  1. Jul 30, 2021 at 7:57 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I forsee a @Tundra2 epic ”Campfire” story. Fortunately, I have not run across any “Three Men in a Bar “ stories in the Knoxville News Sentinel
    bmf4069, des2mtn, FirstGenVol and 3 others like this.
  2. Jul 30, 2021 at 9:09 AM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    We’ve determined DC stands for Double Complex.
  3. Jul 30, 2021 at 10:09 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Looks good. Just an FYI, the previous owner probably checked on a replacement glass and found out it was too expensive or discontinued. That appears to have a curved rear glass so expect a hefty price if you can replace it.
  4. Jul 30, 2021 at 10:51 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Replaced the fan clutch as after 15-20 minutes the temp would start creeping up in 90+ degree weather.
    Cleaned the throttle body (since I had the intake tube off for more room).
    hammeron, des2mtn and bmf4069 like this.
  5. Jul 30, 2021 at 10:55 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Or, he could try Plexiglass. I've used a local plastics shop to build quite a few projects and they are cheap and good. You could probably take some measurements and have the plexiglass cut out, drill holes for the hinges and latch's and be good to go.
    Army_of_One, Darkness and KNABORES like this.
  6. Jul 30, 2021 at 11:09 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Nice. I'm pretty sure my fan clutch is going out too. Did you have to remove the belt to get the fan out?
  7. Jul 30, 2021 at 11:12 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Nope, fortunately the pulley didn't pop off once I had the clutch & fan off. Just cocked itself a little sideways from belt tension but went right back to where it should once the new one was held against it.
    FYI it comes out the bottom so removing the skid plate is a must. I also put a nut back on just in case while finagling it out.
    oscardog86 and des2mtn[QUOTED] like this.
  8. Jul 30, 2021 at 11:20 AM
    3.slow 4life
    3.slow 4life New Member
    Lodi, CA
    2000 4x4 Tundra TRD
    2.5” rough country lift, rough country rims, used 285 75 r16 BFG KO’s. Electric cutouts, flowmaster.
    Got myself an all pro off-road rack. Should start on building it sometime this weekend. 2ECE6440-4AD6-437D-A39F-0CC4BE8CA4F1.jpg
    abcinv, Darkness, bmf4069 and 2 others like this.
  9. Jul 30, 2021 at 11:29 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Let me know if you need any help welding that together.
    My Resume':
    oscardog86, CodyP, Mitch09 and 6 others like this.
  10. Jul 30, 2021 at 11:33 AM
    Nothing a little grinder won't clean up. Looks good to me:itllbuffout:
    bmf4069, Darkness and Bikeric[QUOTED] like this.
  11. Jul 30, 2021 at 12:28 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Might be good to do on cats for protection. Theives will laugh hard enough for you to hear them and chase them off.
    Bikeric[QUOTED] likes this.
  12. Jul 30, 2021 at 1:26 PM
    3.slow 4life
    Lodi, CA
    2000 4x4 Tundra TRD
    Im lucky, an old welder who worked at the mill has a sweet mig setup.
    oscardog86, bmf4069, Glock 40 and 3 others like this.
  13. Jul 30, 2021 at 1:43 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    bmf4069, Glock 40 and Darkness like this.
  14. Jul 30, 2021 at 1:52 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    We're approaching 16 hours. The front end is just about done. We have a bolt for the steering rack we haven't been able to get back in place. Need to torque a lot down still. Tomorrow we start on the rear.
  15. Jul 30, 2021 at 1:57 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Should just say good job men but the ole fart in me says to put that 3 ton jack to use for extra safety if nothing else….cherish or curse the moment…that’s all
    :hattip:
    Darkness likes this.
  16. Jul 30, 2021 at 2:02 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Whatcha think retorque at 3 miles, or wait a thousand?
  17. Jul 30, 2021 at 2:08 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    We've been using that jack both days for safety but had to move it earlier to give us more room for the steering rack fight.
    Darkness and BubbaW like this.
  18. Jul 30, 2021 at 2:09 PM
    18" TRD Off Road Wheels
    Why not both?
    Darkness and Sirfive[QUOTED] like this.
  19. Jul 30, 2021 at 2:10 PM
    des2mtn
    Shady Grove
    Tonto cover
    Go hit some jumps then re-torque it. Give 'er the good shake down.
    bmf4069, Darkness and Sirfive[QUOTED] like this.
  20. Jul 30, 2021 at 2:24 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Paint mark everything, even Noah.
    Looks like sway bar bushing is missing, battle that when its back on the ground.
    I hate the steering rack bolts. I struggled with one last time around for maybe an hour.
    bmf4069 likes this.
  21. Jul 30, 2021 at 2:26 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    That is one LONG upper ball joint.....Is it to fix the control arm angle due to a lift from the Rancho to Bilstein's?
  22. Jul 30, 2021 at 3:10 PM
    1genjunky
    1genjunky New Member
    04 tundra DC
    Added a sink to the pull out kitchen. It comes apart and sores inside. Adding running water next.
    oscardog86, MS22, abcinv and 4 others like this.
  23. Jul 30, 2021 at 3:15 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup, those upper arms flip the ball joint and it helps to relieve the upper arm angle.
    Gonna call @jpink "long balls" from now on :D
  24. Jul 30, 2021 at 3:34 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You don't know the half of it. The last two days has been filled with insults, swearing, shit-talking, Noah's disturbing jokes, and a garage of flatulence.
    oscardog86, Bikeric, CodyP and 7 others like this.
  25. Jul 30, 2021 at 3:41 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I was gonna say at least Noah kept his clothes on but I don't wanna give him any ideas.
  26. Jul 30, 2021 at 5:04 PM
    jpink
    Knoxville
    I’m just made we 100% forgot to take a measurement before we started. I’m certain it is sitting higher up front even though we’re at 0 on the 6112s.
    Have parts list started for next job.
    I’m hopeful rear will go more smoothly than front did. Hopeful we can finish rear in 9hrs tomorrow.
    At least it’s off the jack stands up front now.
  27. Jul 30, 2021 at 5:58 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    @jpink Did you guys use spring compressors or just the weight of the truck to compress the springs in place? Also do you need someone to guide the shock through the top plate while you were doing it?
    Only asking because I plan to put Bilstein 4600s on my truck next month.
    Edit: Nevermind, I’m guessing your 6112s were already preinstalled with the shocks.
  28. Jul 30, 2021 at 7:13 PM
    jpink
    Knoxville
    I had a local shop assemble. Made install not only easy, but much more safe.
    I need to add more to this thread but here’s my journey so far.
  29. Jul 30, 2021 at 11:43 PM
    SouthPaw
    2000 Limited 4x4 AC
    Definitely an alternative but being that it’s curved, it won’t seal. It’s definitely better than nothing though.
  30. Jul 30, 2021 at 11:44 PM
    SouthPaw
    2000 Limited 4x4 AC
