  1. May 6, 2021 at 12:14 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    its normal to have a lake under the truck depending on the weather.. nothing to worry about.
  2. May 6, 2021 at 3:00 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  3. May 6, 2021 at 3:44 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    20210506_053614.jpg 20210506_053809.jpg 20210506_053927.jpg 20210506_054013.jpg
    Lumber prices got me bouta act a damn foo'.
    :quickdraw:
    NUDRAT, Filthyphil, Darkness and 4 others like this.
  4. May 6, 2021 at 4:33 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You need a crew and some black, lowered honda civics. And to live your life a quarter mile at a time.
  5. May 6, 2021 at 4:34 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That's my neighbors house in the background. My truck is backed up to my garage in the pic. You can't see it. Some LLC just bought that house and is going to flip it I assume. Mine does have a metal pan on top of the chimney that needs to be replaced though. It's on my list.
    NUDRAT[QUOTED] and abcinv like this.
  6. May 6, 2021 at 4:40 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    That looks like proper usa hardwood.
    Tundra2[QUOTED] likes this.
  7. May 6, 2021 at 4:44 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    What's at the other end of the chimney? Will you heat with wood?
  8. May 6, 2021 at 4:45 AM
    Professional Hand Model
    Hand Protectors
    Couple of Observations on my 2002 Tundra 4.7L:
    1) My 6 month new(er) OEM Fan Clutch is working very nicely in this warmer weather. I can feel and hear the volume changes in Air Pull compared to the worn out oldie.
    2) My Thermostatic Trans Oil Valve is holding nicely. Was pretty hot to the touch the other day in hot weather. I could feel the upper hose leading to the air cooler was hot as well (meaning its allowing ‘bypass’ as designed). My Aluminum Bracket was warm as well. Haven’t monitored any temps in a long time with the gauges so no idea in terms of actual numbers.
    NUDRAT, MS22, theblurry1 and 2 others like this.
  9. May 6, 2021 at 4:47 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No it's a gas chimney we'll never use.
    Here is the pic the inspector saw. I thought about trying to paint it with some rust converter but figured that might be a lazy approach. I don't want it to stain the new-ish hardie board.
    NUDRAT and Darkness like this.
  10. May 6, 2021 at 5:33 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I have ordered aluminum from airparts out of kc. That would be a permanent solution.
    We had a similar gas chimney in an old house. Are you guys staying in this house for a while or moving in 2 years?
  11. May 6, 2021 at 7:30 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Normal for me here on the east coast.
    NUDRAT and jerryallday[QUOTED] like this.
  12. May 6, 2021 at 7:42 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    If you live in a green state expect a puddle. If you live in the brown states grab some chapstick.
  13. May 6, 2021 at 8:36 AM
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    As others have said, yeah, it's normal - I even have it in one of the brownest sections possible in the US - and in fact you should worry if you didn't, as apparently the drain tube can get clogged, which could result in various issues in the cab.
    I found this out because I get a funky musty smell from my AC when I first turn it on, even here in bone dry Phoenix, and learned about the drain tube then. I made sure mine was clear, and I've taken everything apart, blasted water at the fins, brushed the green / brown gunk off. It lasted...I dunno a couple of weeks? Can't figure out why it keeps coming back.
    Funny @onesojourner mentioned chapstick. Just saw this at a Woodworker's Source, figured I'd give it a try for my cold-weather trips to the high and dry parts of Utah.
    (Made the mistake of looking excited about the cash-register impulse buy before finding out the price....$4 for a small tube (it's even thinner than most chapsticks), but being a Real Manly Man I couldn't put it back at that point, could I?)
  14. May 6, 2021 at 8:41 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I assume we're going to be in this house a while.
    NUDRAT and FrenchToasty like this.
  15. May 6, 2021 at 10:31 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    We had a really bad ice storm several years ago. We had gas heat at the time but I knew a lot of people who were without power and heat for 2 weeks. I had a gas log at the time. It was for looks only, it did not provide any heat. I ran a stainless steel insulated liner and installed a nice little cast iron jotul stove. We built a new house and took the stove. It has paid for itself many times at this point. I like knowing that I can keep my family warm. It's worth considering if you do need to do some work to that chimney.
    oscardog86 likes this.
  16. May 6, 2021 at 12:28 PM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Crossposted from my “build” thread. Thanks to all who’ve posted and weighed in on this. I was finally able to get my steering wheel audio controls wired up. I used a Lexus GX470 airbag w/ cover with audio switches and a Metra Axxess ASWC-01 box.
    Before and after:
    My 2005 Double Cab is an SR5/XSP and didn't have the audio controls nor did it have the wiring at the clock spring (only 3 wires coming out).
    I also have only a 12 pin harness at the back of my stereo, rather than the 20 pin as most others have.
    To make things easier, I snagged a clock spring harness with the 7 wires coming out of it from an 04 Sequoia in a pick n pull rather than re-pinning my existing clock spring plug.
    Here's the pinout for the plug coming OUT of the clock spring. The colors may vary, but the pin position seems to be correct across many models.
    Cut and soldered my original three wires from the 10, 11, 12 positions onto the new donor pigtail.
    From the factory, I had wires in positions 10, 11, 12 which are for the cruise control and horn. I added wires to 4, 5, 6, 7 positions and used a Metra Axxess ASWC-01 box.
    To use an aftermarket stereo, wire *from the clock spring* as follows:
    pin 4 - connect to Metra black wire AND ground
    pin 5 - connect to Metra green/orange wire
    pin 6 - connect to Metra black/green wire
    pin 7 - 12v+ switched with taillights to illuminate steering wheel switches at night
    Metra ASWC-01 red wire to switched 12v+
    Metra ASWC-01 3.5" mini jack plugs into aftermarket stereo remote control input
    Works perfectly!
    https://youtu.be/mCsFiYG9V2w
    Thanks to many but especially to @MrDirtjumper for his help here and @BubbaW for the help here.
    B6Tundra, standard, NUDRAT and 10 others like this.
  17. May 6, 2021 at 2:25 PM
    Hand Protectors
  18. May 6, 2021 at 3:35 PM
    Jack McCarthy
    Bill
    North of Boston
    I love the warm weather. No exhaust manifold leak sounds. Am now preying it will stay that way up till September at the next vehicle inspection. Changing the manifold out will not be an option till I fix the holes in the bottom of the frame where the front jack points lie.
    I miss the days I could give a friend $15 and he could come by with an inspection sticker for me at the end of the day. :(
  19. May 6, 2021 at 5:37 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Got my exhaust tip in today and it’s bigger than I thought it would be. The clamp will only work if the end of the tip is on the ‘bulbous’ end of the exhaust. Not crazy about how this looks and may need to take it to an exhaust shop and have them weld it up.
  20. May 6, 2021 at 5:43 PM
    Hand Protectors
    Maybe Shpray Paint the rest of the pipe under the truck with Flat Black Ceramic BBQ paint to highlight the shiny new tip. It would compliment and highlight your new addition.
  21. May 6, 2021 at 8:53 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Got my new foglights today and started mocking up the mounts.
    NUDRAT, KarmaKannon, Darkness and 3 others like this.
  22. May 7, 2021 at 6:02 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Got my new door latch. Everything looks the same as the original one as far as I can tell. Also got some of the door check reinforcements from the IG dude. $45 shipped for DCs. My driver's door check is getting lazy so I might try the @RUSTYNUTS fix.
    BubbaW, Darkness, bmf4069 and 2 others like this.
  23. May 7, 2021 at 7:40 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    What latch did you end up going with and price?
  24. May 7, 2021 at 7:45 AM
    des2mtn
    SW
    Tonto cover
  25. May 7, 2021 at 7:53 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Please, please please, please post up a tutorial! I'd love to do this!
  26. May 7, 2021 at 9:43 AM
    daveeasa
    David
    Why does nobody make a pod adapter for those ovals? Minimal demand? It seems like such an easy part to injection mold.
    NUDRAT likes this.
  27. May 7, 2021 at 11:40 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I think they'd be relatively easy to replicate with a 3D printer.
    CodyP likes this.
  28. May 7, 2021 at 11:45 AM
    daveeasa
    David
    Yes, that would certainly work, but with the sales figures and how reliable they are, seems like there is more than enough of a market to justify a generic injection molded plastic snap-in part to convert from oval to round pod style matching modern Tacoma/Tundra.
    NUDRAT and Glock 40[QUOTED] like this.
  29. May 7, 2021 at 1:05 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So we were talking about reinforcement for the door thingy? I might need one.
    NUDRAT, CodyP, FrenchToasty and 6 others like this.
  30. May 7, 2021 at 3:57 PM
    Hand Protectors
    Whoa! Maybe we do need these for PM? Yours look Fubar’d though.
    bmf4069[QUOTED] and des2mtn like this.
