  1. Apr 20, 2024 at 7:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Today I adjusted my headlights for the hundredth time. Buying cheap projectors and housings is one of my biggest regrets. The output is dog shit and every time I drive on a gravel road more than a few minutes they come completely out of adjustment. I can barely touch the housing and the whole thing jiggles. At night I often have to use my yellow Baja fog lights for additional support. I feel bad blinding people so I have them aimed really low.
    Also, the driver side headlight only comes on 50% of the time. I have to flip them on multiple times to get it to work.
    Let this be a lesson.
    Here is what they look like after my Arkansas trip.
    After adjustment:
    Here is me touching the housing.
    https://youtu.be/peRgdEAzu7U?si=Q8dam355AhLXxel4
    bmf4069, BroHon and Voss like this.
  2. Apr 20, 2024 at 7:47 AM
    shifty` Inside his chest they found ten thousand pencils
    Dave Matthews does not approve, and Tim Reynolds is looking at you crossly.
    Are these the projectors you bought pre-made?
    Jack McCarthy likes this.
  3. Apr 20, 2024 at 8:07 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Nice! Did you make that bracket yourself?
    FrenchToasty likes this.
  4. Apr 20, 2024 at 8:21 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes. And initially the output was so bad I couldn't see at night. Literally couldn't safely drive without the yellow fogs. So I bought some much better bulbs and ballasts. That helped some but they still aren't good. The ballasts are made by Hylux. I suspect the driver side ballast has an issue which is why they only turn on half the time.
  5. Apr 20, 2024 at 8:26 AM
    Voss
    2003 AC TRD 4x4
    Is this to eliminate a rattle?
  6. Apr 20, 2024 at 8:29 AM
    Voss
    2003 AC TRD 4x4
  7. Apr 20, 2024 at 8:31 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Mine does that every day warming up in the winter. Power steering pump bearings are the issue with mine. It’s fine in the warm weather.
    Voss likes this.
  8. Apr 20, 2024 at 8:34 AM
    Voss
    2003 AC TRD 4x4
    Nice
  9. Apr 20, 2024 at 8:41 AM
    Voss
    2003 AC TRD 4x4
    May I suggest raising the spare tire mount 68EB862B-2187-4F46-9DB0-2EA14D1797F4.jpg
    ignore the Orange. That didn’t happen
  10. Apr 20, 2024 at 8:43 AM
    Voss
    2003 AC TRD 4x4
    khooiii[QUOTED] likes this.
  11. Apr 20, 2024 at 8:44 AM
    Jack McCarthy
    Bill
    North of Boston
    Are you riding bedless for that. Pretty cool.
    Voss[QUOTED] likes this.
  12. Apr 20, 2024 at 8:53 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Yes. I mainly had a rattle at the access door at the top. It’s now gone. The front doors close tighter now too
    JasonC. and Voss[QUOTED] like this.
  13. Apr 20, 2024 at 9:03 AM
    Voss
    2003 AC TRD 4x4
    No just lifted the spare higher for more clearance. 43116A24-049A-4DF0-BFD6-D8E4CBD11250.jpg
  14. Apr 20, 2024 at 9:05 AM
    Voss
    2003 AC TRD 4x4
    Gonna try this. Get a sporadic rattle on passenger side I’ve never been able to locate.
  15. Apr 20, 2024 at 9:43 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    It only takes about 3 wraps with the tape. Any more and the latch will get stuck on the tape around the striker and cause the door to be difficult to open
  16. Apr 20, 2024 at 9:52 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I blame all my rattles on my fire extinguisher. Even the ones from the dash.
    bmf4069, FrenchToasty and Voss like this.
  17. Apr 20, 2024 at 11:13 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Perhaps bake em and pop the lenses off and fix em?
  18. Apr 20, 2024 at 11:22 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    How are the projectors mounted? Screwed to the reflector bowl or is it a threaded shaft mount? If threaded maybe you just need to tighten the shaft nut. If they are bolted to the bowl, the nuts may be coming loose in which case it would require baking them apart and separating the bowl from the backplate to tighten the nuts on the mounting bolts and JB weld over them so they don't loosen again.
    Which projectors did they install for you?
    455h0le_dachshund likes this.
  19. Apr 20, 2024 at 11:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I don't think that's the issue or even worth trying.
  20. Apr 20, 2024 at 12:19 PM
    Finally got tired of the musty smell in the bed. Brushed, vacuumed, foamed and scrubbed, then wiped clean, before vacuuming again.
    Hopefully this helps. If not, I finally bought an ozone machine this week and I’ll slap that back there. My smeller doesn’t want to work anymore after doing all this so I can tell if it helped.
    I think I’m about to Seafoam-spray the intake and 303 the interior. Got a fan inside the cab to air it out. The stuff I used apparently has a penchant for smelling like astringent cucumber if you don’t let it fully air out. It sure as hell worked though.
    Pnwtundy, bmf4069, 805Tundra and 5 others like this.
  21. Apr 20, 2024 at 12:49 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Math from fill ups at same station/pump. I also check actual mpg with the torque app while driving but hand calculate as it is more accurate.
    Mine is an 05, so VVTi, 5 speed trans and uses wheel speed sensors, so dash is accurate still.
    That was hand calculated over 225mi trip to SF and back at 10.9gal, late at night so no traffic and doing 60mph. It was both ways so not just downhill. BUT it was at a very boring 60mph on cruise control.
    225/10.9=20.6mpg @60mph
    249/13.1=19.0mpg @65mph
    I have some older cooper tires that need replacement soonish, so less rolling resistance. Stock 265's on stock wheels. 2wd not lowered (yet).
    Mods: 4.10 gears w/lsd, tonneau cover, AFE washable dry air filter and a TRD velocity stack in my fender to airbox (meant for a 4.0.4runner/tacoma).
    Otherwise stock motor with new radiator (koyo) and denso fan clutch. 175-180k miles on the motor that trip.
    Gears was the biggest difference. The tonneau alone was .5mpg gain in town and 1mpg on the freeway iirc.
    When I get some time, I have a set of 12-hole injectors to install. I wonder if I'll see anything additional.
  22. Apr 20, 2024 at 12:58 PM
    Maybe it was a dumb idea to top-end clean and TB clean right after cleaning the cap carpet….
  23. Apr 20, 2024 at 1:08 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    You need to order new plastic bits the straw is running in between before they're unobtanium.
    They've got the early signs of the brittles.
    shifty`[QUOTED] likes this.
  24. Apr 20, 2024 at 1:23 PM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    I drove it! I have a knack for buying high mileage Toyotas, throwing a few parts at them, then expect them to perform flawlessly on an aggressive drive through Colorado. I have yet to be disappointed. The Tundra did perfect powering through the Rockies! Unexpected snow and all. Sitting at about 278k miles.
  25. Apr 20, 2024 at 1:37 PM
    @NUDRAT ehicb parts specifically?
    Maybe I need to 303 it. I just 303’d the interior plastics.
  26. Apr 20, 2024 at 1:40 PM
    Jack McCarthy
    Bill
    North of Boston
    So what sort of thin enough and strong/rigid enough item have people here used to pop their overhead map lights off without mangling the plastic around it? :confused:
  27. Apr 20, 2024 at 1:57 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You don't think that would give you the needed access to tighten em for good? I do.
    I know on mine I loosened one side to adjust the cutoff and now it's not as tight as it should be. The only way I can see fixing it is to remove the lense so I can use one hand to put pressure on the projector, while the other hand tightens the nut on the backside.
    Edit: unless you meant adjusting the housing
  28. Apr 20, 2024 at 2:01 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Haven't gone after the map lights yet, but but would something like this work? Got a set for like $5 IIRC when on sale.
  29. Apr 20, 2024 at 2:03 PM
    ToyotaDude
    ToyotaDude Member
    Ordered $1260.20 of parts at retail for $664.78 during 25% off online pricing with free shipping. OEM at 47% off = good.
  30. Apr 20, 2024 at 2:04 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    Is 303 different/better/worse than Armor All-type products? I kind of hate Armor All and haven’t bothered to try anything other than baby wipes, haha.
    G_unit3000 likes this.
