Valve covers, fix or leave
Discussion in '1st Gen Tundras (2000-2006)' started by 04DCTundraMan, Apr 2, 2022.
  1. Dec 12, 2022 at 9:40 AM
    shifty` One great big festering neon distraction
    IIRC, PCV valve is something on the maintenance schedule to check every 5k and replace every 20k? I can't recall for the life of me which it is. Usually if you pop it off and shake, if it rattles, it's typically good. With how varnished my heads were, I replaced around the same time as my VC gaskets.
    @txagg had a field day snapping off VC bolts. But mine came off clean. If you're in a salty/rusty area, I'd warm up the engine with a 15-20 mile drive, then tighten 1/16-1/8 turn before backing out. If you apply direct heat, you'll burn the rubber/steel combo washer, but you should replace anyway, with the bolts - I put part number for an inexpensive package for those in reply # 18.
    Weagle likes this.
  2. Dec 12, 2022 at 7:12 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    On the earlier first gens the PCV presses into a grommet somehow and that grommet gets hard over time. I've heard of people loosing pieces down into the valve cover when trying to remove the PCV. For this reason I haven't touched mine and have no clue how bad it is. I don't think it's worth the risk.
  3. Dec 12, 2022 at 7:41 PM
    I hear you on that. In this case, it's something I'd do while doing the valve covers if your concern levels are higher. If the valve cover is off, no risk involved, then you have a set date on when the maintenance was done, and can re-perform at comfortable intervals.
  4. Dec 12, 2022 at 7:46 PM
    NickB_01TRD
    Nick
    KY
    I may have missed the primary focus on this thread. Yeah if you're already pulling valve covers definitely knock it out then.
    shifty`[QUOTED] likes this.
  5. Dec 12, 2022 at 8:01 PM
    If it truly is pop-in as you say, as I've seen others say it was, and you wanted to maybe do it more safely, consider using 3-in-1 or similar light oil on the gasket itself a few days in advance, around the base of the PCV. This should help get into the rubber, making it less brittle, and also help break any bond between the metal PCV and the rubber seal. But you'll probably want to have a replacement rubber seal to replace the old one. Toyota p/n: 1119370010 (link)
    It's weird though, I looked up the 2001 AC SR5 part number for the PCV and it shows 1220450030, which is threaded... (see for yourself)
    Most easy to see in the 5th exploded here: https://parts.toyota.com/a/Toyota_2..._51507_6707302/CYLINDER-HEAD/841420-1104.html
    Hard to make sense of it, but it appears they're saying 11202 is the PCV, 11193A is the gasket.
  6. Dec 12, 2022 at 8:04 PM
    NickB_01TRD
    Nick
    KY
    Hmm maybe I need to take a gander again and see but I really thought it was the grommet style "press" in. I think it was 03 when they changed maybe? Not sure now.
  7. Dec 12, 2022 at 8:06 PM
    I've also heard others with '02 and earlier say it was a press-in affair. I just can't argue with what's showing in the parts catalog either. See if you see a hex provision on the PCV. May need to relocate or move some foam. I can't remember what side the foam was on in mine. I damn sure needed to change mine, I don't think it'd been done since the truck was new.
    EDIT: Searching this part number (1220450030 or 12204-50030) here on the forum may lead you to the posts from the past where someone mentioned that wasn't the right part for earlier model. I'm just confused why that would be the only PCV in the OEM parts catalog for your year if it wasn't the right part.
  8. Dec 12, 2022 at 8:09 PM
    NickB_01TRD
    Nick
    KY
    I wouldn't be surprised if mine was original. Hell my spark plugs were more than double the gap they were supposed to be. No timing belt record. Think the last guy just drove it and changed the oil. To be fair though, no issues related to anything I could think of that would be caused by a bad PCV.
  9. Dec 12, 2022 at 11:40 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 340k+
    2” Lift, Bilstein 5100’s and 885’s, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags with Daystar Cradles. Spider Trax 1.25” Wheel Spacers, Factory Wheels wrapped with Toyo 285/70r17 AT2’s.
    I did the job a few months ago on my 99’ Taco, PCV grommet was crusty, I popped it out in pieces with the valve cover upside down.
    I’m glad my Tundra‘s is threaded.
  10. Dec 13, 2022 at 4:35 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    I'd be willing to bet they're all loose if nobody's been in there before. I snapped one of mine, but it was while tightening. It's on the top side so I haven't messed with it.
  11. Dec 13, 2022 at 9:47 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Oh yeah.... I think I was able to get maybe half of the bolts out without breaking. Then the others I had to drill and tap.
    pictures of this debacle in my build thread...
    I don't remember removing anything to gain access.
    I would start with penetrating oil and some heat. S L O W L Y start backing the bolt out and if it moves, start to tighten it up again, just to work it loose. Keep dowsing it with the penetrating oil, and you might get lucky. If not, you can always drill them out.
    I have a 90 degree cordless drill, which really helps make this job go easier. Buy a good set of bits and go at it slow and steady. They all may come out without breaking!
    The VC removal starts here;
    https://www.tundras.com/threads/my-...epair-modify-thread.71679/page-7#post-2058838
    w666 and bmf4069 like this.
  12. Apr 3, 2023 at 7:02 PM
    Jdtuned
    Jdtuned New Member
    Jorge
    SoCal Whittier
    01 AC sr5 4.7 2wd
    No mods besides regular maintance and up keep. Required to carry 200lbs of tools for work.
  13. Feb 16, 2024 at 10:23 PM
    ToyotaDude
    ToyotaDude New Member
    2003 Tundra AC V8 4x4
    Will be doing mine too. Have had short term success retightening but just planning that until gathering parts and finding time for the job.
  14. Mar 8, 2024 at 11:22 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    Shifty, what’s your opinion on tube seals stop seeping after PCV valve replacement if the over pressure was reason for seepage. I have less than 20k on VCG pcv valve was not done then and it has 210k
  15. Mar 8, 2024 at 6:52 PM
    I mean, if your PCV valve isn't working as intended and you build up pressure, the plug tube seals is where I'd expect stuff to leak first.
  16. Mar 8, 2024 at 7:07 PM
    ToyotaDude
    So I think the 2007 uses a threaded PCV so swapping it is straight forward for like $10 and seeing if the leaking stops? If yours uses a grommet then risk is it crumbling at that mileage and falling below the cover when trying to remove the PCV.
  17. Mar 8, 2024 at 7:09 PM
    It's super easy to test functionality. It's a one-way valve, if I'm not mistaken. Pop it off, test. If failed, replace. I replaced mine proactively recently. I want to say the service lifetime on PCV valves is really short from the Toyo maintenance info.
  18. Mar 8, 2024 at 7:13 PM
    MEWaters
    MEWaters New Member
    Maine
    It is threaded and I picked it up from dealership yesterday I plan on doing it this weekend
    ToyotaDude likes this.
  19. Mar 9, 2024 at 9:19 AM
    #49
    MEWaters
    MEWaters New Member
    Maine
    Wasn’t stuck but rattles less than the new one and less movement for sure. I did have oil in my intake line. Positive for some left side tube seal seepage
    bmf4069, JasonC., abcinv and 3 others like this.
  20. Mar 10, 2024 at 2:43 PM
    #50
    meeseeks55
    meeseeks55 New Member
    2002 SR5 Access Cab 3.4L V6
    You can only tighten them for so long until it won't help anymore. Might as well replace it if its already leaking.
  21. Mar 26, 2024 at 3:20 PM
    #51
    Squeakyduck4
    Squeakyduck4 New Member
    Santa Barbara
    06 DC 4x4 V8 TRD
    Is the "grommet" the washer for the bolt?
  22. Mar 26, 2024 at 4:46 PM
    #52
    Yes. It's like a cupped washer with a rubber disk nested in it.
  23. Mar 27, 2024 at 8:03 AM
    #53
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    The rubber disc gets hard and brittle. Toyota sells new bolts with the disc in the cup. Felpro kit includes the disk. Personally I like OEM for my Toyota but I used Felpro for my LS 5.3 and they were good quality. Also be careful not to overtighten those little 10mm bolts as several here have reported snapping them.
  24. Mar 27, 2024 at 9:41 AM
    #54
    Squeakyduck4
    Santa Barbara
    06 DC 4x4 V8 TRD
    @shifty` got this email after ordering the bolts and grommet part number you posted above
  25. Mar 27, 2024 at 10:02 AM
    #55
    Squeakyduck4
    Santa Barbara
    06 DC 4x4 V8 TRD
    Interesting as the pn they posted is 7$ more expensive, each!
  26. Mar 27, 2024 at 11:23 AM
    #56
    Correct. It doesn't match the VIN, those parts are for a V8 4Runner with the exact same engine, so it's 100% compatible. Tell them to go ahead with the order. I ordered all of those parts myself, and confirm 100% compatibility with our '06es. Several others have used the bolt-and-washer combo in theirs and also confirm it. I actually learned about this part from one of the Yota shops online that sells VC gasket kits, they'll work with any 2UZ-FE loaded truck/SUV.
    Squeakyduck4[QUOTED] likes this.
  27. Mar 27, 2024 at 1:56 PM
    #57
    Squeakyduck4
    Santa Barbara
    06 DC 4x4 V8 TRD
    appreciate it man.
  28. Mar 27, 2024 at 5:21 PM
    #58
    bfunke
    South Carolina
    The bag of bolts I have is marked 90080-10330 and has 10 bolts in the bag.
  29. Mar 27, 2024 at 5:23 PM
    #59
    bfunke
    South Carolina
