  1. Apr 8, 2021 at 9:25 AM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    OK, so Ive finally had some time to get the steering wheels swapped and switches installed. As mentioned above, the steering wheel audio switches plugged right into the clock spring behind the airbag. Now coming out of the clock spring and heading toward the stereo, it appears I only have 3 of the 12 pins pre-installed. I looked behind the stereo and couldn't find any unused plugs either. So I'm guessing if I add wires to the missing pin locations at the clock spring (with these terminals identified from the TW thread), then run them out to the back of the radio via an aftermarket adapter, I should be good to go. I just need to determine which pins are used for the audio switches. Does that seem reasonable/correct to you guys? Does anyone with factory audio controls in a DC have a picture of the wires coming out of the clockspring?? Thanks for any insight!
    really crude wire id for my truck:
    Looking at the harness coming out of the clock spring (this is what I'd like to see a pic of in someone's truck with factory left side audio controls and black right side controls):
    Behind my stereo:
    New airbag and controls awaiting Loncky wrap:
  2. Apr 8, 2021 at 12:28 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I can check my parts truck this afternoon and hopefully clear this all up.
    912[QUOTED] likes this.
  3. Apr 8, 2021 at 2:52 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    See if you can find out what year @912 is while you are looking :cool:
  4. Apr 8, 2021 at 3:42 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Ok so here is the clock spring harness. Top row Colors from L-R are: Gray/Red, Brn/Wht, Grn/Red
    20 pin radio harness. Top of the radio is the back line of wires. You should only be concerned with the row closest to me and only the 3 leftmost wires. Colors L-R are: Gray/Red, Grn/Red, Brn/Wht
    NUDRAT, 912[QUOTED] and daveeasa like this.
  5. Apr 8, 2021 at 4:01 PM
    daveeasa
    I think Toyota has used 090IIU pins for ages for the stereo and I have a bunch, @912 if you want jumpers which will snap right in to the connector I should be able to hook you up. Not sure if they are the same pin on the other side but a close up picture or two would tell us.
    912 likes this.
  6. Apr 8, 2021 at 4:14 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I also just verified with my DMM that the lonely wire in the bottom left corner of the clock spring harness is the illumination wire for the lights. It shows 12v when park lights are turned on and rests open. I would just run a jumper over from the light stalk while you have the cover off.
    Thanks for reminding me about all this while I have still have this parts truck.
    912[QUOTED] and onesojourner like this.
  7. Apr 8, 2021 at 4:35 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    2005 NAV/Audio if it helps !
    912, daveeasa and speedtre like this.
  8. Apr 8, 2021 at 9:25 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    The Lexus wheel is actually super sweet.
  9. Apr 9, 2021 at 3:41 AM
    912
    2005 DC 4x4
    This is SUPER helpful, thank you!!
    That would be fantastic, I'll PM you with some pics next time I'm able to get to this again. Thanks!
    I think this should be all the info I need to make this happen. You guys kick ass, thanks again!
  10. Apr 9, 2021 at 4:52 AM
    Chad01Tundy
    Chad01Tundy New Member
    Will do!
    JustJake[QUOTED] likes this.
  11. Apr 9, 2021 at 2:54 PM
    Mitch09
    Mitch09 New Member
    NC
    2022 SR5 TRD Off-road
    Threw on these Rock Warrior wheels I’ve had sitting in the garage for too long.
  12. Apr 9, 2021 at 3:02 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I really like that color.
    Lil Steve and NUDRAT like this.
  13. Apr 9, 2021 at 3:05 PM
    Mitch09
    Mitch09 New Member
    NC
    Thanks! You don’t see it very often. It’s similar to the 05-06 blue color.
    KarmaKannon likes this.
  14. Apr 9, 2021 at 3:06 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Nice looker....got any comments about the windshield tint strip....work pretty good ?
  15. Apr 9, 2021 at 3:08 PM
    Mitch09
    Mitch09 New Member
    NC
    thanks man. Yeah it’s 5% to near the bottom of the rear view mirror. Does help with sun for sure
    KarmaKannon and BubbaW[QUOTED] like this.
  16. Apr 9, 2021 at 10:07 PM
    speedtre
    speedtre New Member
    Inland Northwest
    It's better than the blue steel metallic of the 05-06 IMHO...and I have an 06. I believe the 04 blue is called blue marlin pearl.
    Mitch09[QUOTED] likes this.
  17. Apr 9, 2021 at 10:39 PM
    My favorite is still the green color they only offered in 05-06 called Timberland Mica. There is a guy that mows lawns around here that has that color and uses it as a work truck. Looks sharp.
    Filthyphil, Mitch09, Darkness and 6 others like this.
  18. Apr 9, 2021 at 10:40 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Nothing will ever beat imperial jade mica (color code 6q7)
    Kimosabe, Voss and FrenchToasty like this.
  19. Apr 10, 2021 at 6:22 AM
    Pearl-snap
    Pearl-snap New Member
    I second that.
    empty_lord[QUOTED] likes this.
  20. Apr 10, 2021 at 6:59 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I like it, but I really love the chili pepper red myself. Very tempted to paint my truck red one day.
    NUDRAT likes this.
  21. Apr 10, 2021 at 7:12 AM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Oh, I love the chili peppers...kick ass band
    Darkness likes this.
  22. Apr 10, 2021 at 7:47 AM
    KarmaKannon
    Utah
    Some junk
    Salsa red
    55OKZm3C6JLlIHqcOkc2ygH7oRcWlCWi7HWxNOrD_a7d69d1ecc074594ca9c4beea0c67c9aa682e50f.jpg
    Voss, RustyShackle323, BubbaW and 3 others like this.
  23. Apr 10, 2021 at 7:49 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Added brand new Armorall steering wheel cover purchased at a salvage shop in penis-cola.
    Steering wheel is cracking at seam between 11-1 o'clock positions. $7 cover cheaper than New wheel.
    Voss and NUDRAT like this.
  24. Apr 10, 2021 at 7:59 AM
    KarmaKannon
    Utah
    Some junk
    The chinese take leather steering wheel wraps are pretty nice for the money. I think mine was under $50. Took some time and patience to do though. Still looks nice even though I could have done a much better job with the wheel removed.
    Voss and KNABORES like this.
  25. Apr 10, 2021 at 8:01 AM
    Roborob70
    Robert
    Looks good, but the red strip is annoying, but i know that you like it, and that is all that matters.
    Tundra2 likes this.
  26. Apr 10, 2021 at 8:02 AM
    Roborob70
    Robert
    Yeah, just trying to figure that one out....46,000 truck and we will put on a urethane wheel....WTF????
  27. Apr 10, 2021 at 9:29 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Installed blueteef adapter which appears to work wonderfully so far. Special thanks to @jimf909 for bringing this to my attention. :hattip:
    This is a quote from his thread. It lists another adapter for the 6×6 plug.
    Tested it out with bohemian rhapsody, and some fiddy cent
    Lil Steve and jimf909[QUOTED] like this.
  28. Apr 10, 2021 at 9:36 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Are those actual leather? I wonder is you can wet them to get them to shrink tighter now that it is stitched.
    NUDRAT likes this.
  29. Apr 10, 2021 at 10:05 AM
    KarmaKannon
    Utah
    Some junk
    They offer fake and real last I checked. I regret not getting real, but the fitment is in me. It would fit tight if I had done it off the truck. Just hard to see/get into the back/bottom of the spokes with the wheel still on the truck.
    NUDRAT likes this.
  30. Apr 10, 2021 at 11:44 AM
    Got a link? I need to do this.
