Want to learn how to properly lube the drive shaft in my Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1999cutiger, Aug 12, 2018.
  1. Aug 28, 2018 at 5:41 AM
    #91
    GreatAvalon
    GreatAvalon New Member
    2016 Tundra Limited DC
    I use a Lincoln grease gun with the flexible whip like @B737 said. I also use NGLI #2 Amsoil grease. It’s purple, cool. It’s grease, cool. It’s the specs Toyota calls for, cool. Any would do that matches what the requirement is.
    B737 likes this.
  2. Sep 16, 2018 at 1:20 PM
    #92
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
    No one posted torque specs for the "propeller" bolts. I'm in the middle of some overdue maintenance & would like to get this done before the hurricane washes us away, lol. Been searching my manuals, the web & this forum & came up with a dry hole so far. Has anyone done this?
  3. Sep 16, 2018 at 1:53 PM
    #93
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @crishard
    I see no one answered this. Here’s my perspective, all ujoints should be greased. If they did not come with zerks, you can add them. If they don’t have plugged and threaded holes for zerks you can drill and thread them or replace the ujoints with some that are greasable.
    You can probably run 20K to 30K miles without grease and not do damage. I would not recommend this.
  4. Sep 16, 2018 at 2:12 PM
    #94
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I have a 2000 f150 4x4 that has the non serviceable joints with 250k miles and the original driveshaft still works great. My previous two ford broncos had a serviceable driveshaft and i had to replace those joints multiple times over their life. Not sure serviceable is better, maybe joints are built better and avoiding improper grease use and damaged seals is a pro. I personally feel better servicing the joints but my experience as far as longevity has been better with the non serviceable.
    1794TexTako and gosolo like this.
  5. Sep 16, 2018 at 5:41 PM
    #95
    j2007
    j2007 New Member
    VA
    2017 DC Bronze Limited TRD
    Full Debadge, TRD Antisway, Platinum Grille, Baja Designs Squadron Sport Fogs, Morimoto MLED Headlight Retros, Tekonsha P3 Trailer Brake Controller with dash mount, Front Tint, Tyger Tonneau Cover, Anytime Fogs, FRAC, Fortin Evo One Remote Start, 12 Volt Bed Power Socket
    The answer to this would probably help a lot of us DIYers/stealership avoiders. Maybe cross-post the question in the “ask the Toyota mechanic” thread and see if @LOTSOFTOYS knows the answer.
    https://www.tundras.com/threads/ask-the-toyota-mechanic.2404/page-43#post-783492
  6. Sep 16, 2018 at 9:06 PM
    #96
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    Got my hands on a toyota repair manual for a 2015 tundra. I've found zero differences between my 2014 and this 2015 in all work I've done to my truck thus far.
    4x4 only:
    -Front prop shaft bolts (8x): 59 ft/lb
    -Front prop shaft heat insulator (2x): 12 ft/lb
    2 Piece Rear Prop Shaft:
    -Carrier bearing bolts (2x): 30 ft/lb
    -Rear diff prop shaft bolts (4x,): 52ft/lb
    -Carrier bearing lock nut (1x): 94ft/lb - this nut is only accessible by dropping the carrier bearing and separating the intermediate and rear driveshafts. it sits inside the rubber housing of the carrier bearing.
    -Trans side prop shaft bolts (4x): 52ft/lb
    https://cardiagn.com/propeller-shaft-2015-tundra/
  7. Sep 17, 2018 at 3:54 AM
    #97
    j2007
    j2007 New Member
    VA
    Thanks for the info. I also didn’t mean to sound like all dealerships are bad. There are some good ones, especially those that help out on this forum. But once Toyotacare is over, my local dealer’s charges for basic services are incredibly high and I’ll be doing this kind of routine maintenance myself.
  8. Sep 17, 2018 at 1:37 PM
    #98
    crishard
    Cris
    The gen 2 flange bolt specs are the same. I found those but wasn't sure if I could use them. Thanks for the info
  9. Sep 27, 2018 at 7:05 AM
    #99
    jtwags
    League City, TX
    2018 Tundra CM
    Thought this would be informative in regards to the greasable vs non-greasable universal joints, at least the moog brand. I was looking for a set of joints for an older Tahoe for the mil and wasn't sure if I should go gresable or non-gresable. I think i am going with the non-greasable since it gets serviced at quick lube places and I bet they don't always fully wipe the zerk before pumping grease. Appears the non-gresable joint is a solid cast vs gresable, probably better for towing applications as it may not twist as much under heavy load, but just conjecture.
    Watt maker likes this.
  10. Sep 27, 2018 at 7:15 AM
    #100
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    I'd rather have greasable, but we'll see. This is my first truck where the joints were sealed.
  11. Sep 27, 2018 at 7:15 AM
    #101
    Fixing to change very rear and very front and 4wd u joints soon on T100
  12. Oct 16, 2018 at 3:01 PM
    #102
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Anyone have an 18' with zerks?
    I have crawled under the truck 2 times to confirm no grease fittings on any of the u-joints
    WAtundra4x4 likes this.
  13. Oct 16, 2018 at 6:41 PM
    #103
    Wolverine
    Wolverine New Member
    Jeff
    Michigan
    2019 SR5 CM Cement
    I have an 18 CMax 4x4 and no zerks. Looked twice.
    OHwendTrd likes this.
  14. Oct 19, 2018 at 10:41 AM
    #104
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    I read this thread a while back and got grease, but never got around to actually using it. Well today I went to grease my 2018 and it doesn't have the zerks either.
    OHwendTrd and WAtundra4x4 like this.
  15. Oct 19, 2018 at 2:30 PM
    #105
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I just did mine last week, 2017 4X4 CM SR5. There are three in the rear prop and two in front prop.
    15whtrd likes this.
  16. Nov 6, 2018 at 8:03 AM
    #106
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    I couldn't find a single grease zerk on my 2018 4x4. What's up with that.
  17. Jan 22, 2019 at 10:11 PM
    #107
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    So can we confirm that the 2018's are sealed? They are unable to be greased?
    Literally was about to go out and get the stuff to do the job, luckily I did a quick search
  18. Jan 22, 2019 at 10:24 PM
    #108
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I just looked at my 2019........no zerks. I can confirm that that the 2019 has sealed U-joints.
    Based on posts from others it appears the 2018 has sealed U-joints as well.
    EDDO likes this.
  19. Jan 22, 2019 at 10:32 PM
    #109
    iamsmokey
    Oahu, HI
    So there are no zerks on the 2018’s or are there a couple, and if so where?
  20. Jan 22, 2019 at 10:42 PM
    #110
    csuviper
    Broomfield, CO
    Could not find a single zerk on any of the u-joints, front and rear drive shaft on my 2019
    There were zerks on all 5 of the u-joints on my 2012.
  21. Jan 22, 2019 at 10:49 PM
    #111
    iamsmokey
    Oahu, HI
    Hmmmm I don’t know how I feel about it but less maintenance? I notice in the 2018 manual it says only torquing the propellor shaft, nothing about lubricating
  22. Jan 23, 2019 at 12:16 AM
    #112
    iamsmokey
    Oahu, HI
  23. Jan 23, 2019 at 10:07 AM
    #113
    matictundra
    Franco
    AZ
    My 2017 has 5 u-joints grease zerks. I believe this was discussed here before, 2018+ have no grease zerks.
  24. Jan 23, 2019 at 10:53 AM
    #114
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    must have changed some time during the 2017 model year. I have not checked the front but I have none on the rear. I looked 3 times if you count the time I looked and then moved the truck slightly and looked again.
  25. Jan 23, 2019 at 12:17 PM
    #115
    iamsmokey
    Oahu, HI
    I saw the earlier posts, just wanted someone to confirm. I guess with no zerks, I’m unable to grease unless I were to drill and put my own which I won’t haha
  26. Mar 25, 2019 at 8:14 PM
    #116
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    I figure the 3 rear zerks are on each of the u-joints on the driveshaft for a 2017? I couldn't find anything on the rear of mine. The two fronts we're easy enough to find and grease.
    I'm wondering if they didn't have zerks on the end of the year builds. As we bought our truck mid 2018.
  27. Apr 15, 2019 at 1:08 PM
    #117
    kw819
    kw819 New Member
    so is the needle used for the zerk on the very front? I was able to get the gun on the zerk but every time O pumped the grease is just came out where the zerk was, and yes i cleaned off the old paint. I also couldnt get the damn zerk on the middle one for the life of me.
    EA08BEFF-8084-4B00-897E-829B425A2B4D_zps_18cb9601fbd458005537da79bd053f7b785b0fa0.jpg
    trips222 likes this.
  28. Apr 15, 2019 at 2:49 PM
    #118
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yep, that’s what I found on my ‘15 Pro.
    It’s possible that some grease gun lube connectors will fit, but I tried 3, without success. The needle works fine for me.
  29. Apr 15, 2019 at 2:53 PM
    #119
    kw819
    kw819 New Member
    for the one at the very front? I found other people saying for the one in the middle that you have to come at it from a different angle, so I may try that this weekend, and hopefully ill find a needle by then.
  30. Apr 15, 2019 at 3:11 PM
    #120
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @kw819
    I’m pretty sure that is the one, but it’s been a while and it’s muddy out there right now so I’m not gonna crawl underneath to check
