2005 Tundra ATF Change; OBD2 port Pin #s
Discussion in '1st Gen Tundras (2000-2006)' started by Limnetic, Jul 28, 2019.
  1. Jul 28, 2019 at 10:57 AM
    Limnetic
    Limnetic [OP] New Member
    2005 Tundra SR5
    I'm planning to perform a ATF drain & fill on a 2005 tundra SR5 (V6). I've read a # of posts and articles covering this procedure on Toyota vehicles that do not have dipsticks, and lacking a dipstick, the correct fluid level is established by an overflow plug. Also, the fluid temperature must be in the 115 - 130 degree F range to accurately check the level.
    Lacking a scan tool to measure the fluid temperature, I had planned to use the trucks OBD2 system, employing a piece of copper wire, to "jump' the connector, as discussed in a number of posts. However, unless I'm mistaken, it appears to be that the OBD2 port on this vehicle has only 1 row of 8 PINS (located above the gas pedal), in contrast to the 16 PIN configuration that has been cited in several posts.
    Am I mistaken about this 8 PIN configuration? Or is there a jumper method for this 8 PIN configuration that allows one to be alerted when the correct temperature range is reached for checking the fluid level via the overflow plug?
    Thanks in advance for any assistance in addressing this issue!!
  2. Jul 28, 2019 at 11:23 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I can't offer any assistance on the pin, but my unsolicited advice is to buy a $40 infrared thermometer, scan the pan until the temp shows in the proper range, then proceed with drain and fill operations. The pan is sheet metal which is very thermo conductive. Several youtube videos have shown the infrared thermometer temp to be within 5 degrees of the fluid temp. Good luck.
    bmf4069 and speedtre like this.
  3. Jul 28, 2019 at 11:33 AM
    As long as you measure what comes out and put that exact amount back in, you can probably avoid all the headache you're describing. Don't over think it.
  4. Jul 28, 2019 at 11:59 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I suspect the 8 pin connector you've found is not the OBD2 port. For your model Tundra, look for the OBD2 port on the left side of the steering column, lower left side of the dash.
    speedtre and Aerindel like this.
  5. Jul 28, 2019 at 3:29 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    If you have a smart (dumb) phone and are willing to spend about $30 you can measure the trans temp whenever you please. I picked up a Bluetooth obd2 adapter for about $25 on Amazon and paid for the app called "torque pro". If you plug in a custom pid you can get the trans temp to feed right to your phone real time. It was half as hard as it sounds. I would offer one piece of advice though. Disable all the gps crap on torque so your data usage doesn't shoot way up in a hurry. Unless you have unlimited I suppose.
    Here is where I found the pid for the trans temp. I believe them to be correct although I cannot verify.
    speedtre likes this.
  6. Jul 29, 2019 at 2:06 PM
    growit
    growit New Member
    2006 Dbcb SR5
    Why not just take it to the dealership and have a total flush and refill done, It cost me about $260. It only needs to be serviced like that every 100k miles.
    That's the only thing I have the dealership do, its to painful to have them do anything else.
  7. Aug 6, 2019 at 3:28 PM
    notlame
    notlame New Member
    jkeith72 and KarmaKannon like this.
  8. Aug 12, 2019 at 5:59 AM
    jkeith72
    jkeith72 New Member
    2005 Tundra SR5 4X2 Double Cab Phantom Gray
    Excellent video, I did mine this weekend.
    I did a load of research on fluid too, regarding the Toyota WS and Valvoline Maxlife. The previous owner used the Maxlife in my truck for the last 5 years without any issues. Toyota says from 2004 you need to use their WS. From what I saw, the WS was created out of environmental concerns and the Valvoline Maxlife ATF is still safe to use...
  9. Aug 12, 2019 at 7:21 AM
    Any indications if Maxlife is safe to use in my 02? I've been using it without issue but I've read conflicting things.
  10. Aug 12, 2019 at 7:46 AM
    notlame
    notlame New Member
    Can't recall if I used Toyota brand or Red Line. Regardless, everything seems fine about 10k miles later.
  11. Aug 12, 2019 at 7:57 AM
    jkeith72
    jkeith72 New Member
    I believe that is the correct fluid from 2000-2003 with the 4.7L engine at least. In 2004 and newer Toyota says ATF WS (World Standard).
  12. Aug 12, 2019 at 11:31 PM
    akhero
    akhero New Member
    2005 Toyota Tundra
    I will pay the $250 at the dealer save the headache!
    jkeith72 likes this.
  13. Aug 13, 2019 at 7:07 AM
    jkeith72
    jkeith72 New Member
    I agree with a flush....but a drain and fill is super simple and takes about an hour total for about $25. I plan on doing it once a year, that should keep the fluid fresh.
    Tamarack likes this.
  14. Aug 13, 2019 at 8:41 AM
    My Toyota dealership won't even do a flush anymore. It has created too many problems for people. If you do a series of drain+fills it should get you pretty close to a flush without the cost and the risk. There really isn't any reason to pay $250 for this. Doing a drain+fill is easier than an oil change as you don't even have to remove the skid plate.
  15. Apr 25, 2025 at 5:50 PM
    Tamarack
    Tamarack New Member
    2005 Tundra 4.7 TRD AC (Green)
    Unmodified
    Stearlership quoted me $475 for drain and fill in 2025. Going to be doing it myself lol (insert “opens empty wallet dot gif”)
  16. Apr 25, 2025 at 6:17 PM
    Find a BG certified place. Have them do the BG transmission service. It'll cost less and put your transmission under warranty for (I think?) 12 months.
