  1. Mar 20, 2024 at 6:37 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    OMG that reminds me of this...
    https://www.instagram.com/reel/C1XG90Vuk9c/?igsh=dmJmdW9mNzZ4a25r
  2. Mar 20, 2024 at 6:39 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :eek2: that's my fear realized. That's probably why they call it the kick panel. :rimshot:
    Better hit the kunkyardy
  3. Mar 20, 2024 at 6:53 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I'll see how it rides/lasts. It's already F'ed up because the cab is smashed down 1/2" there, if you look you can see where I had to "modify" the top to get to the 10mm for dash panel removal. She's haggard :thumbsup:
    10.2mpg on recent fill up. I add the 3.7% to calibrate for the 265s. Weird that going UP a size makes mileage go down, you'd think it would be higher, or even a wash if you consider rolling resistance maybe?
    But logically you get more revolutions per engine RPM. Do you know the science behind that @shifty` ?
    bmf4069 and FrenchToasty like this.
  4. Mar 20, 2024 at 7:21 PM
    fk bud
    fk bud New Member
    jj
    2005 DC V8 4x4
    flatbed
    wow! lots of good info in there, thanks man!
    FrenchToasty likes this.
  5. Mar 20, 2024 at 7:23 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I just got out of the sub 10s club, sub 11s is a different world!!! But I don’t do any of that fancy math, I can barely read a tape measure
  6. Mar 20, 2024 at 8:46 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  7. Mar 20, 2024 at 8:49 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  8. Mar 20, 2024 at 8:51 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Hauled a few rocks today, 6 to be exact. I really should put brakes on this trailer…
    7B8A3B83-2818-4256-8264-6291EC78B987.jpg 584A69ED-9C69-4EB0-ADDB-03DE74380CF6.jpg
    Voss, NUDRAT, The Black Mamba and 4 others like this.
  9. Mar 20, 2024 at 8:52 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    @Mr.bee disapproves if those weren't lifted by hand.
  10. Mar 20, 2024 at 9:03 PM
    PenderBen
    2003 Tundra AC 4x4
    Funny you should say that, actually used the largest machine I’ve ever used to load them at the quarry, a Case 240 excavator (24ton). Ironically I unloaded them with the smallest machine I’ve ever used (my excavator) a Bobcat 323 (1.6ton), it couldn’t lift them but it could pull them around.
    I can flip one of them by hand…
  11. Mar 21, 2024 at 6:09 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    I removed my back seats the next day after I bought my AC. No one will ever sit back there!
  12. Mar 21, 2024 at 6:15 AM
    shifty` Inside his chest they found ten thousand pencils
    Had this chat in a PM with another member recently who I think also had it backwards, unless I have it backwards?
    "Going from 265/65r17 -> 275/70r17 leads to +5.2% difference, i.e. 1 mile with stock tire is 1.052 miles on the new larger tires. My last fill-up was a 201mi trip. 201x1.052 = 211.452 actual miles? So my calculation, I actually went more miles but reported less, so I'm getting mpg figures based on 5% less actual miles traveled. My MPG numbers should be lower, I believe?"
    But let's be real - my original tire was 37lb weight. The new Mickeys are 55lb, almost 70% heavier, if my maths are right? And I'm sure the new wheels are probably heavier also, so basically roughly doubling my rotational weight going from road tire to AT and a couple sizes up. I should be in the shitter MPG-wise right now.
    But yeah, city driving, without correction (and yellowbox isn't really an option for the VVTi trucks in 1GT), I'm struggling to get in the 10s for mpg right now. Before the tire/wheel change I was consistently 12s with mostly city driving. I wish I could easily correct w/yellowbox or similar.
  13. Mar 21, 2024 at 6:41 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Looking really good. Have you decided if you're going to paint the topper? It doesn't look bad now.
  14. Mar 21, 2024 at 6:57 AM
    It's on the list of things to do while I'm on my paid permanent-work-leave. But it's got a few things ahead of it. Gotta deal with a recall, new tires and alignment on the '20 Highlander. Need to get around to pulling whatever shit brake pads the PO had installed on the truck, the screeching is driving me f'n nuts. Been waiting for temps to warm up so I can glue the hairline crack in the lip of the cap, and refinish that section before I take it in for paint. I think I'll lift the cap and inject glue from underneath to flow it thru the crack, then sand down and use some touch-up spray on it.
    My to-do list is long right now! While the cap is out, I think I'll probably do some small touch-up stuff on tie-downs, mulch the yard, pull the liner and wax the bed, prep my wiring for permanent power to the rear and lighting in the cap.
    NUDRAT likes this.
  15. Mar 21, 2024 at 7:04 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Tape reverse side, sprinkle baking soda into crack, dribble some super glue (not the gel type) on the baking soda, remove tape, sand
    NUDRAT, BroHon and oscardog86 like this.
  16. Mar 21, 2024 at 7:09 AM
    I already have some Thixo (382660) to seal it up. Reco from one of Dad's friends who rehabs bass boats. I showed him pics of the back side, he said it looked like most of the fibers are still intact over the crack, best bet was just to straight-up inject it from the rear until it oozes out of the front, then clean up most of the excess and lay some tape over the painted side to help the Thixo lay flat for easier finishing later.
  17. Mar 21, 2024 at 7:21 AM
    FishNinja
    Lee
    06DC2wd
    $50?!?!?!?! Fuckkkkkkk
  18. Mar 21, 2024 at 7:22 AM
    What, for the Thixo? Dude got me a tube for $18. Parents delivered it a couple weeks back when they came to grab some furniture.
    EDIT: Looks like scAmazon has it for $30.
    FishNinja[QUOTED] likes this.
  19. Mar 21, 2024 at 7:23 AM
    FishNinja
    Lee
    06DC2wd
    Oh that's not bad. I googled it and the first one was like $47 lol
  20. Mar 21, 2024 at 9:38 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    Finally got my wheels and tires put on. Love the way they look. Went with 265/70r17 Mickey Thompson Baja boss tires. Got a good deal on them and they ride well. Have 5100’s coming in two weeks so can’t wait to get those on too. Only problem is one of the wheel studs broke so I have to get that taken care of soon.
    ignore the dent in the side it’s but a scratch haha
  21. Mar 21, 2024 at 9:43 AM
    oscardog86
    Southern California
    ^ That is such a cool color on your FGT!
    KTM_AJ421 likes this.
  22. Mar 21, 2024 at 9:52 AM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    thanks man I love it!
  23. Mar 21, 2024 at 10:05 AM
    FishNinja
    Lee
    06DC2wd
    for only being 1" larger than my 265/70r16. You set up looks massive compared to my stock set up. The 34's are gonna look ridiculous in my truck. Lol
  24. Mar 21, 2024 at 10:07 AM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    Mine is a 2wd with worn out springs and shocks maybe they will look a little smaller once I get the 5100’s mounted up.
    oscardog86 likes this.
  25. Mar 21, 2024 at 10:07 AM
    phudz
    phudz
    Michigan
    2004 DC V8 4WD
    Sorry for the late reply, I was out of town the last 2 weeks on a roadtrip. After 5000+ miles put on them, I can say they're great so far and the only annoyance was squeaky/creaky friction pads that occurred after a coating of fluidfilm. They ride firm and keep the truck planted confidently on pavement. There were some spots on my trip (namely I80 in eastern Iowa, and SH-93 near Obsidian, Idaho) that made the rear end bounce like mad, but I'm gonna blame the road there.
    I don't really go "offroading" (unless you count USFS / BLM roads that might be kind of rutted out, but I slow down for that stuff anyway). That said, I will be upgrading the stock struts this spring to Bilstein 5100s with OME springs to improve the ride a bit more.
  26. Mar 21, 2024 at 10:13 AM
    FishNinja
    Lee
    06DC2wd
    same. And same. And I also have 5100's.......
    bmf4069 and KTM_AJ421[QUOTED] like this.
  27. Mar 21, 2024 at 10:16 AM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    not going to lie the 265’s on this thing with these rims poke more than I thought, especially in the rear. I get a tiny bit of rub at full lock on the front mudflap but that’s it
  28. Mar 21, 2024 at 10:19 AM
    FishNinja
    Lee
    06DC2wd
    At ~31.6" you're right at the cusp of having to lift to clearance easily. It also would depend on the dimensions of your wheels. What are they?
  29. Mar 21, 2024 at 10:41 AM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    17x8.5 -10 offset
  30. Mar 21, 2024 at 11:07 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    my favorite color. Looking good. :fistbump:
    KTM_AJ421[QUOTED] likes this.
