  1. Dec 26, 2022 at 9:19 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You’d actually really like @robabeatle sound set up, he’s gone way above and beyond just the doors, with other Materials as well I believe. He’s a audio head similar to yourself!
  2. Dec 26, 2022 at 9:20 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    [​IMG]that
    L area of the box is the target.
    oscardog86 likes this.
  3. Dec 26, 2022 at 11:50 PM
    empty_lord
    05 rollover special
    Said screw it. Wire, rtmr, Deutsch connectors, pins, seals, plugs, a ground bus and some other odds and ends coming. Wiring projects to start soon. Once I have the rtmr and ground bus I’ll check fitment where I want it all then decide if I’m running a dual j case fuse holder for my amp and future larger draw add ons or if I’ll be running a single space dependent
    trucks garage queen stayus for now with the body damage. So may as well make progress where I can
    txagg and KNABORES like this.
  4. Dec 27, 2022 at 3:54 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Thanks for your thoughts on the window seals; is this the part?
    https://www.rockauto.com/en/catalog...&+lamp+assembly,windshield+molding+/+seal,766
    And for sure, way over kill with the cld in many respects. Now, I did not use a solid piece of abs or the like to cover the huge holes in the door, just the cld which in theory helps the midbass. Also, using the cld on the door card to hold the mlv there in place. But most people mistakenly believe that cld will block road noise and well, not so much. For that you need mass, like mlv, which I have 100 lbs in the truck: mostly the floor of the cab and the doors. I just happen to have extra cld around and wanted to make it extra difficult to put on the door panels each time, which is about every other day now. :facepalm:
    I just learned a new technique for getting the time alignment down to the resolution of the dsp. Not hard once I got my hand held by a german gentleman. Here is a pulse from the tweeters reaching the midpoint of where my head would be:
    The idea is to delay timing until the initial rise in each tweeter is overlapped. That way the signal from each tweeter (and then each woof, etc.) all reach the listener at the same time. Imaging is coming along...
    txagg and shifty`[QUOTED] like this.
  5. Dec 27, 2022 at 5:35 AM
    daveeasa
    David
    I believe this is the electrical tray I have, in case it helps:
    https://www.kamdesignstudios.com/electrical-mount-v1-5
  6. Dec 27, 2022 at 7:31 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I hope I’m just seeing things and that isn’t coolant mixing with the oil to make it reddish brown.
    Still need to take care of this valve cover gasket leak…
  7. Dec 27, 2022 at 7:35 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Looks like just normal oil to me.
  8. Dec 27, 2022 at 7:36 AM
    Jack McCarthy
    Bill
    North of Boston
    Im hoping you’re right. I’ll change it next week just to make sure.
  9. Dec 27, 2022 at 7:39 AM
    Crack your oil pan drain plug and see if any water comes out.
    oscardog86 and Jack McCarthy like this.
  10. Dec 27, 2022 at 7:52 AM
    Jack McCarthy
    Bill
    North of Boston
    That’s a good point. When I drain it, I can pour some into a clear container and see if water separates from the oil.
  11. Dec 27, 2022 at 7:53 AM
    If there’s water in there, it will come out first. The oil will float on top of the water
    oscardog86, Filthyphil, txagg and 2 others like this.
  12. Dec 27, 2022 at 8:30 AM
    shifty` Inside his chest they found ten thousand pencils
    Oh, I know, I remember when he did his cab floors and was thinking that was overkill too, but I'm not one to knock anyone, I totally understand. Over-the-top is OK in that case. :D
    It came up in conversation over here but the meat of the conversation and issue is over here. I suspect the core of the problem is the seal I pasted in orange in that 2nd thread. But it could also be the red or the green seals.
    I think @Kimosabe replaced the 'sweep' or 'squeegee' part that's 68172A / 68172B in the diagram he posted after my colored diagram and he says that got rid of 80%+ of the rattles. Someone did, at least. But I'm skeptical if all rattles can be quelled without doing the upper seal I lined in orange.
    I believe it was on another forum, that I saw where someone took backer rod and was able to shove it into the seal I painted in orange and it 'fixed' the rattle. But I can't seem to find that thread again, so I dunno what size backer rod to buy.
  13. Dec 27, 2022 at 8:48 AM
    robabeatle
    AZ
    Exactly the kind of solution I was looking for. :cheers:
    I happen to have a piece of irrigation drip line that is miraculously the exact length of the window channel. I slipped into that fold. The window closed but struggled a tiny bit at the very top. A few times back and forth and it closes fully. I will test to see if it stops the rattle later.
    shifty`[QUOTED] and txagg like this.
  14. Dec 27, 2022 at 11:37 AM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Thank you for that link. I ordered the parts listed there and the OEM handle. My truck is a DC.
    shifty`[QUOTED] likes this.
  15. Dec 27, 2022 at 1:59 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  16. Dec 27, 2022 at 3:01 PM
    Where'd you stuff it in the channel and what diameter hose? Last time I looked, I seem to remember it having two flaps on either side that should put pressure on the window, ceasing any rattle. And that would give with time. I figured you could stuff backer rod into the back of it like shown here with red dots (this isn't our exact seal), which would force more firm grip on the window. Is this basically what you did?
  17. Dec 27, 2022 at 3:02 PM
    Sucks though, I looked it up, and the paint-matched one isn't around anymore for your truck. It would've been the part number ending in 'b0' or 'b1'. I found a couple on fleaBay.
  18. Dec 27, 2022 at 3:23 PM
    robabeatle
    AZ
    I did, but with 1/8 inch drip irrigation line. I tucked it into one side of the flaps only. I figured backer rod is too flexible. It definitely removed a good bit of play in the window. Thank you sir. :thumbsup:
    When I first got the truck, I also ran silicon based tubing on the outside seals of the doors and it is holding up still. In southern AZ, that is a feat.
    So, the window is better, but the damned rattle is still there so it is something else. Chasing rattles aint no fun.
    shifty`[QUOTED] and FrenchToasty like this.
  19. Dec 27, 2022 at 3:42 PM
    FrenchToasty
    Mo
    Bone stock
    8E3FE39B-182B-4A8E-9C92-EF9889353D2A.jpg 8FED06F0-6724-4FE4-A1DF-AAC01353D142.jpg AA09A587-B052-48AF-9B33-90F81EB32542.jpg 0D770EB1-FE58-4A95-847B-59C24CC89B5A.jpg 1B586F55-0724-4B6E-B064-ACF11DB194E2.jpg Did some welding on the bumper today. And then found where my PS leak was coming from(cracked hose at the cooler) so I went and got more hose but capped the lines while I sanded and cleaned with purple degreaser. Tomorrow I’ll be painting it black, hopefully I can get into all the nooks on the backside
    oscardog86, txagg, bmf4069 and 5 others like this.
  20. Dec 27, 2022 at 4:41 PM
    Thems some good looking welds.
    Tundra2 likes this.
  21. Dec 27, 2022 at 4:50 PM
    FrenchToasty
    Mo
    Bone stock
    Most of them weren’t mine
    Tundra2 and shifty`[QUOTED] like this.
  22. Dec 27, 2022 at 4:51 PM
    Oh, in that case, those are some shit welds, bro! :rofl:
  23. Dec 27, 2022 at 5:27 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Shitty/Non-Shitty welds aside... It all fit gud?
  24. Dec 27, 2022 at 5:48 PM
    FrenchToasty
    Mo
    Bone stock
    Yeah fits nice
    Tundra2[QUOTED] likes this.
  25. Dec 27, 2022 at 5:53 PM
    TUNDRA
    Tundra2 and FrenchToasty like this.
  26. Dec 27, 2022 at 5:54 PM
    << TUNDRAAAAAAAAAAAAAAAA
  27. Dec 27, 2022 at 5:55 PM
    Jack McCarthy
    Bill
    North of Boston
    Tunora
    Tundra2 likes this.
  28. Dec 27, 2022 at 5:57 PM
    It's really hard to etch on round tubing but you may be right.
  29. Dec 27, 2022 at 6:43 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I wouldn't have noticed if yall didn't point it out! Lol
  30. Dec 27, 2022 at 7:44 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    you're fine. Coolant would make it milky and opaque. Looks like good clean oil.
