  1. Jul 12, 2021 at 10:01 PM
    hammeron
    hammeron New Member
    2002 Tundra v8 Blue 2wd
    Nothing, but another breakfast without PHM, just not the same! Why?
    Why did you have to step in the poo? Now many of us miss you.
    On a lighter note, planning to take the rig to Lowes in the morning for
    Concrete blocks for my flower bed project.
    06yotamike, Glock 40, Thrussn and 6 others like this.
  2. Jul 12, 2021 at 10:03 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’m sure he still enjoys his dark roasts while paroosing the local sections.
    Darkness and Tundra2 like this.
  3. Jul 12, 2021 at 10:05 PM
    hammeron
    hammeron New Member
    Yeah, but I'm sure he wishes he was still here with his buds.
  4. Jul 13, 2021 at 12:12 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I've tried and tried and tried to program mine but none of the codes worked
  5. Jul 13, 2021 at 12:12 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    I know it works for the 4 speed but I can't get it to work for the 5 speed
  6. Jul 13, 2021 at 12:29 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I'm crafty... haha. Seriously tho, I used the original outer frame, cut all the inner stuff out, then drilled the holes. Cut the tubing pieces longer than the opening so they'd extend into both the top and bottom of the frame.
    NUDRAT, Darkness, oscardog86 and 2 others like this.
  7. Jul 13, 2021 at 12:47 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    That grill has been growing on me. I think it originally reminded me of a lincoln mark lt, but as soon as someone mentioned tacoma it started to fit.
    NUDRAT and RUSTYNUTS like this.
  8. Jul 13, 2021 at 12:59 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Yeah I'm still not sure how I feel about it. Confused mostly. I'll post it again when its black
    onesojourner, TRDGen, CodyP and 4 others like this.
  9. Jul 13, 2021 at 12:57 PM
    ehtundra01
    ehtundra01 New Member
    Thomas
    01 sr5 55,xxx
    Well gentlemen, two weeks ago I was driving on the beach and all of a sudden I heard a loud BANG so I get it towed off the beach and back home. Today I got to tearing into it and found some fun carnage, anyway, if anyone has a stock carrier for a 01 ac tundra id gladly pay ya lol
    Darkness and oscardog86 like this.
  10. Jul 13, 2021 at 1:07 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    The 5 speed has an extra sensor too.Some of us are using android with torque pro for the readout.
    The last time I was out camping I saw the torque converter get up to 220. The pan never made it to 200. At what point do you guys start backing off? (I am asking specifically about the 5 speed with WS).
    TRDGen[QUOTED] likes this.
  11. Jul 13, 2021 at 1:17 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    When I see my pan temp hit 200 I try to back off or stop. I have noticed that in 4HI, and low speed, the transmission gets really hot, really fast. As soon as I put it in 4LO the temperature plummets.
  12. Jul 13, 2021 at 1:26 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Rotated my tires, cleaned the rust off the front disk brake pins with an overnight soak in muriatic acid, greased them up and put them back in place. Last time I had to drill those suckers out to get them loose. Huge PIA, and never again.
    FrenchToasty likes this.
  13. Jul 13, 2021 at 1:27 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Get a few packs of brake hardware to keep on tap.
    Jack McCarthy likes this.
  14. Jul 13, 2021 at 1:52 PM
    Richid
    Richid New Member
    Keep an eye on CL or FB marketplace. When I replaced my rear axle due to the housing rusting through, I thought someone would want the old third member.
    No takers after 6 mos, so I scrapped it. I think the failure rate in these is really low, so there should be a bunch out there.
    Best of luck!
    NUDRAT and Jack McCarthy like this.
  15. Jul 13, 2021 at 2:18 PM
    Jack McCarthy
    Bill
    North of Boston
    That’s really interesting. If I had a standard shift I would probably use 4wd low a lot more often. I hate when the truck shifts hard between 1st and 2nd or 2nd and 3rd in 4wd low using an automatic.
    NWPirate and des2mtn like this.
  16. Jul 13, 2021 at 2:26 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I agree. I also think I would use 4-LO more with a manual t-case.
  17. Jul 13, 2021 at 3:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Seen this coming off an on ramp. Willie Nelson was driving the oversize load lead truck. Looked like Johnny paycheck was driving the chase truck.
  18. Jul 13, 2021 at 3:10 PM
    des2mtn
    SW
    Tonto cover
    That's a big joint. No surprise it's Willie Nelson's.
    NUDRAT, oscardog86, RUSTYNUTS and 2 others like this.
  19. Jul 13, 2021 at 3:13 PM
    They used to build those in a factory down by the river (cue the Chris Farley) in Little Rock, AR. Would see them all the time headed east or west on I-40.
    NWPirate, FrenchToasty and Tundra2 like this.
  20. Jul 13, 2021 at 3:18 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  21. Jul 13, 2021 at 3:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Note to self: do radiator distilled water flush in fall from now on. :bananadead:
  22. Jul 13, 2021 at 3:57 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Ouchole! When mine went out this pin had come loose.
    It occasionally backed out, smashed the pinion to lock up my rear then went back in. I drove on it for about a month before realizing what was wrong.
  23. Jul 13, 2021 at 4:00 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
  24. Jul 13, 2021 at 4:17 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    bmf4069 and TRDGen like this.
  25. Jul 13, 2021 at 4:41 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    That's good to know. Since I usually leave it in 4hi when off roading until I need 4lo
  26. Jul 13, 2021 at 4:43 PM
    TRDGen
    TRDGen Schnooogins
    Travis
  27. Jul 13, 2021 at 4:50 PM
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    I would strongly advise against 4.30s with 35s unless you like shifting all the time and mashing the skinny pedal. I think 4.30 brings these trucks back to stock with 33's?
  28. Jul 13, 2021 at 5:39 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    You may be right. But are you speaking from a vvti or non vvti v8 aspect? I only ask because I see you have an 04 and I have an 06. My truck on 33s and stock 3.91 gears really doesn't seem sluggish
  29. Jul 13, 2021 at 5:57 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    My truck on the 33s has been doing BETTER on gas with the stock 3.93s than when I had the 32s
    oscardog86 and FrenchToasty like this.
  30. Jul 13, 2021 at 7:32 PM
    alee891
    Now/here
    Shitbox
    At highway you may have an advantage with your transmission, but off road, even in 4LO, it’s going to be a dog turning that big of tires. Just my two cents and I’m by no means a gear guy, but I’d hate to go through the effort of regearing to be dissatisfied once on a trail. I’ve never heard someone say they were too over geared.
    :notsure:
    Are you driving at mostly highway speeds to where that added weight is helping you roll along, as opposed to the truck having to turn them through town?
    des2mtn and FrenchToasty like this.
