Wes' Tundra
Discussion in '2.5 Gen Builds (2014-2021)' started by TTU19, Aug 14, 2016.
  1. Sep 23, 2016 at 6:48 PM
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
  2. Sep 25, 2016 at 3:07 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Installed the front "Raptor" amber LED lights. Was a pretty easy job, I followed Mike's DIY and was exactly how it wrote it up, so I can't Thank You enough.
    Start by removing the top hood bulge.
    There are three holes underneath that are perfect for this. The middle one you'll have to drill out.
    Buy extra nuts for the three lights and use the one that comes with it as a spacer.
    Cut 2 12" positive and 2 12" negative wires. Use those to extend the far right and far left lights to extend towards the center. Connect all three positive and all three negative together. At this point drill a hole in the back support frame to ground your negative wires.
    Put a connector on the positive and run the positive wire along or through the hood towards the back.
    Use the circuit fuse tap on one of the IGN or headlight fuses.
    Put the panel back on, store your wire and hood bulge back on, done.
    SuperSilverTundra likes this.
  3. Sep 25, 2016 at 3:09 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Also picked up some inserts for the Tundra under the radio. They are not as fine tune as the guy would like so he's working on it. Overall though, really makes it pop and he can do almost any color.
    Here is where you can get the inserts:
    http://www.ebay.com/itm/182286265876
    StormtrooperTK624 likes this.
  4. Oct 12, 2016 at 8:04 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
  5. Oct 12, 2016 at 8:05 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Photo of my 3rd brake lights change to LED:
    SouthBoundSteve and dcsleeper408 like this.
  6. Oct 15, 2016 at 9:26 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Got my reverse lights changed out!
  7. Oct 15, 2016 at 12:08 PM
    PermaFrostTRD
    Northern NY
    @TTU19 I want to do the reverse lights also - how do they interact with the backup camera at night? Does it wash everything out or does it improve visibility?
    I feel like tinting or dimming the license plate lights because they throw a lot of glare on the camera at night. Not sure if LEDs would improve or make it worse.
  8. Oct 15, 2016 at 10:53 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Here is a screen shot. This is from sitting inside my garage, so part of the light is blocked, probably look better out in the open.
    PermaFrostTRD likes this.
  9. Oct 15, 2016 at 10:59 PM
    PermaFrostTRD
    Northern NY
    Awesome! Thanks man. @TTU19
    TTU19[OP] likes this.
  10. Oct 16, 2016 at 8:52 AM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    Where did you get the doer sills?
  11. Oct 16, 2016 at 9:23 AM
    lehminh
    lehminh New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
    Thanks @TTU19! Ordered my inserts.
  12. Oct 16, 2016 at 9:24 AM
    lehminh
    lehminh New Member
  13. Oct 16, 2016 at 1:25 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Sparks Parts online.
  14. Oct 22, 2016 at 10:23 AM
    lehminh
    lehminh New Member
    image.jpg image.jpg Just applied my silver inserts. Thanks for the link!
  15. Oct 22, 2016 at 12:34 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Wes how hard was it to take out the taillights? I want to smoke mine
  16. Oct 22, 2016 at 2:37 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Taking them off, super easy. If you want to open them up, I have no clue.
  17. Nov 1, 2016 at 10:31 AM
    Texan25
    Texan25 New Member
    Todd
    Add TRD Pro grill Add 5100 Bilstein shocks front and back at highest setting Add Toy Tech Shackles on the rear Add Grid GD-1 +15 offset rims Add Toyo Terra Grappler 305/60R18's Add Katzkin leather seats (Original seats were UGLY)! Add rubber bed mat (free from dealership) Add cargo bed lights Add tint (legal) to the windows
    I like the radio inserts, and changing out with the LED's. Will be looking into this with my truck. Also like the Raptor lights in the grill, just not sure I want to be drilling into my brand new truck!!
    woodcan and TTU19[OP] like this.
  18. Nov 1, 2016 at 10:33 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Thanks. For the Raptor lights, its just one little spot that you have to drill out. There are already holes on the bottom, but that middle one has a very thin piece of metal behind it. Very easy to drill it out and doesn't hurt anything.
  19. Nov 1, 2016 at 10:48 AM
    #49
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Will be doing this next.
  20. Nov 1, 2016 at 10:51 AM
    #50
    csuviper
    Broomfield, CO
    You need to copy this to a new DIY thread for others to find. Good writeup.
    Sunnier and TTU19[QUOTED][OP] like this.
  21. Nov 1, 2016 at 10:53 AM
    #51
    Crewmax Chris
    Crewmax Chris Paper Airplane Enthusiast
    Lewiston, ME
    2013 Tundra SR5 DoubleCab
    Your truck looks awesome, Wes!
  22. Nov 1, 2016 at 10:54 AM
    #52
    TheBeast The Beach
    I installed my JDM rear back up LED lights. Great add on.
    how easy is it to install the cargo lights ? don't you have to remove the liner inside to access the bulbs ?
  23. Nov 1, 2016 at 10:54 AM
    #53
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Thanks. I need to get some current photos up. I just blacked out the bumper ends, added a hood decal and installing the TRD grill today or tomorrow. Been waiting to do all that to post new photos and write up.
    Crewmax Chris[QUOTED] likes this.
  24. Nov 1, 2016 at 10:56 AM
    #54
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Nope, just pop off the lens cover. There is a metal plate behind it as well, so be aware that its there. Bulbs where simple to change, then put the metal on and lens cover. I had to play with it just a little to make it all line up or something. The button wasn't working on one, but eventually I guess it all lined up. Has worked flawless every day since.
  25. Nov 1, 2016 at 10:58 AM
    #55
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Thanks! I'll do that, just put it under mods and Tutorials?
  26. Nov 1, 2016 at 11:00 AM
    #56
    csuviper
    Broomfield, CO
    Add under General Tundra Discussion. Here i will help you. Hang on a sec.
    Sunnier likes this.
  27. Nov 1, 2016 at 11:08 AM
    #57
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Well figured I'd go ahead and post these. I had to order a new Hood Decal because the one I ordered first came in 2 pieces. After putting it on there was a slight gap and that's not going to work. But you get the idea from the photos.
    Also platidipped my bumper ends, which came out perfect! Took out the fogs and tapped off the surround and started spraying:
    End result:
    Oh and also did the cup ring:
    More pics...
  28. Nov 1, 2016 at 11:09 AM
    #58
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Added my flag decals:
    Looks backwards but I wanted the "pole end" to act like if I was driving down the road and these waving.
  29. Nov 1, 2016 at 11:11 AM
    #59
    csuviper
    Broomfield, CO
  30. Nov 1, 2016 at 11:18 AM
    #60
    TheBeast The Beach
    btw to remove plastidip overspray I use Goo Gone. Works great.
