  1. Mar 8, 2020 at 3:46 PM
    speedtre
    speedtre New Member
    Inland Northwest
  2. Mar 8, 2020 at 3:51 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That's cool. What's the normal range for vacuum?
  3. Mar 8, 2020 at 3:56 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  4. Mar 8, 2020 at 4:01 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Temp gauge appears to be set for Centigrade which would make it 190 F ?
    because_wumbo-truck likes this.
  5. Mar 8, 2020 at 4:03 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Good catch, that usually what our 4runner is at, pretty close to the coolant temp usually
    BubbaW[QUOTED] likes this.
  6. Mar 8, 2020 at 4:07 PM
    empty_lord
    05 rollover special
    Mine seems to be in good ol Merida measurements.
    Well according to my scan tool vs the scan gauge
  7. Mar 8, 2020 at 4:39 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I ran mine pretty hard and o don't think I saw over 145.
  8. Mar 8, 2020 at 4:45 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I've seen mine hit 190 on a hot day, at a red light. But normally it's a lot lower.
  9. Mar 8, 2020 at 5:03 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I'm pretty sure mine hit 205ish pulling a TT last summer up some grades.
    Tohopko likes this.
  10. Mar 8, 2020 at 5:46 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Haven't driven it yet....will let you know tomorrow...:thumbsup:
    empty_lord[QUOTED] likes this.
  11. Mar 8, 2020 at 5:49 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Nope, set to F...coolant is on C though..
  12. Mar 8, 2020 at 6:04 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Oh, ok....coolant and temp to me are the same but that's just me and ~190 F matches my coolant Temp !
  13. Mar 8, 2020 at 7:25 PM
    Whothefat
    Whothefat New Member
    Clark
    Las Vegas
    2006 Black Tundra DC 4x4
    I stripped mine too, had to get a 3/4 inch nut welded on there to get it off.
    Some recommendations i got was to try a torx bit in there too but mine wouldn’t budge.
  14. Mar 8, 2020 at 7:38 PM
    empty_lord
    05 rollover special
    There’s a Lexus part you ca buy off the front diffs of a 2012 is350. It has a hex head and fits our front diffs
  15. Mar 8, 2020 at 7:39 PM
    empty_lord
    05 rollover special
  16. Mar 8, 2020 at 7:41 PM
    KarmaKannon
    Utah
    Some junk
    How did you check it? I think my measurement is at the pan because it is very constant from what I recall.
  17. Mar 8, 2020 at 7:41 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    finally got on the LED bandwagon.
    My cargo lights have never worked since I got the truck. Finally got a Round Tuit & bought some new bulbs. Went LED as the original bulbs had scorched the housing, hoping LED is cooler enough to close that issue.
    One bulb worked, one didn't - but then I remembered some learning I did here & rotated the non working & viola - fixed!
    Good thing I got one right or I would have been chasing fuses & …. bullet dodged. :)
  18. Mar 8, 2020 at 7:52 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I'm going to start my HID retrofit. For those who have done it, can I align the lights while they are sitting on the bench, or do they need to be installed in the truck?
  19. Mar 8, 2020 at 8:12 PM
    FrenchToasty
    Mo
    Bone stock
    You can align them on the bench/jig, as long as you mark your level and steps on the wall with the old bulbs. It’s then opening them and getting them back on the jig exactly the same that can be tough or throw your alignment off
  20. Mar 8, 2020 at 8:41 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Started removing the front suspension to make room for the frame repairs.. Every bolt has been fighting me the whole way.
  21. Mar 8, 2020 at 9:16 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    With The torque app. I believe it’s the pan temp? But I’m not sure. Now that I have the information for both I’m going to delete the gauge I have and load the two new ones and see about it. I could be remembering it wrong as well since it was last summer.
    NUDRAT and KarmaKannon[QUOTED] like this.
  22. Mar 9, 2020 at 4:14 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Both Pan and Torque Converter Outlet temps are available...Torque with GPS on this HU with GPS is addictive....so many settings to play with. No need for speedo correction when I have GPS speed front and center...:)
    Two different Trans temps are bottom center immediately parking after my 8 mile city drive to the gym at 6AM, i.e. no traffic
    Here's the PID's:
    For sensor 1 (Pan Temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 1
    Short Name:
    TFT 1
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    °F (there is a degree symbol in Torque)
    Equation:
    ((((E*256)+F) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
    For sensor 2 (Converter outlet temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 2
    Short Name:
    TFT 2
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    Equation:
    ((((G*256)+H) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
  23. Mar 9, 2020 at 4:20 AM
    Professional Hand Model
    Hand Protectors
    Nice set up. Anyway you can double confirm your temps using another device like a laser? For validity purposes.
  24. Mar 9, 2020 at 4:39 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Not at the moment....
  25. Mar 9, 2020 at 4:58 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I made it much easier to work out of my 2002 SR5 by installing a high wedge ARE cap.
  26. Mar 9, 2020 at 5:43 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    roll out floor & you're living the high life. Nice.
    Rex Kramer[QUOTED] likes this.
  27. Mar 9, 2020 at 5:44 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If you remind me, I can check my pan temp and compare that to my Torque Pro app to see how accurate it is.
  28. Mar 9, 2020 at 5:47 AM
    FrenchToasty
    Mo
    Bone stock
    I’m sure emptylord will be able to compare his with one of the fancy scanners he uses.
    Also; I hate laser temp guns with a passion. Our light bulb changers use them to check air temps coming out of registers/fan coils. They are extremely inaccurate for air temp readings and questionable for surface readings
  29. Mar 9, 2020 at 5:50 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    What I'll add and you may know this but the face of the headlight assembly has a indented dimple about size of BB. It represents the center point of our halogen bulbs. That needs to be your reference when positioning the center of projector. Also, the projector needs to be perpendicular to ground but should be able to adjust after temporary install. I'm sure those that have installed possibly understand what I just said ?
    Doing as good as one can, it's a an easy thing to get off just a tad. Mine below needed to be adjusted just a smidge on passengers side but was easy peasy after the fac
    t.
  30. Mar 9, 2020 at 8:23 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    That's a beautiful shell. How much did you get 'er for?
