  1. Oct 16, 2022 at 1:00 PM
    Ah, just the tip. Not the toe. Got it. :rofl:
    bmf4069 and GODZILLA[QUOTED] like this.
  2. Oct 16, 2022 at 5:44 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    My tundra does that and its from the rear leaf springs. Grab the springs firmly and shake with all your body weight
  3. Oct 16, 2022 at 6:03 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    No, mine did this behavior 6 months before my left rear body mount collapsed. That was PIA to replace not know if grinding off the rusted bolts was going to set my gas tank on fire since I could smell fumes when I filled it. :bananadead:
    After reviewing videos of others online debunking that myth, I bravely attempted the job sparks flying and all and got it done. :D
    Now it's the same symptom that I experienced with that first body mount. Feels like the jack shifted in place under the rear seat.
    By the way, the 3rd gen taco poly mounts from energy suspensions fit perfectly for our trucks. (DC results may differ)
  4. Oct 16, 2022 at 6:11 PM
    Sunnier, bmf4069, RUSTYNUTS and 2 others like this.
  5. Oct 16, 2022 at 6:13 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    After doing some electrical work for our HOA this morning, I decided to get a haircut and wash my truck. One the way there, got a CEL and P1126 code. Decided to try easiest first. Cleaned the MAF sensor but code would not clear so I cleaned the throttle body and it cleared and hasn't returned. Success!
    NUDRAT, oscardog86, bmf4069 and 4 others like this.
  6. Oct 16, 2022 at 6:14 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Rotors, pads and lines. I'm looking at upgrading to the GX bigger rotor and caliper.
    5N0W808[QUOTED] and FrenchToasty like this.
  7. Oct 16, 2022 at 6:16 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Does that include the transmission mount? Which energy mounts are these?
  8. Oct 16, 2022 at 6:16 PM
    Jack McCarthy
    Bill
    North of Boston
    No squeaking yet except from the front left corner strangely. :confused:
    Somewhat intermittent.
    shifty`[QUOTED] likes this.
  9. Oct 16, 2022 at 6:19 PM
    Jack McCarthy
    Bill
    North of Boston
    No just the 6 body mounts. I bought them on Amazon for $99.
    I put the model number somewhere in this thread...
    https://www.tundras.com/threads/pickup-bed-lean…bad-leaf-bushing-shock.107039/page-3#post-2804176
    Or maybe not...Energy Suspension P/N 8.1409G
    https://www.amazon.com/Energy-Suspe...efix=energy+suspension+8.4109g,aps,100&sr=8-2
  10. Oct 16, 2022 at 6:27 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yup, I have extended SS lines. Just in front. Rear they didn't have in stock. Eventually I'll get some.
  11. Oct 16, 2022 at 6:30 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Nice. Yea mine are a bit different since it's a Sequoia. Similar but different lol. I've seen one other guy on here with them. Or maybe it was a different forum, can't remember.
  12. Oct 16, 2022 at 6:36 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
  13. Oct 16, 2022 at 7:34 PM
    daveeasa
    David
  14. Oct 17, 2022 at 7:12 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Since we are discussing brakes again I've been meaning to share this update on my GX calipers.
    It's been exactly 2 years since I installed the 14WA calipers. At some point, I started noticing a metal on metal noise every time I went over bumps. I only hear it with the windows down. For a while I just assumed it was my aftermarket skid plates where they rest on each other. I removed the skid plate and the noise remained. A few months ago I crawled under the truck with my dead blow hammer and started tapping everywhere to recreate the noise. It wasn't until I smacked both spindles that I heard the same noise. My mind immediately went to the brakes but I dismissed it thinking I was suffering from confirmation bias.Can you guess where I'm going with this?
    Fast forward to last week and I'm driving over a particularly bumpy road with the windows down wondering about the god awful rattling noise. I approach a curve and then hit my brakes while going over bumps and the noise immediate stopped. Let off the brakes and the noise comes back. Picutre the old cartoons where the light bulb goes off above the head of the character.
    All this time, I've chased every possible issue and it never occured to me that something went wrong when I had these calipers modified at the machine shop. I never measured the ears after picking them up(shame on me). The shop manager seemed to understand exactly what was needed and told me he shaved off the right amount(I believe it was 4mm) They looked great and mounted right up to the spindle. What I suspect is that they didn't mill enough off the mounting ears. The geometry is off somehow and the pistons are having to travel too far to move the pads, thus why I'm having to double pump the pedal. This would also explain the noise. They are rattling against the spindle??? As I apply the brakes, it somehow expands enough to eliminate the rattle.
    TLDR-These calipers have to go. I'm ordering new 13WL calipers/rotors/pads. If nothing else, it should solve this noise even if I'm somehow wrong about this also causing the other issue.
    Tundra2, bmf4069, oscardog86 and 3 others like this.
  15. Oct 17, 2022 at 7:25 AM
    daveeasa
    David
    Interesting update. It can be hard to trace down a root cause. Milling off ears doesn’t seem overly complicated but I can imagine it’s hard to achieve tight tolerances.
    Noises / rattles really get to me too. I have one in the 2016 and several in the Tundra. Stuff you just have to suffer through till you solve it.
    5N0W808 likes this.
  16. Oct 17, 2022 at 7:36 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Me too. And I love driving with the windows down but I would avoid it because of the rattle. I was so focused on the brake issue that I didn't devote much time to the rattle. It never occurred to me they could be connected.
    5N0W808 and daveeasa[QUOTED] like this.
  17. Oct 17, 2022 at 8:00 AM
    Make sure you're connected. The writing's on the wall.
    https://www.youtube.com/watch?v=WoESSG6iSAI
    FirstGenVol[QUOTED] likes this.
  18. Oct 17, 2022 at 9:19 AM
    ryderboy
    ryderboy New Member
    06 tundra sr5 double cab
    Yes it’s stock
  19. Oct 17, 2022 at 9:25 AM
    ryderboy
    ryderboy New Member
    Put the ol’ girl to work. Definitely not a fast tow but it did it. Going to order some sumo springs to help with the sag and this trip ended up knocking off a factory bump stop anyways.
  20. Oct 17, 2022 at 9:33 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Do you all think I should try to sell these 14WA's to someone willing to work on them? Knowing they may be hard to fix. I'm not going to send them back as cores for some poor SOB to get stuck with.
    txagg and oscardog86 like this.
  21. Oct 17, 2022 at 10:02 AM
    5N0W808 likes this.
  22. Oct 17, 2022 at 11:46 AM
    tokolosh
    tokolosh Serial procrastinator
    J
    SF Bay Area
    05 AC V8 SR5 Phantom Grey
    new driver
    I like turtles
    bmf4069, 5N0W808, Casper421 and 8 others like this.
  23. Oct 17, 2022 at 12:44 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Pucks, you were more relaxed when you lived in CO. :rasta:
  24. Oct 17, 2022 at 1:08 PM
    Sunnier
    Sunny
    San Diego, CA
  25. Oct 17, 2022 at 1:13 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well that was a cluster fuck. @Pucks18 got a 30 day vay-cay.
    Here's his BST post link.
  26. Oct 17, 2022 at 1:16 PM
    Casper421
    In the woods
    06 DC
    Oh shucks, I had an at tire related question that I really wanted his opinion on!!
  27. Oct 17, 2022 at 1:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  28. Oct 17, 2022 at 1:24 PM
    Casper421
    In the woods
    06 DC
    In seriousness though, I’m selling the 35’s for 34’s and was about to click buy but had the thought to go to an at tire instead of an mt. So now I’m thinking about trying the falcon at3w’s in 285/75r17. Any thoughts on the at3w or any other at with good traction and good for towing?
    KingSequioa007 and oscardog86 like this.
  29. Oct 17, 2022 at 1:30 PM
    I was looking at the AT3 line in general as my go-to just because there's been so much good feedback on many aspects, and they look pretty good. AT3W specifically, lots of glowing feedback:
    https://www.tundras.com/threads/tire-recommendations.112407/#post-2899637
    https://www.tundras.com/threads/tire-recommendations.112407/#post-2899730
    https://www.tundras.com/threads/tire-recommendations.112407/#post-2899798
    https://www.tundras.com/threads/tires-what-stock-brand-and-type-at-touring.87624/#post-2205158
    https://www.tundras.com/threads/tires-what-stock-brand-and-type-at-touring.87624/#post-2206912
    https://www.tundras.com/threads/phantom-gray-pearl-tundra-thread.60030/page-3#post-2399631
    https://www.tundras.com/threads/suspension-talk-recommendations.92123/#post-2328077
    To be fair, one bad feedback, which may actually be a positive for your needs:
    https://www.tundras.com/threads/33-tires-on-stock-tundra-with-leveling-kit.69272/#post-1794486
    With more details on why: https://www.tundras.com/threads/33-tires-on-stock-tundra-with-leveling-kit.69272/#post-1794846
    Casper421[QUOTED] likes this.
  30. Oct 17, 2022 at 1:48 PM
    daveeasa
    David
    CodyP, oscardog86 and Tundra2 like this.
