TOTAL CHAOS Long Travel *Discussion Thread*
Discussion in 'TOTAL CHAOS' started by TOTAL CHAOS, Oct 2, 2018.
  1. Oct 2, 2018 at 8:55 AM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    We have a Long Travel Kit Thread, but we wanted to create a Long Travel Discussion Thread.
    This is a place to discuss ANYTHING Total Chaos Long Travel!
    Post questions, pictures, feedback, tips/tricks, etc. We are happy to help
    info@chaosfab.com
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    _______________________________________________________
    https://youtu.be/tankr69sI1s
    TOTAL CHAOS +2.5" Long Travel System (Boxed)
    TOTAL CHAOS +2.5" Long Travel System (Tubular)
    MORE INFO
    We also offer kits for the First Gen Tundra!
    TOTAL CHAOS - 2000-2006 TUNDRA Long Travel
    Rica25, Darkness and Rheywood456 like this.
  2. Oct 2, 2018 at 9:03 AM
    TOTAL CHAOS
    Corona, CA
    PRODUCT SPOTLIGHT -
    TOYOTA TUNDRA +2.5" LONG TRAVEL SUSPENSION (BOXED)
    • TC boxed lower arms feature sway bar mounting tabs to retain the factory sway bar for better cornering.
      TC Heim sway bar link kit is NOT INCLUDED. PT# 87250 is required to retain the sway bar.
    • 2.5" extended 4130 chromoly tubular upper arms bolt to factory control arm mounting locations.
    • Boxed and plated lower control arms are designed for dual 2.5" shock capability.
    • Upper and lower control arms eliminate factory ball joints and incorporate 1" uniballs for maximum wheel travel and component strength.
    • TOTAL CHAOS includes 1" I.D. uniballs that feature a heat treated stainless steel ball & heat treated stainless steel race for maximum corrosion resistance and component longevity. These uniball's also features a military grade PTFE woven fabric liner that helps prevent noise.
    • 2.5" long travel specific coil over shocks bolt into the factory coil bucket location. Extended travel shocks are too short and will not work.
      FOX 880-02-949 (COIL OVER) 982-02-950 (BYPASS)
      KING TC5143-03 (COIL OVER) TC1143-34 (BYPASS)
    • A secondary external bypass shock can be installed to increase dampening and tune-ability.
    • Adjustable limit strap clevis' are included so that you can properly limit the suspensions droop wheel travel and make necessary adjustments during the life of the limit strap.
    • 2 stage powder coat process includes a durable clear coat to provide a long lasting finish.
    • TC 4340 custom extended axles reuse factory inner and outer CV's to retain 4wd. (axles are sold separately and not included with the kit)
    • Stainless steel DOT braided brake lines, hi-misalignment spacers and all grade 8 mounting hardware is included.
    • Hand crafted in the U.S.A.
    • Fiberglass fenders are required to install this system.
    LIFT:
    3-4"
    TRAVEL:
    16" w/4WD
    TIRE: 35" or 37"
    TRACK WIDTH INCREASE:
    5"
    DID YOU KNOW? The TOTAL CHAOS (Boxed) Long Travel System is compatible with the factory swaybar!
    All you need is the TOTAL CHAOS Heim Swaybar Mounting Kit
    37881355_2314970368543498_76886295158865_6f6dfb85b828a2bad852e96475f1a90bdaf4b62f.jpg
    TOTAL CHAOS Long Travel - Heim Swaybar Mounting Kit
    The tubular LCA set up is great. However with the added cab weight of the 4 door we wanted to reduce some of the body roll at high speeds for flatter cornering. Adding the Sway-Bar-System gave the Tundra much better on and off road handling
  3. Oct 2, 2018 at 9:07 AM
    TheBeast The Beach
    me likey those discussions :) my wallet..not so much.
    Darkness likes this.
  4. Oct 2, 2018 at 9:21 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I've been beating on your tube kit hard for the past 4 years. I love the ground clearance on the lower arms. This is by far the best kit out there if you need clearance over technical trails.
    I have a suggestion though, you need a reinforcement on the tube where the knuckle contacts the lower control arm when you turn the wheel full lock. The tube gets dented from the knuckle and it makes me hesitant to do a full lock turn on tight trails.
    Other than that the kit is badass!
    SoCal619 likes this.
  5. Oct 2, 2018 at 9:22 AM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    What components do you recommend gusseting when running Long Travel?
  6. Oct 2, 2018 at 9:26 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I have my spindles and cam tabs gusseted. I definitely recommend the cam tabs. As for the spindle, both sides are cracking in two different places. Same places on both sides. I think the spindle is flexing and the gussets aren't strong enough in those two places. But my spindles haven't bent yet so I'm not worried about it
  7. Oct 2, 2018 at 10:36 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    everything!!
    i have spindle gussets, cam tab gussets deff both needed.
  8. Oct 2, 2018 at 10:37 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Have you guys ever considered doing a "step up" kit? Like how for the Tacoma your shop offers a +2 or +3.5. Since the Tundra kit is a +2.5, a +4 would be interesting (ie. LSK's is +5).
  9. Oct 2, 2018 at 10:40 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    @TOTAL CHAOS why no bed cage option like camburg. the sua parts are all there, all you need to do is make a cage. Although im doing a combination of your parts and theirs. I have camburg cage, your sua plates and lower shock mounts, and deavers.
    Also bump mounts would be nice for LT guys for the rear. camburg only makes them for mid travel guys. Im having to custom make them myself. but no big deal.
    also like alex, i run your front kit and love it. No complaints. on the front kit you guys should include a set of wheeler super bumps for the front kit. they are much better than stock bumps and front cans are not really needed with dual coilover / bypass setups. plus there is limited room when you add a limit strap
    joonbug likes this.
  10. Oct 2, 2018 at 10:44 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    I would only guess as their front kit has 16" of travel and utilizes stock CV's with longer intermediate shafts you run into extreme CV angles at full droop which can cause issues so if you extend the shaft another 2 inches while you may gain an inch or two of travel similar to LSK race kit #'s you run the risk of binding a CV which could be catastrophic. But I could be totally off base @TOTAL CHAOS could probably give a better reason as to why not. Just spit balling here
    plus this kit is the exact same as what they run on their race trucks. So it works, if it aint broke dont fix it! LOL
  11. Oct 2, 2018 at 10:46 AM
    Spvrtan
    Kris
    San Diego, CA
    Yea, that's true. You'd really have to trust the strength of your limit straps and bump stops. Didn't you or Alex reach out to RCV about axles?
    papasmurf likes this.
  12. Oct 2, 2018 at 10:47 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    RCV axles were several months out last time I asked. They might be available now, but they're only making LT axles specd for TC kit
  13. Oct 2, 2018 at 11:07 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    alex did, i wouldnt waste the money honestly ive built two sets of the tc spec axles and the toyota CV's are beefy!! and the 4130 Chromoly TC axles are great. Yeah limit straps and bumps would be the key but id be afraid the length in the arm and cv angles would still be too much. Thus why go longer if you have to restrict travel if that makes sense
    2500$ though is wayyyy too much, id rather build a spare set of TC spec axles with factory toyota parts and carry those, two sets for the price of one. Plus they have boot issues. AS we know from the convo in my build thread
    osidepunker[QUOTED] likes this.
  14. Oct 2, 2018 at 4:18 PM
    TOTAL CHAOS
    Corona, CA
    With the knuckle modified there shouldn't be major contact at the LCA. Did you trim your steering stops? I've attached the installation instructions that show the modification. Here is an image of the knuckle after modification:
    We appreciate the feedback. Looking forward to hearing from you regarding the steering stops.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    SoCal619 and dcsleeper408 like this.
  15. Oct 2, 2018 at 4:23 PM
    TOTAL CHAOS
    Corona, CA
    dcsleeper408 and papasmurf like this.
  16. Oct 3, 2018 at 4:40 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yeah my ball joint cradles look like they do in your picture, ie no steering stops. I'll take a picture and show you.
  17. Oct 3, 2018 at 7:32 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    This is a discussion thread yeah?
    @TOTAL CHAOS any comment or thoughts about what @Spvrtan and I were discussing??
  18. Oct 3, 2018 at 7:59 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Easy to do... give tesco or kibbietech 200k and they can build you a 6100 truck ...
  19. Oct 3, 2018 at 8:07 AM
    TOTAL CHAOS
    Corona, CA
    The majority of our customers want to maintain maximum bed space. With this in mind, we developed a solution that would allow longer shocks without intruding in the bed. Some customers have made custom cages for their applications or used other options on the market.
    We do offer a Bump Stop Mount Kit for the Tundra! Designed to work with a KING 2.0” stubby adjustable bump stops. Since you're running a SUA kit the install is a little different. Instead of running the bolt-on striker plate you will need to weld a striker plate to the top of the axle housing.
    Thanks for the support! Post a pic or two of your truck in action :)
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    SoCal619 and papasmurf[QUOTED] like this.
  20. Oct 3, 2018 at 8:11 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Yeah will do and understand the market driven point makes total sense. I will post up pics have a ton in my build thread. That being said about the bumps I am just making my own can mounts using king Kartek bump cans and some plate. I also have axle strike plates that will be welded in. Thanks for the help and comments.
  21. Oct 3, 2018 at 8:15 AM
    TOTAL CHAOS
    Corona, CA
    No plans to make an additional kit for the Tundra. We've found +2.5" to be the best option for maximum performance while maintaining a daily driver package. It's a very wide vehicle as-is, and at +2.5" it's barely fitting in parking spots. Going wider wouldn't be very practical.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  22. Oct 3, 2018 at 8:18 AM
    TOTAL CHAOS
    Corona, CA
    Sorry about any delays - We try to respond as quickly as we can :thumbsup:
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    papasmurf[QUOTED] and SoCal619 like this.
  23. Oct 11, 2018 at 9:52 AM
    TOTAL CHAOS
    Corona, CA
  24. Oct 18, 2018 at 11:54 AM
    TOTAL CHAOS
    Corona, CA
  25. Oct 18, 2018 at 12:12 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    sweet!! good luck have fun and kick ass out there... cant wait for some vids!!
  26. Oct 25, 2018 at 10:20 AM
    TOTAL CHAOS
    Corona, CA
    Rica25, Darkness, TheBeast and 3 others like this.
  27. Nov 15, 2018 at 9:34 AM
    TOTAL CHAOS
    Corona, CA
    45596937_2525153677525165_67035468119922_c5852dcf9805f7f67ba5f1e44b5df08705130739.jpg
    Have questions about TOTAL CHAOS Long Travel? Comment below!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    BajaTurd, Darkness, smslavin and 6 others like this.
  28. Nov 15, 2018 at 10:43 AM
    TOTAL CHAOS
    Corona, CA
    Rica25, 1UPPER, Darkness and 6 others like this.
  29. Nov 15, 2018 at 11:38 AM
    TOTAL CHAOS
    Corona, CA
    Their Instagram might have photos and details, we only have info on the front w/ our Long Travel System
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  30. Nov 28, 2018 at 10:26 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    just a couple of TC long travel tundras doing our thing... @TOTAL CHAOS
    Rica25, osidepunker, jc153 and 6 others like this.
