TOTAL CHAOS Long Travel *Discussion Thread*
Discussion in 'TOTAL CHAOS' started by TOTAL CHAOS, Oct 2, 2018.
  1. Nov 28, 2018 at 11:50 AM
    da_jeep_luva
    da_jeep_luva New Member
    Paul
    2017 CM and 2008 RCSB
    TRD Pro suspension, powder coated bumpers, wheels, tires, lowered, coated, list keeps going.
    I want everything!!!! Lol
    TheBeast likes this.
  2. Nov 28, 2018 at 1:14 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    Rad Tundras! Thanks for sharing :hungry:
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  3. Nov 28, 2018 at 1:15 PM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Nice lights :cool:
  4. Nov 28, 2018 at 1:17 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    @Baja Designs absolutely!! i had to upgrade to only the best! Now ive got the 40" onyx hipower, quad squad pros for ditch and fog, and s2 sports for chase.. still have a pair of flush mount s2 sports im gonna set up for reverse / rear work lights too
  5. Nov 28, 2018 at 1:18 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    osidepunker likes this.
  6. Dec 4, 2018 at 7:52 AM
    TOTAL CHAOS
    Corona, CA
  7. Dec 4, 2018 at 8:05 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    :drool: :bananadance: :headbang: :woot:
  8. Dec 4, 2018 at 8:12 AM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    You should build one for the kids to drive to school :boink:
    Black Wolf likes this.
  9. Dec 4, 2018 at 8:24 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    sure. come on by the house, you can run that idea by bec yourself... :cool:
    831Tun likes this.
  10. Dec 4, 2018 at 8:32 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    So,,,,, what about the rear? What's TC's suggestion for rear long travel for our trucks?
  11. Dec 4, 2018 at 9:03 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    dude. your answer is right here... :bananadance::cool:
  12. Dec 4, 2018 at 10:39 AM
    TOTAL CHAOS
    Corona, CA
    We don't have a "Long Travel" Kit for the Rear, but we do offer a Spring Under Axle Conversion that is a great "Mid Travel" option. Some customers have installed bed cages with our SUA kit to go full Long Travel Rear. We don't offer a bed cage for the Tundra since most customers want to maintain maximum bed space. Our kit is the perfect blend of performance and practicality.
    TOTAL CHAOS - Rear Shock Mount & Leaf Spring Conversion
    SoCal619 and 831Tun[QUOTED] like this.
  13. Dec 4, 2018 at 10:40 AM
    TOTAL CHAOS
    Corona, CA
    :eek:
    papasmurf and SoCal619 like this.
  14. Dec 4, 2018 at 11:25 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks, didn't see that on your site, probably looking in the wrong place.
    Any increase in travel #s?
    GodlessPro likes this.
  15. Dec 4, 2018 at 12:49 PM
    TOTAL CHAOS
    Corona, CA
    Travel is increased with the conversion. 12" of travel is expected in the rear
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  16. Dec 4, 2018 at 1:43 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    compatible with king 3.0 triple bypass?
  17. Dec 4, 2018 at 2:29 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    :anonymous::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    SoCal619 and smslavin[QUOTED] like this.
  18. Dec 4, 2018 at 3:26 PM
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    Well played sir:bowdown:
    papasmurf and smslavin[QUOTED] like this.
  19. Dec 4, 2018 at 3:36 PM
    #49
    TOTAL CHAOS
    Corona, CA
    This is designed to accept a 12" shock in the rear. You can use a King 3.0 triple bypass depending on bypass tube location. This will not work with the King 3.0 triple bypass that bolts into the factory location.
    TRD15559 and smslavin[QUOTED] like this.
  20. Feb 15, 2019 at 12:25 PM
    #50
    TOTAL CHAOS
    Corona, CA
    DID YOU KNOW? The TOTAL CHAOS (Boxed) Long Travel System is compatible with the factory swaybar!
    All you need is the TOTAL CHAOS Heim Swaybar Mounting Kit
    TOTAL CHAOS Long Travel - Heim Swaybar Mounting Kit
    The tubular LCA set up is great. However with the added cab weight of the 4 door we wanted to reduce some of the body roll at high speeds for flatter cornering. Adding the Sway-Bar-System gave the Tundra much better on and off road handling
  21. Apr 29, 2019 at 3:55 PM
    #51
    TOTAL CHAOS
    Corona, CA
    "Back in 2012 I took a gamble on a company buying a long travel kit for my 2005 Tacoma that I knew very little about. 2019 is here an that same Long travel kit is still kicking! It's not quite as pretty but I can assure you it's just as functional. Nearly 100,000 miles and close to 60 Wheeling trips later I can say I have never been more satisfied with the durability, dependability, support, and passion of an offroad manufacturer. Thx to TC for all they do. Keep bringing the Chaos!"⁣
    @NickKinzie - Cincinnati Ohio⁣
    osidepunker, Darkness and Black Wolf like this.
  22. Jun 22, 2019 at 4:22 PM
    #52
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Any chance there is a board discount? I'm looking for a set of 3.5" extended axle shafts for my 06 tundra. Should be part number 97300.
    Thanks
  23. Jun 23, 2019 at 8:40 PM
    #53
    TOTAL CHAOS
    Corona, CA
    We don't offer a forum discount
    We're happy to process your order if you give us a ring. Tomorrow morning we are back in the shop
    951-737-9682
  24. Jun 23, 2019 at 8:50 PM
    #54
    KarmaKannon
    Utah
    Some junk
    Bummer
  25. Jun 25, 2019 at 2:34 PM
    #55
    TOTAL CHAOS
    Corona, CA
    65428233_3038909506149577_23048821090654_d4b93078ee50ecd3eb0d318687db4e48c89982d6.jpg
    The difference is in the details
    At TC we are committed to customer service.
    Designed for performance. Built to last.
    We put extra effort into every process when we build our parts for you. ⁣
    Learn more at www.chaosfab.com
    ⁣#MadeintheUSA :oldglory:
    65061415_3038909602816234_23463321641292_5bd443c6cc572002f90a5de869170f41dbe11191.jpg
    65652505_3038909769482884_75862480268096_d04dc47088e8ed59ed6a713b33f440bda7b43437.jpg
    65217399_3038909792816215_90054013470711_4a478f9a6bfa91340b95aed558faf68e1f014745.jpg
  26. Jul 31, 2019 at 2:42 PM
    #56
    TOTAL CHAOS
    Corona, CA
  27. Aug 5, 2019 at 11:48 AM
    #57
    TOTAL CHAOS
    Corona, CA
  28. Aug 28, 2019 at 11:38 AM
    #58
    TOTAL CHAOS
    Corona, CA
    Supercharged Urban Lexus rocking a +3.5" TOTAL CHAOS Long Travel System
    What do you think?
    : (IG)snoopy_gx470
    69281766_3210637355643457_53299849303550_34c6767ae4d3a09696ea7890cae94d4547a55e60.jpg
    69368375_3210637508976775_53216329841959_e516a059b19f6d003de38fa6e99013e1bd8393d7.jpg
    69939753_3210637408976785_87505996548669_2d5ce4abf1c366e0d6509effe1ee1c110c452d33.jpg
    69027820_3210637552310104_76659746328469_8b6117809d4b5a058e5365d007c9b978d72d4850.jpg
  29. Aug 28, 2019 at 4:39 PM
    #59
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    That's a no-go IMHO.
  30. Aug 28, 2019 at 5:58 PM
    #60
    Vizsla
    Vizsla pretend2send
