  1. Jun 10, 2021 at 1:47 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Are you sure you have clear coat? My work van white tundra came without it.
    The clear coat is a toyota problem in my opinion.
  2. Jun 10, 2021 at 1:57 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Yes I do. I only have to look at the inside of the fuel door to see the paint without clear on it.
    onesojourner[QUOTED] likes this.
  3. Jun 10, 2021 at 4:36 PM
    Azblue
    The Dirty T ( ^_^)_且
    It's the sun. I've lived in Tucson my entire life and have never had that problem. The key is just waxing (preferably with a good synthetic, not plain wax) more often. I try to do our vehicles at least quarterly. Same goes for the headlights, wax often. I've never had cloudy lights either.
  4. Jun 10, 2021 at 4:36 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    McGeorge sent me some more enjoyment for next week :yes:
  5. Jun 10, 2021 at 4:42 PM
    Jack McCarthy
    Bill
    North of Boston
    New wheels from energy suspension just came in for the creeper. I was concerned about it being bright red, but these actually match the cushions, so im good. Just need to buy some dremel cutting wheels to cut off the originals now.
    TRDGen, Darkness and bmf4069 like this.
  6. Jun 10, 2021 at 5:18 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    New key fob case since the 02 taco has damn near the same key and the same key fob. Cement gray AJT should make the tundra key pop a bit eh? Might even order an black one with red screws for the tacos. [​IMG]
  7. Jun 10, 2021 at 8:27 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    It's definitely the wax. Pretty sure mine has never been done and has been in the TX sun it's whole life.
  8. Jun 10, 2021 at 8:56 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Why are my ears on fire? :bananadead:
  9. Jun 11, 2021 at 1:00 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I ended up ordering 4 of the the desert armor spot/flood combo ambers
    SoCalPaul[QUOTED] likes this.
  10. Jun 11, 2021 at 5:33 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Today I got my truck back with the nitro 4.56 gears, nitro helix LSD and Eaton locker in front installed. Also changed the rear bearings, o ring, gaskets whatnot.
    Now to wear it in over weekend and run the switch for the locker. Pretty excited!
  11. Jun 11, 2021 at 5:39 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’ve been heavily contemplating gears, I’d probably do a Elocker for the rear, still not sure what ratio id go, what size of tires you running, and any extra weight added?
    des2mtn and Voss[QUOTED] like this.
  12. Jun 11, 2021 at 5:53 PM
    Voss
    2003 AC TRD 4x4
    285/75R16 KO2s. No extra weight yet but will soon have skid plates, sliders and a RTT. I’ve only driven her home and at 1st I couldn’t feel much of a difference with the 4.56 gears. Then I realized I was accelerating a lot faster than I usually would. Haven’t tested freeway driving yet.
  13. Jun 11, 2021 at 6:01 PM
    empty_lord
    05 rollover special
    Washed the truck today. And the god damn hard water strikes again. Water spots after I drove it from the spots I wasn’t able to dry.
    onesojourner, Filthyphil and hammeron like this.
  14. Jun 11, 2021 at 6:05 PM
    hammeron
    hammeron New Member
    2002 Tundra v8 Blue 2wd
    Question please: I'm changing out uppers and lowers and on the upper, should the top of the boot slide past the metal ring? Instructions do not say to do so, but want to do it right. The second pic is how it sits now.
  15. Jun 11, 2021 at 6:45 PM
    empty_lord
    05 rollover special
    I believe it sits just above the snap ring. Been a while
  16. Jun 11, 2021 at 7:15 PM
    hammeron
    hammeron New Member
    Thank you, that's the way I will install it then.
  17. Jun 11, 2021 at 11:06 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Just did mine last week and did the same.
  18. Jun 12, 2021 at 8:55 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Brakes felt stiff during weekly drive. Bled brakes once home with new to me help. Last time I use the new found help for truck things. Brakes are worse than before, but I hope to be off tomorrow night, and can single man bleed using 1A-Auto method. Last time I allow that help to help. Sidelined.
    Good note, truck fired right up like old times without throwing some hokey multiple cylinder misfire. Think it was jealous.
    bmf4069, alee891, Filthyphil and 3 others like this.
  19. Jun 12, 2021 at 10:15 AM
    Professional Hand Model
    Hand Protectors
    A new brake Debacle builds... :rofl:
    CodyP likes this.
  20. Jun 12, 2021 at 11:37 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I need to change my rear diff fluid this week, need to order two new crush washers first. The rear has the LSD sticker on the pumpkin been reading I should use 75W-90.
    was going to go with royal purple but ready negative reviews on other threads, then was going to run the Valvoline because read positive review (it also come in a bag for easy fill).
    The more I read, it looks like Lucas is the way to go. I’m lost and just need a push in the right direction.
    Truck has 166k and it’s probably never been changed. Price doesn’t matter just want the right/best.
    hammeron and CodyP like this.
  21. Jun 12, 2021 at 11:50 AM
    Hand Protectors
    Two things I have done:
    1) Reused Crush Warsher.
    2) Used Dino Lucas 80w-90 (non-syn) in the Rear. (3.1 Quarts on 2002 with LSD 4wd).
    Success with both.
  22. Jun 12, 2021 at 2:07 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Motul 90pa, correct 90 weight and proper amount of friction modifier already in the additive package. 2 jugs needed for the 3+ qts the rear diff needs, each bottle is 2L.
    I've only had to replace the crush washers once on a diff out of a late 70's Toyota, that had been clearly mushroomed out by over tightening.
  23. Jun 12, 2021 at 2:59 PM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Before and after pics
    Today I slapped on some aftermarket fender flares from eBay that fit pretty nicely. Had them painted by the local auto body shop for a pretty penny. Would’ve done it myself but I suck at Painting.
    Last week I installed rancho 2.5 Quicklift coilovers and a 1.5 - 2 inch aal kit. New rough country shocks in back as well. Aal really makes the ride enjoyable.
    Might put on one of the better uca brands later down the road.
    oscardog86, chrisb, bmf4069 and 10 others like this.
  24. Jun 12, 2021 at 6:48 PM
    Voss
    2003 AC TRD 4x4
    Headers came finally.
    @Professional Hand Model, I remember reading you used different gaskets on your install. What type of gaskets were they?
  25. Jun 13, 2021 at 5:52 AM
    Hand Protectors
    You can refer back to my build page for part#/pics, but for the Manifold (Percy/Taylor Cable Seal4Good) and for the collectors (Remflex DIY Sheet) cut using the JBA Gasket as Template.
    All Toyota New Studs/Nuts at Manifold and the provided JBA Bolts at collectors with Toyota Nuts.
    You live in Coolifornia so your job should go double fast and if needed you can hire a garage for half price compared to the Island. :rofl:
  26. Jun 13, 2021 at 8:46 AM
    Voss
    2003 AC TRD 4x4
    Thank you sir
  27. Jun 13, 2021 at 1:59 PM
    empty_lord
    05 rollover special
    Organized some of my ratchet straps and got the big ones and the choker straps into one tote with a come along and a moving blanket. Now I just need another tote for the smaller straps and I’ve got 7’ bed space left.. with easy removal of the totes for the full 8’ or the bed extended for more
  28. Jun 13, 2021 at 3:08 PM
    NWPirate
    Zach
    WA
    Haven't had a 8' bed since selling my Cummins in 06, miss that extra space.
  29. Jun 13, 2021 at 3:37 PM
    empty_lord
    05 rollover special
    It’s nice. But the lack of interior space is annoying to an extent. Cap helps with that too though
  30. Jun 13, 2021 at 4:22 PM
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    Nice job! Got some questions: what material are you using for the inner panel (the darker (black?) part of yours) and what did you use to adhere it to the plastic? Did you do anything special to fit it around the bulges and curves, or does the material you use just stretch as needed?
    I'm in the middle of the same job. I was afraid to do it to mine, so I got a panel from a scrap yard. Took forever to get the old fabric off, only to discover some cracks in the plastic. It's ABS, so I'm going to try the "dissolve scrap ABS in acetone and patch it" method to repair and re-inforce the cracks... but now that it's hotter than hell out here, that whole project is on the back burner for awhile.
    https://www.tundras.com/threads/interior-door-panel-re-carpeting.88361/
