  1. Aug 2, 2021 at 11:26 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  2. Aug 2, 2021 at 11:29 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Looks right to me.
    02 RC non-vvti 2uz
    16100-59275
    05 AC vvti 2uz
    16100-09200
    Both supercede on Toyotas parts site.
    Part Number: 1610009201
    Supersession(s): 16100-09201; 1610009200; 1610059275; 1610059276
    daveeasa[QUOTED] likes this.
  3. Aug 2, 2021 at 11:30 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  4. Aug 2, 2021 at 11:46 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
  5. Aug 2, 2021 at 12:11 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
  6. Aug 2, 2021 at 12:14 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    The rears were super easy to do, I’d like to assume the fronts wouldn’t be to bad. But at some point you need to decide what is worth more; your sanity or saving a few bucks
  7. Aug 2, 2021 at 12:24 PM
    Jack McCarthy
    Bill
    North of Boston
    Is it something that takes more than an hour's time? Back or front?
  8. Aug 2, 2021 at 12:27 PM
    FrenchToasty
    Mo
    Bone stock
    I mean the bleeding takes more time than it does to do the rebuild. But that’s here with a crust free undercarriage, not sure how much fun it would be with a truck from the crust belt
  9. Aug 2, 2021 at 12:33 PM
    The only challenge to rebuilding brake calipers is the cylinders themselves. If you have leaking seals, or mild sticking (from crud buildup or lack of fluid getting to the outside of the cylinder) it's easy enough to clean up, put the new seals and bleeders on and go. If the cylinder has the slightest pitting or corrosion, some mild honing is possible (with the right tools) but otherwise dealing with more corrosion is futile, turn em in and get new ones.
    NUDRAT and Jack McCarthy like this.
  10. Aug 2, 2021 at 12:34 PM
    Jack McCarthy
    Bill
    North of Boston
    It’s probably no different than the periodic rust removal I need to perform with the bell cranks on the emergency brake every few years or so. Lots of sanding and lubing.
    NUDRAT and FrenchToasty[QUOTED] like this.
  11. Aug 2, 2021 at 12:35 PM
    Word.
  12. Aug 2, 2021 at 12:38 PM
    daveeasa
    David
    OK, if it's not too much abuse of the thread (ordering parts is what I'm doing today) would anyone be willing to double-check my cart? I'm not 100% sure on quantities, I'm assuming 8 spark plugs but what do I know, never changed a plug in my life. And no idea at all on valve cover gaskets. The tie rods were from the sheet provided by the dealer so I assume those parts are good, along with serp belt and tensioner.
    I'm guessing there are likely several other items I should add, perhaps the spark plugs themselves? And maybe replace cables at the same time?
  13. Aug 2, 2021 at 1:10 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Is your timing belt new? It has to come off to change the water pump. Now is a good time to replace if it has some miles.
    EvilMilkshake and NUDRAT like this.
  14. Aug 2, 2021 at 1:15 PM
    daveeasa
    David
    Yes, the timing belt was replaced last week by the dealer for $600 ish. They wanted another $600 for the water pump while doing the timing belt and another 400 on top of that for the belt tensioner which just seemed extreme so we're doing things the dumb way and taking it all apart again to do the pump, belt and tensioner since I needed to find someone to do the gaskets and tie rods (or attempt that myself but I am happy to farm this out since it's a decent chunk of work.)
    Anything else to consider/do at the same time?
  15. Aug 2, 2021 at 1:22 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    In Houston they just call em slabs
  16. Aug 2, 2021 at 1:25 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Yeah. That's a pretty big hit when its mostly already done.
    Thermostat and that o-ring/gasket that occasionally fails under the intake, maybe?
  17. Aug 2, 2021 at 1:26 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @daveeasa what are you attempting to do with the tie rods? You have 2 different part #'s in your cart with vastly different prices.
    Also, with everything else you have listed I'd consider doing your serp belt tensioner and idler pulley.
  18. Aug 2, 2021 at 1:31 PM
    daveeasa
    David
    I had hopes that my cart included the proper tensioner? Is it not 16620-0W101? Is there a separate part for the idler pulley? Did I screw up on the tensioner? It does say compatible with 2002 Tundy.
    I was told inner and outer tie rods need replacement so those parts are from that work order, I'm definitely the least confident on those part numbers (any help appreciated).
    I will try to hunt for those parts to see if I can find them, thanks for the suggestion.
  19. Aug 2, 2021 at 1:37 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I think this is the o-ring for the pipe to thermostat/inlet housing.
    96761-24019
  20. Aug 2, 2021 at 1:41 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I hate searching for parts too so don't beat yourself up. Both your timing belt and your serpentine belt have a tensioner. I was just suggesting it might be a good time to replace the serp belt tensioner too since you are taking so much apart. I believe the part number you linked is for the serp belt, not the timing belt. This should be for the timing belt. https://toyotaparts.mcgeorgetoyota.com/oem-parts/toyota-engine-timing-belt-tensioner-1354050030?c=Zz1lbmdpbmUmcz1lbmdpbmUmbD00Jm49U2VhcmNoIFJlc3VsdHMmYT10b3lvdGEmbz10dW5kcmEmeT0yMDAyJnQ9c3I1JmU9NC03bC12OC1nYXM=
    It might be easier to just call the dealer you are using and ask them to verify. I know when I use McGeorge they are extremely helpful.
    FrenchToasty and Jack McCarthy like this.
  21. Aug 2, 2021 at 2:03 PM
    Jack McCarthy
    Bill
    North of Boston
    Did they tell you the inner and outer tie rods are worn out or damaged? Usually if those items are worn out, you replace them in pairs unless you like doing the work twice over a couple years.
    I take it since you’re ordering all the parts, you’ll be doing a lot of the work yourself or with someone helping.
    If that’s the case, don’t forget the zip ties to replace the bands on the steering rack boots after you cut them. It’s either that or buy new bands and spend $20-$30 for the special band crimper to reattach.
    NUDRAT likes this.
  22. Aug 2, 2021 at 2:09 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Good chance they are very tight or wanting to fight ya when attempting to remove. Ratched it back and forth 1/8-1/4 turn when you first start. Eventually they’ll come on out.
    As for comment about McGeorge, they have been very helpful whenever I’ve needed to call, asked questions in comment box when ordering and I know they will contact via email if they question something on order IF you supply VIN # when ordering.
  23. Aug 2, 2021 at 2:10 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    In my experience here in the rust belt it's just easier to replace the whole caliper because usually the bleeder snaps off and the $100 is better spent on a reman.
  24. Aug 2, 2021 at 2:14 PM
    daveeasa
    David
    Ah so buy two of each inner and outer and just do both sides? That makes sense.
    NUDRAT likes this.
  25. Aug 2, 2021 at 2:19 PM
    Pretty sure SLAB is actually an acronym for Slow Low And Bangin', some places say Slow Loud And Bangin'.
    I think this is a pretty decent brief breakdown on the origins of donk/box/bubble: http://www.liftabrand.com/About/Blog/entryid/12/donk-box-or-bubble
    Everywhere is different though. What someone says in Chicago may cause a fight in Houston or Atlanta. You just never know ...
    bmf4069 and TRDGen[QUOTED] like this.
  26. Aug 2, 2021 at 2:20 PM
    Jack McCarthy
    Bill
    North of Boston
    Yes, and when you peel back the boot you’ll see what I mean by using a skinny crescent wrench vs using a monkey wrench (pipe wrench) over the round part of the inner tie rod. Also don’t forget to count the number of turns prior to removing the outer tie rods so you can get them back as close as possible to the original toe setting before you get the front end realigned after you’re done.
    NUDRAT and daveeasa[QUOTED] like this.
  27. Aug 2, 2021 at 2:21 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I mean I'm not saying that OEM parts aren't great but I'd have an issue paying $166 for an inner tie rod when the Delco Pros are about $50.
    Jack McCarthy likes this.
  28. Aug 2, 2021 at 2:23 PM
    Jack McCarthy
    Bill
    North of Boston
    x2, that why I got Moog ones myself.
  29. Aug 2, 2021 at 2:28 PM
    Huh. Just looked it up out of curiousity. Granted this is from CNN, so who knows whether it's valid. I don't consider them kings of culture necessarily.
    https://www.cnn.com/travel/article/houston-slab-cars-music/index.html
    Seems like maybe there's some dispute about the etymology or meaning.
    TRDGen[QUOTED] likes this.
  30. Aug 2, 2021 at 2:32 PM
    Probably important to mention TRW bought MOOG or vice-versa and they're the same company. Talking about which is better on internet forums is like religion and politics for some folks. For S&G while working on my '68 pickup, I bought an inner and outer of each and other than one small section that may've had a miniscule shape variation on the casted eye end, the parts were basically identical. Both are considered higher-end products.
