  1. Jan 19, 2022 at 10:37 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    What's the allowable limit for windshield tint in TX? Here it's zero but I know some people who've gotten 5% done which is unnoticeable according to them from an inspection POV.
    Significantly reduces glare from oncoming headlights I'm told as well.
  2. Jan 19, 2022 at 11:49 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    wait, I didn't know you spoke Noahish!
    NUDRAT and Jack McCarthy like this.
  3. Jan 19, 2022 at 11:55 AM
    Sthricthly sthpeaking Tython! Lithpietht man on thith earth!
    CodyP[QUOTED] likes this.
  4. Jan 19, 2022 at 1:15 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Alright men, got rambunctious and might have myself in a bind. Doing the door actuators and got a little heavy handed. Maybe a lot heavy handed. Will my door handle still function with this clip broken:
  5. Jan 19, 2022 at 1:38 PM
    Voss, txagg, oscardog86 and 2 others like this.
  6. Jan 19, 2022 at 1:55 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Thanks @shifty` I will run grab some. Got the other card off and all apart while I waiting for answers. I could get the broken clip shown moved out of the way, but it won't give from the door handle. On this other side I'll give it more hell
  7. Jan 19, 2022 at 2:02 PM
    One of the ones on my tailgate was a freaking PITA to pop off too. the latches on either side of the tailgate are such a bitch to get to, no room to maneuver, impossible to get leverage.
    Best trick I can give you with these is to slide a slim flathead into the belly of the "U" where it clips onto the rod and pop outward, if you can easily get access.
    If not, it means the tips of the U must be facing toward you, and a lot of times pressing the round edge of a 5¢ nickel into the tips of the U will spread and push it back.
    I always hated doing speakers in doors on older vehicles, the clips always inevitably break. We had a bin full of replacement clips at the shop.
  8. Jan 19, 2022 at 2:17 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I was able to pry this mother off the rod, but couldn't pull the rod out of the handle after that. So just had to contort the entire assembly to get to the other side of the actuator to take the last screw off. In the process of moving it I'm pretty sure it turned back over the rod and the got snap a lapped! I have all those tailgate clips from Toyota and saved your thread to do it when I install the reverse camera
  9. Jan 19, 2022 at 2:19 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I went ahead and called it a day. Unplugged the battery and decided I needed to do some high level security with the door handle:
    tacoguybill likes this.
  10. Jan 19, 2022 at 2:22 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    All was not lost, as a bus dropped off some help for the other door card:IMG_2818.jpg
  11. Jan 19, 2022 at 2:25 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Also, "installed" the backer rod I have had for a month while my daughter worked on the door:
    We'll see if that helps with the dash rattle's
    chrisb, abcinv and shifty` like this.
  12. Jan 19, 2022 at 3:04 PM
    bmwahba
    bmwahba New Member
    Damn that looks lifted surprised that is stock lift and no rubbing. I'll be running this exact setup then! I have a slight lift front and rear.
  13. Jan 19, 2022 at 4:21 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Up to 25% light transmission for the top 5”, but clear uv film is acceptable.
    FrenchToasty likes this.
  14. Jan 19, 2022 at 4:39 PM
    Jack McCarthy
    Bill
    North of Boston
    What about the rest of the windshield? 0%
  15. Jan 19, 2022 at 4:41 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea?, just says clear, no percentage.
  16. Jan 19, 2022 at 4:41 PM
    The percentage is light transmission. So 0% would be painted black. 5% is limo tint, very dark. Most factory tint is 20-25% or so on the rear and little to no tint on the front.
  17. Jan 19, 2022 at 4:44 PM
    Jack McCarthy
    Bill
    North of Boston
    Interesting. So you do think anyone would notice 95%?
  18. Jan 19, 2022 at 4:49 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I plan on getting the ceramic lumar air 90 or whatevs.
    KK6PD and txagg like this.
  19. Jan 19, 2022 at 4:57 PM
    Jack McCarthy
    Bill
    North of Boston
    Let us know how that works out. If it cuts down headlight glare, I may become a customer.
  20. Jan 19, 2022 at 4:57 PM
    I want it to cut down heat from the sun.
    KK6PD likes this.
  21. Jan 19, 2022 at 5:57 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    @KNABORES, it works for that. I have it on my onefiddy. You cannot tell it's tinted, many factory windshields come with a hue that looks similar
    KNABORES likes this.
  22. Jan 20, 2022 at 5:37 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Finally got these extended brakes likes from Crown performance installed. Had them for a while and only reason I installed them was because the little small metal tube line going to caliper broke and leaked out most of the fluid. Anyone experience this with your lifted rigs?
    NWPirate, alb1k and txagg like this.
  23. Jan 20, 2022 at 6:56 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Work has been crazy so I’ve been MIA for a bit.
    Tundra is in with my brother getting long tubes and a full 3” exhaust put on. Also, after 6 months, the mishimoto radiator popped a leak. It isn’t horrible, we were able to make the 30mile drive to the shop. MM has a lifetime warranty, but radiators are back ordered 8-10 weeks, so now I need to decide if I’m going to park it for 2 months and drive the Ram every day, throw the stock radiator back in, or screw mishimoto and buy a new all aluminum rad.
    what to do, what to do…
    bmf4069 and Voss like this.
  24. Jan 20, 2022 at 7:00 AM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    What UCAs are those? freedom offroad?
  25. Jan 20, 2022 at 7:06 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yes sir! Freedom.
  26. Jan 20, 2022 at 7:07 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Make Mishimoto honor the warranty. Sell the replacement or put it back in. Looks like a lot of salt.
    lsaami[QUOTED] and chrisb like this.
  27. Jan 20, 2022 at 7:09 AM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    Do you like them? call me cheap but I'm having a hard time swallowing the price of SPC,JBA, etc
  28. Jan 20, 2022 at 7:13 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I can't speak for @KingSequioa007, but I have Freedom UCAs on my truck and they're not terrible. I'd like a little more caster out of them, but they don't bind or make any noise. Not sure what else I can ask at that price point.
  29. Jan 20, 2022 at 7:18 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You have the worst luck. Didn't your CVJ axle boot tear prematurely as well? This makes me wonder if the Mishimoto rads are worth the extra price.
    Darkness and lsaami[QUOTED] like this.
  30. Jan 20, 2022 at 7:22 AM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    I would love to find out what happened with this guy:
    https://www.tundras.com/threads/freedom-off-road-uca-bent-my-spindles.99719/
    Do you have the uni-ball type or the others? I live in Wyoming so I'd like to avoid uni-balls, as ive heard they arent great in these climates. as long as bent spindles are not the norm, ill probably go with freedom offroad. I also plan on welding in spindle gussets at the same time.
    :burnrubber:
    KingSequioa007 and alb1k like this.
