TPMS tool
Discussion in 'Wheels & Tires' started by Breakaway11, Oct 25, 2016.
  1. Mar 19, 2017 at 12:27 PM
    Ericsopa
    Ericsopa Old man and the sea
    Nope, don't think so. You still have no differential pressure between the sensor and the schrader valve or stem. The sensor has to be on the pressure side and the valve on the ambient side, subject to atmospheric pressure only. The PVC idea would result in all sensors indicating flat tires, because the pressure on the sensor would be the same as the pressure on the valve.
  2. Mar 19, 2017 at 12:35 PM
    LML 3500HD
    Drill a hole then and install like on a wheel.
    AxelsHumanDad likes this.
  3. Mar 19, 2017 at 12:36 PM
    Ericsopa
    Yeah, four holes, one for each sensor, and install sensors like they would be on a wheel. That would work.
  4. Mar 19, 2017 at 12:40 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I wonder if you can change the pressure when the light goes off on techstream. If you can change it to 0, that would probably turn it off. I'll try next time I hook up to techstream. But that would be too easy and I'm sure someone would have found that by now.
  5. Mar 19, 2017 at 12:49 PM
    LML 3500HD
    Yep, several ideas on that thread.
    One guy just taped them together and installed them inside his spare. So the drilling a hole in the pvc pipe is not needed.
    landphil likes this.
  6. Mar 19, 2017 at 12:53 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Well, I'm keeping mine. I need a reminder after airing down. I can see myself driving home a couple hundred miles on 20 psi. :crazy:
  7. Mar 19, 2017 at 1:04 PM
    LML 3500HD
    This video is on a Chevy Malibu, and proves that just tossing the sensors inside the tube works.
  8. Mar 19, 2017 at 2:05 PM
    Ericsopa
    All righty!!! Don't understand it, but I'll concede. :confused::D
  9. Mar 19, 2017 at 3:10 PM
    LML 3500HD
    Not sure how to explain this, but I will try:
    The sensor is on the inside of the TPMS sensor. The Shrader valve just delivers the compressed gas from outside of the tire to the inside of the tire. nothing to do with delta P.
    Here is a good image of the parts breakdown of a TPMS sensor:
  10. Mar 19, 2017 at 3:29 PM
    Ericsopa
    Yep, only thing I can think of is a sealed sensor housing, and a constant fixed pressure inside the housing.
  11. Mar 19, 2017 at 7:47 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That is my understanding of how they work, rather than using barometric pressure as a reference. But truth be told, once you get to what goes on inside a sensor or module, it works on the PFM principle in my mind. That's Pure F@&?ing Magic...
    ColoradoTJ and Ericsopa[QUOTED] like this.
  12. Mar 19, 2017 at 7:52 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Oh, and don't forget to thank Firestone tires and the Ford Exploder for where we are today with TPMS. That IS what started it all.:confused:
  13. Mar 19, 2017 at 7:56 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Ok, but I do feel dumb right now. Somehow I missed the part of the conversation where almost everything I posted in that reply had already been said. Duh! Oh, I bet a beer will help...
  14. Mar 19, 2017 at 8:01 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Really? This is all because of the firestone mess? Damn Ferds!!
    landphil[QUOTED] likes this.
  15. Mar 19, 2017 at 8:13 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  16. Mar 19, 2017 at 8:35 PM
    LML 3500HD
    No, I was being serious. I learned a bunch from you today...and YouTube, Google.
    @Ericsopa started it by asking questions. I like people that question if it doesn't make sense to them. Brought on some good conversation.
    I learn a ton from people on this site everyday.
    Ericsopa and landphil[QUOTED] like this.
