2003 Corolla "Virus"
Discussion in 'Other Toyota Vehicles' started by Tundra2, May 23, 2021.
  1. May 31, 2021 at 8:46 PM
    #121
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
  2. May 31, 2021 at 9:20 PM
    #122
    Tundra2
    Noah
    Western Kentucky
    Changed 10mm/⅜ hose coming from gas tank to metal tubes that run upfront somewhere. I bent the old hose, and sidewall cracks revealed themselves. No pics because you need 3 hands for that operation under the car.
    Noticed another questionable hose ziptie tensioners. Looks Itty bitty. No replacement on hand, or spring clamps.
    I know, I know silicone tube bad. Especially here... it's all I had. I'll wake up early today/tomorrow, and go directly to Rural king looking for replacement rubber hoses.
  3. Jun 1, 2021 at 9:19 AM
    #123
    Tundra2
    Noah
    Western Kentucky
    Rubber hose purchased, and installed in place of silicone. No pics because plenty ahead of this post. Cost was .86 cents a foot. :)
    While in autobones, I saw headlight resto kit on clearance for $17.50. Decided to try it out today instead of $400 headlight assemblies with complete bumper removal to access side bolt on headlight :rolleyes:
    https://youtu.be/SNU_vpID5mE
    Today was overcast with no rain. Griots garage headlight resto-kit says no water on final ceramic coat. I was wiping down the first headlight when it started to sprinkle... only increased from there :rain:
    Time will tell how well it holds if at all because it all went sidewayz halfwayz through :rofl:I spent significantly longer on the drivers side because it wasn't raining. I really gave her the elbow juice on the passengers side. I mean just fisting that whole light on the sanding step. :muscleflexing:
    FirstGenVol and onesojourner like this.
  4. Jun 1, 2021 at 10:52 AM
    #124
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Nice work. These polished headlights still have a lot of life left. Plan and giving them this treatment about once a year. Also Power tools are your friend. I bet you will find a bit more clearity.
    I was watching this video and I thought of you. You might want an excuse to hang out outside on a nice cloudy June day hanging out with your truck and car doing relatively mindless work.
    https://www.youtube.com/watch?v=ulWXODgg8V4
  5. Jun 1, 2021 at 10:55 AM
    #125
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I need to find time to read this but the thread title alone is priceless!
    FirstGenVol, Tundra2[OP] and GODZILLA like this.
  6. Jun 1, 2021 at 6:07 PM
    #126
    Tundra2
    Noah
    Western Kentucky
    I bet you're right about clarity! I've never used a headlight restoration kit before this. Kinda makes me wished I'd done that with my original truck buckets that I still have. I opted not to use power tools on my first time to avoid potential fubars. I may practice with a power tool set on my trucks old buckets. The only reason I still have them is because of deer. Never know when you're gonna need another set. ;)
    That's a helluva long one. I'll have to listen to it on the way home. An overcast June day will be great for another application of headlight resto (because it rained on my ceramic coat.)
    It was just a "build" instead of Virus. Last night my little brother came out and talked to me while I was under the car. He asked me what I was doing to my Corolla Virus. I just wished I'd thought of it. :rofl:
  7. Jun 1, 2021 at 6:13 PM
    #127
    Tundra2
    Noah
    Western Kentucky
    Rocker switch
    Mag Light Bar mount
    Also, some sort of roof light bar action will be happening. It will be my biggest light bar yet.
    :laser:
    The car sits just under 5 feet tall roughly. My head sits about 4 feet off the ground. Headlights are about 1.5-2 feet off the ground. The buck bushes, and grass on the side of the roads I drive on are anywhere from 3 to 4 feet tall in some places.
    I need to be able to see above the grass which means I need more light above it. I figure I can place the light bar in the middle of the roof to alleviate hood/windshield glare.
    I figure I can put that green switch here because I don't enjoy that shitty coin holder thing anyways.
    Still not quite sure how I'm gonna get the wiring up there. I'll probably do one of these.
    https://youtu.be/fFNoTDlDIZI
    https://youtu.be/YWfUnoVF1V4
  8. Jun 1, 2021 at 7:19 PM
    #128
    Tundra2
    Noah
    Western Kentucky
    FYI: Any lighting experts opinions would be welcome here on this. I'm against nothing except drilling if it can be helped.
    Never done a roof bar before.
  9. Jun 2, 2021 at 5:25 AM
    #129
    Tundra2
    Noah
    Western Kentucky
    OEM turn socket LED conversion for proper turn socket fitment! (SBL 4MM neowedges are on a 3 month back order so I ordered the 3MM and converted the original sockets.)
    I'm one light short. :rofl:
    onesojourner likes this.
  10. Jun 2, 2021 at 6:58 AM
    #130
    Tundra2
    Noah
    Western Kentucky
    I hadn't considered a door wiring run...
    https://youtu.be/yp-JMya_RWg
    I figure the rear passenger door will be used least.
    I have a few methods to investigate now. Options are good!
  11. Jun 2, 2021 at 3:15 PM
    #131
    Tundra2
    Noah
    Western Kentucky
  12. Jun 2, 2021 at 3:25 PM
    #132
    Professional Hand Model
    Fred
    Hand Protectors
    Ye. Nice on the lights buffings. I’ve done my OEM 2 Times in the past. First time looks good for a season or two. Second time one season at best. Used the 3M Kit with Power Tools Buffer Kit ($40).
    Maybe time to spend that $390 refund from your headlights assys on some Morimotos 2.0’s. :D
    Tundra2[OP] likes this.
  13. Jun 4, 2021 at 4:17 AM
    #133
    Tundra2
    Noah
    Western Kentucky
    Changed assumed autobones MAF for Denso 197-6030 OE. This is how the box arrived. As you can imagine I was less than gruntled. Disgruntled even.
    Fortunately, the actual MAF was fine. Below you'll see comparison shots of the Denso and the No-Name unit. The visible pin which I'm assuming is the Temp sensor on the No-Name is slightly shorter. Perhaps this is why my outside temp guage is off by a few degrees, but I think that sensor is in front of the radiator. Time will tell.
    Magnet collar on screwdriver helps tremendously with itty bitty, teeny weeny, tiny winy scwews. Free.99 from work.
    NUDRAT and onesojourner like this.
  14. Jun 4, 2021 at 4:26 AM
    #134
    Tundra2
    Noah
    Western Kentucky
    Installed $10 DD LED turn signal flasher. I completely mangled the fuck out of the original plastic mount because I entered full gorilla mode when the anger started flowing through me.
    Big hands in tiny hole equals frustration or a good time. Depends on who you're with.
    Anyways.... since I completely ruined the mount for it I trimmed up one of the side supports for the clip, and trimmed the locking clip on the relay clip. Below is the side support I trimmed up to make it fit again.
    It fits pretty good considering I was trying to save my FUBAR. It was so much easier on my truck!
  15. Jun 4, 2021 at 4:29 AM
    #135
    Tundra2
    Noah
    Western Kentucky
    Added old set of work gloves to side glove box compartment thing by the steering wheel for inevitable deer carcass removal.
  16. Jun 4, 2021 at 4:50 AM
    #136
    Fred
    Hand Protectors
    The Mangle is Strong in this one. :rofl:
    We’ll give you a break since it was plastic. :thumbsup:
  17. Jun 4, 2021 at 1:41 PM
    #137
    Tundra2
    Noah
    Western Kentucky
  18. Jun 4, 2021 at 2:41 PM
    #138
    Tundra2
    Noah
    Western Kentucky
    10 minute install. 3 minutes to swap screws, and 7 to figure out how to put in an unbroken bezel. :rofl:
    NUDRAT and GODZILLA like this.
  19. Jun 5, 2021 at 4:57 AM
    #139
    Tundra2
    Noah
    Western Kentucky
    Changed my Fan/Overflow reservoir today!
    Blue arrow is pointing to a mangle crack repair done by previous owner. Wouldn't hold fluid above the crack which bothered me.
    The new one came with an overflow relief that the OEM one didn't have. Added a date sticker for future reference.
    I decided to use the funnel after I had a little oopsie daisy as evidenced above.
    Dorman 620-546 Engine Cooling Fan Assembly
    This was indeed a perfect fit, and that new Fan sounds strong! :muscleflexing:
    Added Permetex Anti-sieze to both overflow bolts!
    NUDRAT likes this.
  20. Jun 5, 2021 at 5:04 AM
    #140
    Tundra2
    Noah
    Western Kentucky
    Changed front turns to 1157, and LED using "old" bulbs from the Sequoia. Below is a shot of the old, crusty Drivers side, but both bulbs were like this.
    In the below picture the passengers side is the only one changed.
    NUDRAT likes this.
  21. Jun 5, 2021 at 5:12 AM
    #141
    Tundra2
    Noah
    Western Kentucky
    Cleaned battery terminals (even though it doesn't look like it...) and applied anti-sieze to the battery hold down bolt/stud.
    Battery is dated 9/18. Both the Tundra, and the Corolla use group size 35. Perhaps I'll look into getting one of them "new fangled" dry cell units for the Tundra, and Rob it's battery for this.
    Tundra will sit pretty much 6 days a week now. Sorta sad, but kinda glad too.
    FirstGenVol and NUDRAT like this.
  22. Jun 5, 2021 at 5:18 AM
    #142
    Tundra2
    Noah
    Western Kentucky
    Test fit my new toggle switch for the light bar. It wasn't a perfect fit like I'd hoped, but I'd bet money that it would fit exactly into a newer toyota slot.
    I elected to swap the dimmer switch, and the toggle switch positions because I can see the toggle now from just about anywhere my head is while driving normally.
    Here is the original layout above. I used that stupid coin holder thing as a reference while I rounded the corners of the toggle so it would fit more snugly in the trim piece.
    @empty_lord can you provide me with a pin-out or a wiring diagram for the dimmer switch. I would like to tie the toggles back light into the actual dash lights circuit so it won't be on all the time.
    NUDRAT likes this.
  23. Jun 5, 2021 at 5:29 AM
    #143
    Tundra2
    Noah
    Western Kentucky
  24. Jun 5, 2021 at 6:20 AM
    #144
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Ya got to love Corolla's. I found an XRS model in the Riverhead Toyota (Long Island) and had to have one. My 2006 I found in Florida at a Honda dealer it had 17,000 miles when I purchased it and 250,000 before some girl hit me from behind and totaled it. I found another 2005 in Topeka, Kansas at Briggs Subaru Of Topeka. They handle well, the XRS is peppy and I get good gas mileage.
  25. Jun 5, 2021 at 6:27 AM
    #145
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
  26. Jun 5, 2021 at 10:00 AM
    #146
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    off-brand 1st Gen
    I'm sorry, can we talk power steering fluid? That's bothering the F outtame. :(
    Tundra2[QUOTED][OP] likes this.
  27. Jun 7, 2021 at 5:08 PM
    #147
    Tundra2
    Noah
    Western Kentucky
    NUDRAT likes this.
  28. Jun 8, 2021 at 6:48 PM
    #148
    Tundra2
    Noah
    Western Kentucky
    I'm slowly turkey basting it into new fluid. The reservoir is just stained is all.
  29. Jun 8, 2021 at 7:31 PM
    #149
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It’s bothering you? Fuck my tundras is begging me to replace it it’s so stained. I’m looking into metal reservoirs for
    It right now
  30. Jun 8, 2021 at 8:21 PM
    #150
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    off-brand 1st Gen
    We used to use rock salt & ice cubes - shaken, not stirred to clean'em-out. IIRC, cause that was as long ago as you two is old pretty much. :anonymous:
    (removed & empty first of course).
