  1. Jul 12, 2021 at 11:05 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Nice, which tire are you running with the 5100's and OEM coils?
  2. Jul 12, 2021 at 12:29 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I finally ordered a 1 inch body lift. I'm so excited. Now I'm one step closer to 35's.
    Still need some 17s and bigger brakes and gears.
    oscardog86 likes this.
  3. Jul 12, 2021 at 12:30 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    What ratio gears ya going with? I was leaning towards 4.56 but I think with extra weight and such Ill eventually go 4.88 for 33s. I have a V6 tundra though
    TRDGen[QUOTED] likes this.
  4. Jul 12, 2021 at 12:31 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Oh and I also installed some neoprine seat covers
  5. Jul 12, 2021 at 12:31 PM
    Legender
    Legender New Member
    Carlton
    DFW
    2006 Tundra DC Limited 2WD
    None yet.
    Still running the Cooper Discovery 265/65R17s that were on it when I bought as they are fairly new. But thinking I'm going to have some massive air gaps now that I've upgraded the shocks, even with the OEM springs that I did not change out. With 150k miles on the original KYB shocks I think it was time to relieve them of their duties.
    TRDGen likes this.
  6. Jul 12, 2021 at 12:32 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    I have a v8 and I do mostly highway miles so I was thinking 4.30 but I might go 4.56
  7. Jul 12, 2021 at 12:35 PM
    oscardog86
    Southern California
    Whats the V8 have stock? Mine are 4.10
  8. Jul 12, 2021 at 12:39 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    I believe mine came with 3.91 stock
    FrenchToasty likes this.
  9. Jul 12, 2021 at 12:48 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I want taller tires, because longer gears arent recommended. 3rd is in the sweet spot, but could afford some extra leg.
    but ill probably have to idle at 70 in OD if i gather the confidance to swap on a 6 or 8 speed slushbox and controller, when a wide ratio 5 speed stick is comparable in price without the double OD. A stick truck can sound good no matter what, this a340 has me at all the wrong revs all the time. I dont know if i have 3.90s or 4.10s but thats a negligible difference. The titan had a lockup .7 OD and 2.93s (and stock 33’s). But when the pinion cooked the bearings we got a 3.36 diff with the aluminum cover from a newer truck from a JY.
  10. Jul 12, 2021 at 12:58 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  11. Jul 12, 2021 at 1:04 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm about to go out and adjust the rear drums. Going to jack it up, put it in neutral, etc etc. Will I be able to hear the shoes lightly drag the drums when I spin the tires, or is it more of a feel on the amount of force it takes to spin the wheel? I had the drums off Saturday to clean and inspect and now I'm just trying to get it back in spec.
    bmf4069, NUDRAT and Darkness like this.
  12. Jul 12, 2021 at 1:05 PM
    Desert Dog
    Just wondered. When OEM coils are used with 5100's there's oftentimes some funky handling that goes along with the setup. A heavy tire and wheel are almost a requirement. Have you driven it yet?
  13. Jul 12, 2021 at 1:09 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    more about this. Ive got 3rd gen tacoma take offs i wanna use, that are 2” longer, but softer. How much is tire weight goint to affect my options on the road? I can fine tune the weights for balance, but theres more than a pound @ 31’s vs (fatter) 33’s right?
  14. Jul 12, 2021 at 1:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Started radiator drain, flush, and fill this morning. Pics on build thread.
    bmf4069, Desert Dog and FirstGenVol like this.
  15. Jul 12, 2021 at 1:19 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    I'm curious how you made a custom grill?
  16. Jul 12, 2021 at 1:34 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Turn the adjusters in a bit, then while the rear wheels spin, hammer the parking brake on/off until both sides ‘clunk’ at the same time. Maybe or maybe not it helps to have it in reverse? I always do it in reverse.
  17. Jul 12, 2021 at 1:37 PM
    Desert Dog
    I'm sure there is more than a 1lb difference in all 31's v 33's. I know the 33" BFG KO2's on my Jeep are significantly heavier than the 31" BFG KO2's I took off. I'm not understanding your question about your road options though. Can you be more specific?
  18. Jul 12, 2021 at 1:39 PM
    Desert Dog
    Got my lower radiator shroud installed and the rest of my parts in for the exhaust manifold change. Now I just need a full day off to do it.
    Filthyphil and BubbaW like this.
  19. Jul 12, 2021 at 2:20 PM
    Legender
    Legender New Member
    Carlton
    DFW
    None yet.
    Interesting... I've not heard this. No, just got the call that the shocks are ready so will try to carve out some time tonight to install. Will keep you posted. Thanks.
    Desert Dog[QUOTED] likes this.
  20. Jul 12, 2021 at 4:17 PM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    I do it this way too. I also tighten the adjusters with the star wheel until the parking brake engagement is solid and positive.
    Tundra2 likes this.
  21. Jul 12, 2021 at 5:15 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Something tells me I should check the Knoxville news in a few more weeks when the 3 musketeers get together :facepalm:
    bmf4069, Tundra2, Darkness and 3 others like this.
  22. Jul 12, 2021 at 8:37 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    1st thing I saw was the grill & thought (1st gen) Tacoma. Glanced at the truck attached to the grill & thought "That Tacoma looks big - why?"
  23. Jul 12, 2021 at 8:53 PM
    Desert Dog
    Yeah, 5100's are designed for heavier unsprung weight. If you have the clip set at or below the 3rd setting you may like the ride. Feedback would be welcomed after you drive it. Thx.
  24. Jul 12, 2021 at 9:05 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Drove my truck about 1200 miles between Saturday and today. Saw trans temps get pretty high, steady 165 on the highway in 113 degrees weather and as high as 189 up the grapevine at 106 degree weather. Gonna replace trans fluid this week if I can, planning to do the same drive August 30th.
    oscardog86, des2mtn, bmf4069 and 2 others like this.
  25. Jul 12, 2021 at 9:11 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’ve never driven the Vine, but herd about it. When I had the scan gauge hooked up the to 2010 4runner; going up a long slow climb(off roading, 2wd but in low gear) I got temps into the 210+ area! I’m really glad I had amsoil full synthetic WS fluid in there. There is no external cooler on the 5thies, but after seeing those temps it makes me want to add one! I’m always pleasantly pleased when I see the low temps in the truck.
    bmf4069 and Darkness[QUOTED] like this.
  26. Jul 12, 2021 at 9:16 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The vine going south is seriously hard on cars. I always see people overheated not even 1/4 of the way up. Going north is not nearly as strenuous. In winter it snows there often and becomes a nightmare, they tend to close it.
  27. Jul 12, 2021 at 9:35 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Are you guys talking about the pan temperature or the torque converter temperature?
    TRDGen likes this.
  28. Jul 12, 2021 at 9:38 PM
    FrenchToasty
    Mo
    Bone stock
    Usually you want to look at pan temp
    the pan temp is a general temp of the entire fluid that coming back from the cooler. The converter temp is all over the place because it locks and unlocks, so it’s hard to get a baseline off the converter I guess?
    onesojourner[QUOTED] and bmf4069 like this.
  29. Jul 12, 2021 at 9:39 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    How do you monitor trans temps?
  30. Jul 12, 2021 at 9:41 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Scanguage2 has a setting you can program to see trans temps.
    TRDGen[QUOTED] and FrenchToasty like this.
