Want to learn how to properly lube the drive shaft in my Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1999cutiger, Aug 12, 2018.
  1. Aug 12, 2018 at 6:48 PM
    1999cutiger
    1999cutiger [OP] Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    My 2017 Tundra is my first 4x4. I like to do as much of the routine maintenance as I can. I am coming up on 10,000 miles. I don’t have any experience with lubricating the drive shaft and I am hoping you guys can walk me through it. What kind of grease to use, how to know when the grease zerk is full, grease frequency, how many zerks need grease, etc.
    I understand one of the rear wheels needs to be jacked off the floor so the drive shaft can be rotated as needed.
    Thanks in advance for all of your help...
    Occidentalis and mdavis like this.
  2. Aug 12, 2018 at 7:01 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    NGLI No. 2 lithium base, grease until all seals purge, I do it every oil change, and I've never had to jack the rear wheels up. The front driveshaft can be a pain; there's a little debris shield to the driver side of it.
    https://www.youtube.com/watch?v=wH-fvddVt-g
  3. Aug 12, 2018 at 7:03 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    This could derail very quickly....
    I have only done mine twice so I dont recall exactly. I think there are 6 zerks. I used whatever grease the manual recommended. I pump it in until I notice a little starting to squeeze out. Do it every oil change and I haven't needed to jack it up to do it, theres enough play in the shaft to reach all the fittings.
    I'm sorry that isn't all that helpful.
  4. Aug 12, 2018 at 7:05 PM
  5. Aug 12, 2018 at 7:07 PM
    1999cutiger
    That is extremely helpful...thank you.
    How many zerks need to be filled...front and rear?
  6. Aug 12, 2018 at 7:09 PM
    computeruser6
    Dirk
    Escondido
    My Tundra has a one-piece driveshaft in the rear so I only have four. I think that all other configurations have a two-piece driveshaft so you may have more.
    omgboost likes this.
  7. Aug 12, 2018 at 7:10 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    On mine you have to use something like this, to access 1 of the zerks .
    TTund16 and Black Wolf like this.
  8. Aug 12, 2018 at 7:15 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  9. Aug 12, 2018 at 7:18 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Mobil 1 synthetic red is in my grease gun.
    It's what I use on all my machinery so hopefully it is ok for the tundra.
    Just looked it up...it is a #2 so I'm good.
    Ajkkane likes this.
  10. Aug 12, 2018 at 7:21 PM
    1999cutiger
    Do you use two different kinds of grease?
    DZ_ likes this.
  11. Aug 12, 2018 at 7:25 PM
    csuviper
    Broomfield, CO
    No
  12. Aug 12, 2018 at 7:27 PM
    1999cutiger
    OK...thank you.
    Is Mobil 1 (red grease) a good choice?
    Ajkkane likes this.
  13. Aug 12, 2018 at 9:46 PM
    csuviper
    Broomfield, CO
    You should be good with any main brand as long as its lithium base NGLI No. 2
    I ignore the molybdenum disulphide part for the double-caran joint.
    Ajkkane likes this.
  14. Aug 12, 2018 at 9:54 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I need to do this. So much truck stuff to do!
    SouthBoundSteve likes this.
  15. Aug 13, 2018 at 8:05 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  16. Aug 13, 2018 at 8:14 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    @GNTundra is an expert on lubing his shaft. :devil:
    Randydw, chugs, Inquiringone and 5 others like this.
  17. Aug 13, 2018 at 8:38 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    X4.....or 5ish....
    Have done this on every truck, every oil change. This is also when I get underneath with some CRC SP-400 and hit all of the normal rust areas (although I am starting to experiment with some PB Blaster Corrosion Stop)
    I like CAM2 products for grease. Used them a lot in a commercial/industrial environment at my last job.
    I use CAM2 ULTRA580EP#2 on almost everything now. Driveshafts, trailer bearings, ball joints, suspension linkage on dirt bike...It's the only grease I have purchased for a few years now.
    Sas likes this.
  18. Aug 13, 2018 at 8:47 AM
    Sas
    OKC, OK
    Grrr, have to fill in a form twice to just get a quote for a couple of tubes of this stuff. :annoyed:
  19. Aug 13, 2018 at 9:02 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    My mom-and-pop Carquest in town carries it. Not sure if all Carquests do. At my last place of employment we ordered in bulk from a Cam2 distributor, this was in PA. I don't believe it's available anywhere else on the open market (grainger, Amazon, msc...)
  20. Aug 13, 2018 at 9:28 AM
    Sas
    OKC, OK
    We don't have those here (it's Advance Auto) and unfortunately they don't seem to carry it. Found another one w/moly as well from Valvoline. Edited my post above.
    prevent likes this.
  21. Aug 13, 2018 at 9:33 AM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    Put it in neutral, apply parking brake, and chok a wheel then you can spin your drive shaft.
  22. Aug 13, 2018 at 3:40 PM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    i highly doubt dealers take the time to do this. i do it every other oil change too. i swear my junk came from the factory without any grease in the fittings. getting them to purge took a lot of grease, then not much was needed on subsequent oil changes.
    purchased this gun locally at tool supply
    Lincoln Lubrication 1134
    https://www.amazon.com/dp/B0002NYDZ8
    15whtrd, TTund16 and Sas like this.
  23. Aug 13, 2018 at 4:49 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    I'm really impressed with our collective self control. With a title like this I expected it to be derailed immediately :rofl:
    15whtrd, MotoTundra, mtTundra and 2 others like this.
  24. Aug 13, 2018 at 5:24 PM
    Sas
    OKC, OK
    I grin a little when I see this post come up, but the title is too easy. I hit the low hanging fruit sometimes, but there's no sport in it when you're hitting lobs all day lol.
    15whtrd likes this.
  25. Aug 13, 2018 at 6:02 PM
    Professional Hand Model
    Hand Protectors
    Mobil 1 has great products. I use the STP moly b lith. The rear four zerks are easily serviced. Pump till the grease flows out the bushings which pushes all that dirt out too. The front two on the 4wd prop will not accept grease. Maybe need the needle?
  26. Aug 13, 2018 at 11:11 PM
    TTund16
    TTund16 New Member
    It says "lubricate propeller shaft and tighten bolts" ...
    Do you know the torque spec on these bolts? Are they 21mm or 25mm bolts?
    Rex Kramer likes this.
  27. Aug 14, 2018 at 6:03 AM
    Sas
    OKC, OK
    BTW, from where did that screeny come?
  28. Aug 14, 2018 at 6:38 AM
    csuviper
    Broomfield, CO
    google search
    nlaroy likes this.
  29. Aug 14, 2018 at 6:57 AM
    Sas
    OKC, OK
    Looks like it was from an '07 manual of some sort. Would like to find a more recent version if possible.
  30. Aug 14, 2018 at 7:15 AM
    csuviper
    Broomfield, CO
    @Nor7 can you help with this?
