose. Had to run out, and buy a proper 3/8 drive wrench for the filter. Couldn't find the YZZF1 as Wallace wurl and autobones were sold out. Purchased two YZZF2. Dexron IV for shift juice.
    Changed the reverse lights to LED as I had that bulb on hand.
    WFD473, Blue Thunder, NUDRAT and 3 others like this.
  16. May 23, 2021 at 7:27 PM
    Wallygator
    Have always said the only car that can survive the apocalypse is the Toyota Corolla. FACT!!!
    Y0TA PR0, WFD473 and Tundra2[OP] like this.
  17. May 23, 2021 at 7:36 PM
    Tundra2
    Noah
    Western Kentucky
    So after wallering around on the ground inspecting things, I'm noticing things I didn't before.
    Coolant overflow reservoir has a crack about half way up. Didn't see it on PDI due to hair line. Noticed it after topping off coolant. It's part of the Auxiliary fan so I'll have to pay some monies for that one.
    Front left pinch weld or hook is bent inwards towards the middle of the car, and right underneath the radiator center support is bent straight back towards the rear of the car. I didn't have ramps to take with me to pull it up, and onto when I did my inspection. Y'all already know this fat boy can't get underneath the car without ramps. :rofl:
    I don't think these are going to be huge issues, but surprised the damage didn't show up on carfax. Probably a minor accident at low speed that the previous owner just said fuck it.
    Wallygator and GODZILLA like this.
  18. May 23, 2021 at 7:44 PM
    Tundra2
    Noah
    Western Kentucky
    One of the two previous owners must have had, or personally installed this Kenwood aftermarket head unit. It does everything I care about. Blueteef. Saves me work. Win.
    Also, this vent doesn't stay where I put it on the vertical axis. Don't really care too much about that either. Possible flea-bay item.
    @empty_lord. Are there LEDS to be changed out or is all this stuff soldered on boards? I absolutely love the dash, but just wish it had oil pressure also. I'm just not much a fan of the green anymore.
    This compartment door is fubar. Don't really care that much unless I find a cheap flea-bay part.
    Drivers side window switch trim is broke-dick. May peruse flea-bay for this. Not really a huge issue for me.
    Mountun Goat and Wallygator like this.
  19. May 23, 2021 at 7:46 PM
    empty_lord
    05 rollover special
    My rollover doesn’t appear on car fax... that core support damage is fine. As long as the hood closes and nothings rubbing
    NUDRAT and Tundra2[QUOTED][OP] like this.
  20. May 23, 2021 at 7:47 PM
    empty_lord
    05 rollover special
    For the cluster they’re LED. You can put other corolla clusters in with different colors. But meh.
    The center stack I believe is neowedge bulbs. But it’s been soo long I don’t remember
    Tundra2[OP] likes this.
  21. May 23, 2021 at 7:54 PM
    Tundra2
    Noah
    Western Kentucky
    Good deal. Nothing appears to be rubbing, or sounds like it is. Hood closes fine if dropped from about 6-8 inches. Won't latch if I push it down like my truck will. Even then it takes a small amount of force on the Tundra.
    Plenty of times I've been stuck in a ditch (189) and didn't report it as there was no real damage.
    I'm sure there's a youboob video out there. Now, if only I could get those damned bulbs out of the bottom of the rear view. My masking tape isn't sticky enough lol
    GODZILLA likes this.
  22. May 23, 2021 at 8:03 PM
    Tundra2
    Noah
    Western Kentucky
    NUDRAT, Wallygator and GODZILLA like this.
  23. May 23, 2021 at 8:50 PM
    Tundra2
    Noah
    Western Kentucky
    Perhaps I keep too many LEDs on hand...
    Led cargo/trunk light that's probably way too bright for its job. :laser:
    Led License plate bulbs that are perfect for their job. I'll have to see about removing the rear trim above the license plate, and sealing up where the light is coming through above the left light in the photo.
    The screw in tie-down for the donut was just rolling around in the floorboard there. Remdied. Lug wrench was loose cargo also. Remedied. My filter socket thing just so happens to be a perfect fit inside the foam dome that sits over the screw in tie-down.
    Spare filter also in the area. Nothing else I have uses either of those so this is perfect storage. No need to lose them in the clutter.
    :yes:
    Also, came with two OEM keys, and two OEM working key fobs.
    Check engine code for P0420. Will mend that sometime soon after I get Haynes, and confirm rear sensor is dead as I suspect from scan-tool.
    coldcanuk, GODZILLA and Wallygator like this.
  24. May 23, 2021 at 9:00 PM
    Tundra2
    Noah
    Western Kentucky
    Thank you much! As most of the regulars know... I drive 100~ish miles a day, at least Monday through Friday. This should help minimize future petrol expense.
    I did the math with my tundra as I've been keeping track.
    Average MPG is 15.8. Round up to 16 for easier math. 100 miles divided by 16 mpg equals 6.25 gallons of gas. Pretty much a quarter tank daily. $4.00 gas costs multiplied by 6.25 gallons of gas is $25 to commute back, and forth to work. Monday through Friday. Monday through Friday fuel expense assuming $4.00 gas, and consistent MPG.
    $25 multiplied by 5 days equals $125 a week.
    Adds up quickly over the course of a year.
  25. May 23, 2021 at 9:18 PM
    empty_lord
    05 rollover special
    either that or broken welds around the cat. but typically you'd hear that. GET AN DENSO sensor. Best to replace both if ones dead. the front sensor can fail and cause a false 420 code too.
  26. May 23, 2021 at 9:25 PM
    Tundra2
    Noah
    Western Kentucky
    She runs quiet as a barn mouse. I figure it's just a dead sensor. Drove exceptionally the 120 miles home. Waiting till monday for stuff to open to get insurance ball rolling, tags, taxes...
  27. May 23, 2021 at 11:04 PM
    Tundra2
    Noah
    Western Kentucky
    Changed interior dome festoon to LED courtesy of passenger side vanity light from the Tundra as I rarely have passengers.
    Changed the PRNDL oem green to cool white led...
    Can confirm the other lights are neowedge. I may just go back to OEM green led. It's sorta growing on me now that I've had the dash apart...
  28. May 24, 2021 at 4:49 AM
    Sbrow191
    Sbrow191 Jus Lerkin
    NC
    yup. Plus the tundra will depreciate less with less miles and when shit breaks on the tundra it’s gonna be more expensive in general to fix.
    don’t want to go full tree hugger but you can also feel pretty good about using less Dino juice and saving some for Elon Musk’s escape plan, I mean “Mars mission”.
  29. May 24, 2021 at 5:10 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Seconded.
    This provides perfect color rendering. Leds will not.
    Led lights in a 2003 corolla will attract some extra attention you probably won't want.
  30. May 24, 2021 at 7:04 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    P0420 might be the cat.. oil burning might be an issue on the 1zz.. I mean you can still get 26mpg even with a bad cat. My Celica did for years, before I moved it out and had to smog it and was forced to replace the cat, and yes I did replace both upstream and downstream sensors and the code still came back.
