Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Aug 16, 2018 at 6:53 AM
    #1201
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    @LOTSOFTOYS what is the purpose of antifreeze going to the throttle body on a 3rd gen?
  2. Aug 16, 2018 at 12:23 PM
    #1202
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    Supercharged, TRD Dual Exhaust, Bilstein 6112's/5160's, TSS wheels, Toyo AT Xtreme 285/60R20, LED bed lights, Hellwig sway, PopNLock tailgate lock
    @LOTSOFTOYS Trans temperature question: Trying to see what the TF1 and TF2 normal temperature ranges are, just starting to monitor mine with a Ultra Gauge. My supercharged 13 (Canadian) tundra shows a trans temperature higher than dead center for any temp over 150 (could be a bad gauge / or mis aligned as the speedo was changed when it was imported back to the US).
    Is TF1 the pan and TF2 the torque converter?
    Towing a pop up to leadville last weekend and I saw the TF2 get to 225F, but the TF1 never went to more than 203F. Normal lockup in 4th for TF2 appears to be between 160-190 depending on load and incline. I had the thermostat pinned open, I need to confirm it still is. Gauge in cluster never moved for the above temps. What is considered TOO HOT for which sensor.
    Can I replace the sensor that shows on the cluster to get it back to center?
  3. Aug 28, 2018 at 5:22 PM
    #1203
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Lotsoftoys, quick non tundra ?. Wife’s 2013 Camry 4cyl has 98k miles. I scheduled service to do timing belt. Did a little research and it looks like it has a timing chain.
    Is this correct, chain not belt??
    If so I shouldn’t have to do anything w it in regards to timing chain right?
  4. Aug 29, 2018 at 12:40 PM
    #1204
    CZTundra
    CZTundra New Member
    13 Tundra 4x4 CrewMax 8' box
    Lotsoftoys, any ideas?
    Posted in the general thread too: I have never had any mechanical issues with my work truck until about a month ago, when transmission started noticeably slipping on my 2013 Tundra (at 88K miles). Luckily still under "platinum" warranty. Took it to the dealer, two days later dealer confirmed that the truck needs new transmission. Allegedly transmission was replaced with a "refurbished" one. A week later I get my truck back and drive about 20 miles away from the dealership when the truck starts acting up again. The acceleration is lagging and the truck is super jumpy. I nearly stalled twice on the freeway on my way back to the dealer. They take the truck back. A week later they call me and tell me that the problem is due to uneven thread wear (I had recently replaced a flat tire). This made no sense to me, because my truck is 4x4. As far and I know, this only applies to symmetrical all wheel drive. Anyway, they put new tires on my truck and let me drive around for a couple of days thinking that it would solve the problem. It did nothing. They scratched their heads and sent me home. According to their road tests, the new transmission is shifting fine and there are no other error codes present. They claim they could not replicate the problem on their test drive.
    The truck is not safe to drive and I need it for work, so I took it to a different dealer. Went on a test drive with them, felt the problem twice. They have recorded the test drive data, but cannot pin point the problem. At this point it's been over a month, nobody can find the problem. I have reached out to corporate, opened a case requested they send an engineer. I take care of my truck, all recommended services have been done at the appropriate times. Any ideas?
  5. Sep 5, 2018 at 7:45 AM
    #1205
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    I have a ticking after start up in the morning. Outside temp is mid 80’s. The ticking starts a few minutes during warm up, I rev a little and the sound goes away, not to return until the next morning. I changed the oil a month ago, used Toyota filter and Mobile 1 0w20 synthetic. Fluid levels are correct.
    Any idea what is causing the noise? 2016 5.7 with 17000 miles.
  6. Sep 5, 2018 at 7:24 PM
    #1206
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The engine is inherently, mechanically noisy. There's a lot going on in the top end of the engine. There have been discussions on the matter in other threads and that's pretty much become the consensus. Some have calmed their uneasiness by running heavier oil.
  7. Sep 9, 2018 at 7:03 AM
    #1207
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    T case input seal? The tcase needs to be removed. I'd also do the trans output deal while you are there.
    Coolant is ran through every throttle body on toyotas... im assuming because they want the throttle plate to be warm.
    The cluster is likely just a signal from the ECB. Maybe an average of the two? Why are you pinning the tstat for the trans open? Let the truck be how it was designed.... itll work just fine. As for temps, 225 F is getting up there. What was your coolant temp at the time? I've had mine that high pulling birthoud pass a couple times. I start paying attention around 215 or so. The hotter temp is always the sensor closest to the torque converter
    Drive the bitch;)
    Your description is too vague, what exactly happens?
  8. Sep 9, 2018 at 7:17 AM
    #1208
    Warreng
    Warreng New Member
    @LOTSOFTOYS, I have a used 2013 tundra. Was using 4lo for first time recently, it sounds “whiney” at 10mph, is that normal? Dont remember that from previous trucks in 4lo.
    Thanks for your time.
  9. Sep 9, 2018 at 7:52 AM
    #1209
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    @LOTSOFTOYS
    "The cluster is likely just a signal from the ECB. Maybe an average of the two? Why are you pinning the tstat for the trans open? Let the truck be how it was designed.... itll work just fine. As for temps, 225 F is getting up there. What was your coolant temp at the time? I've had mine that high pulling birthoud pass a couple times. I start paying attention around 215 or so. The hotter temp is always the sensor closest to the torque converter"
    I have it pinned due to the high temps that I see around town. Seeing up to 208f just driving around town at times. What temp does the tstat open? Would I be better using a different cooler, as my 13 has the one integrated into the a/c condenser where previous sequoia and tundra had a separate large cooler? Also the cooling may be reduced as i have the supercharger radiator that sits infront of the A/C condenser. I just don't want to fry my trans! Scheduling a service the week of the 17th.
  10. Sep 9, 2018 at 7:53 AM
    #1210
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Check the fluid level just to be sure, but mine does this as well, even with the Sequoia T-case. It's just mechanical noise.
  11. Sep 9, 2018 at 12:27 PM
    #1211
    BassRunner
    BassRunner New Member
    Kenny
    Lexington. South Carolina
    2018 Limited
    I'm sure this has been asked before. I have 2018 Limited will it void any warranty if change the exhaust ie. the muffler.
    Thanks kenny
  12. Sep 10, 2018 at 7:56 PM
    #1212
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Normal gear/chain noise
    So u dont have the tow package cooler then. Could add one wouldn't hurt. Just have it serviced on time
    Itll be fine
    Nope
    NewImprovedRon likes this.
  13. Sep 16, 2018 at 10:05 AM
    #1213
    Motofun
    Motofun New Member
    Nate
    Great White
    2013 Tundra: 6" RC with icon coils 3" BL 37x20x13.5 toyo shoes Nfab pusher ARB 10" spot lights x3 Custom headlights Spyder LED taillights Smoked 3rd brake led 50" Ridgid roof mount bar 30" ridgid bumper bar 4.5" ridgid fog light swap Starry night halos Flashtechusa halo kit RGB+W rocklights Custom white diamond leather seats Heated seats front and rear +3 shackles (CB) Steering kit (CB) Shims (CB) OME dakar leaf pack KN CAI Rhino lined bed ICI magnum foot steps
    What's code PO113 and how do I fix it
  14. Sep 16, 2018 at 2:42 PM
    #1214
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  15. Sep 17, 2018 at 7:22 PM
    #1215
    Giants916
    Giants916 New Member
    B
    2011 Blk Rock Warrior DC
    Anybody know the amperage if this alternator? I'd really appreciate it... can't seem to find anything.. I've heard 150 and 170.. thank you!15372372590494976256021870691027.jpg
  16. Sep 17, 2018 at 7:37 PM
    #1216
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    Giants916[QUOTED] likes this.
  17. Sep 17, 2018 at 7:40 PM
    #1217
    Giants916
    B
    Well thank you, last week on this site I was reading a thread about 2nd Gens and a few guys agreed 170 amp if you had a tow package.. I'm putting in 1600 watts worth of JL amps and was concerned I might cook the alternator.... still not sure.. I do have the Big 3 to install
  18. Sep 18, 2018 at 2:32 PM
    #1218
    eperm25
    eperm25 New Member
    I have a 2015 Tundra. I removed the battery terminals yesterday to clean them up a bit and remove some of the build-up that was on them. After I reconnected them and took my truck for a drive, I noticed the transmission was really jerky. There is a delay on take off, and when she changes from 1st to 2nd, and then from 2nd to 3rd. She is also unable to get our of third gear, even when I switch to the manual mode.
  19. Sep 18, 2018 at 2:32 PM
    #1219
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    When I pick up my 2018 SR5, do I need to do anything else other than ask them to update the firmware to avoid the IBC from disconnecting my trailer brakes on I70?
    Thanks for answering questions.
  20. Sep 18, 2018 at 6:35 PM
    #1220
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Never heard of this?
  21. Sep 18, 2018 at 6:42 PM
    #1221
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Question for you -- when I apply the brake I get a whirring sound coming from the right side as I sit in the driver's seat. Any clue what that is? Started very recently and goes away when I put the truck in neutral and/or let off the brake.
    Thanks
  22. Sep 18, 2018 at 6:52 PM
    #1222
    sbxx312
    sbxx312 New Member
  23. Sep 18, 2018 at 6:55 PM
    #1223
    trdprobped17
    trdprobped17 New Member
    My I gave my 2010 CM to teenaged son to drive and approximately 4-6 months later, it started to have a grinding vibration coming from the tranny whenever the gear changes from high to low, or sudden acceleration. In addition, the truck is very hard to move from “Park” to reverse. So, I took it to my local Toyota dealership and the told me that the problem existed with a faulty tranny neutral switch. Plus, the tranny needy a flush.
    I agreed to have those services performed on my truck and the problem went away for about 6 months. But, now it’s back. What could it possibly be that’s causing the problems?
  24. Sep 19, 2018 at 10:55 AM
    #1224
    Giants916
    B
    I'm no master mechanic but I'd definitely go with a normal pan drop transmission service and not a "flush" if you haven't had a flush in the past on the vehicle. Even then, I'd still just do the pan drop. I've heard too many transmission flush horror stories
    trdprobped17[QUOTED] likes this.
  25. Sep 19, 2018 at 11:11 AM
    #1225
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Weather permitting, I'm going to be upgrading front and rear shocks, springs, shackles and doing a diff drop this weekend. Any tips, tricks, or gotchas I should know about before getting started?
  26. Sep 19, 2018 at 11:45 AM
    #1226
    trdprobped17
    I had the pan dropped and the flush done with the very same dealership last year. But, now, the same problem has returned.
  27. Sep 19, 2018 at 1:20 PM
    #1227
    Trebor57
    Trebor57 New Member
    Rob
    Sacramento, CA USA
    2018 Toyota Tundra SR Double Cab - 2-wheel drive
    I have a 2018 Tundra Double Cab SR, it doesn't have the Lane Departure Assist (whatever it is called), so, how hard is this to add to my truck?
    Does any of the wiring exist or anything else already which could make it "Plug and Play"? I know adding the fog lights and switch was easy as everything already existed on the truck.
    Thank you
  28. Sep 19, 2018 at 1:35 PM
    #1228
    sprtbkr
    Scott
    Denver, CO
    I've seen front facing dash cameras that feature lane departure warnings.
  29. Sep 24, 2018 at 5:23 AM
    #1229
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Not sure man... would have to feel it. Go back and show them it has returned
    Watch youtube
    No u cannot add it
  30. Sep 24, 2018 at 6:33 AM
    #1230
    Sas
    OKC, OK
    Thanks. Found cat videos. Got confused. Dick stuck in spring. There actually wasn't a whole lot of useful info about installing this stuff on our trucks so had to figure out most of it as I went. Got a lot of help from some folks here on the forums and from @M C M as well though.
