Tire Fender Overhang Formula
Discussion in 'Wheels & Tires' started by cthomaschase, Mar 1, 2017.
  1. Mar 1, 2017 at 5:37 PM
    cthomaschase
    cthomaschase [OP] New Member
    In a previous thread I created, https://www.tundras.com/threads/max...-stick-out-past-the-fender.10652/#post-185499, I was trying to determine exactly how combinations of wheels and tires result in fender overhang (i.e how much the tire is tucked under the fender) for my '17 CM. I received many great responses and figured I'd create a formula to show the exact(ish) results.
    I started by figuring out the distance from the front wheel hub to the fender, turns out it's 90mm (FYI the rear is 105). Using this, I came up with the following formula to determine fender overhang.
    Overhang = TW/2 - WO - 90
    TW = Tire Width
    WO = Wheel Offset
    So, for example, on the stock '17 CM with 255/70-18 tires and 18x8 wheels with 60mm offset, the calculation is 255/2 - 60 - 90 = -22.5mm. The same calculation on the rear is -37.5mm, or a 37.5 overhang of fender over tire.
    A negative number means the tire is tucked inside the fender, a positive number means the tire sticks out beyond the fender.
    What role does the wheel width play?
    None. The tire width is really what we're concerned with, the center of the tire is the same as the center of the wheel.
    What if I have spacers?
    Easy, spacers push the wheel and tire out towards the fender, so therefore add the size of the spacer to the final calculation. Remember 1" = 25.44 mm. For instance, if I added 1.25" spacers (which is 31.8mm) to my stock setup as before, the overhang would be 255/2 - 60 - 90 + 31.8 = 9.3mm, which means it actually would stick out past the fender about 0.37".
    Please let me know if you see any issues with this.
    hudrock, Pimpala1962, Mattdf and 13 others like this.
  2. Mar 1, 2017 at 6:05 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Nice formula. I haven't seen this before. Yep seems to work, crunched the #s with my set up 295 70 18, +60 offset and 1.25" spacers. Appears to be pretty close.
    joonbug likes this.
  3. Apr 7, 2017 at 1:16 PM
    cthomaschase
    Finally got around to using my formula and finding the wheels and tires I wanted.
    Went with the Method Mesh 18x9 wrapped with Yokohama Geolander 295/70-18.
    Krezz, J4RR3N4 and Jsena like this.
  4. Apr 7, 2017 at 2:03 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Missed this when originally posted, but nice work.
  5. Apr 8, 2017 at 1:10 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Liking the front bumper. I guess that's the one drawback, ya gotta buy a light bar too.
    joonbug likes this.
  6. Apr 8, 2017 at 9:08 AM
    cthomaschase
    Exactly, looks weird without the light bar.
  7. Apr 8, 2017 at 10:34 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I've still got bumper envy though!
    joonbug likes this.
  8. Apr 12, 2017 at 10:16 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    2007 Slate Metallic Double Cab
    Jsena and Les7311 like this.
  9. Apr 12, 2017 at 10:53 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    That's a great buy on the lights
  10. Apr 14, 2017 at 1:05 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    Excellent work!
  11. Apr 14, 2017 at 1:09 PM
    az1441
    az1441 6-0 G7s on the road
    Steeler Country
    2017 Toyota Tundra TRD Pro cement
    4" Readylift 35" Toyo M/T 20x9 0 BMF BATL Retrofit w RGB LED Halos and Strips
    Mine should in your appendix of grossly improper calculation
  12. Jul 5, 2017 at 8:09 PM
    Vancepp
    Vancepp New Member
    2017 TRD Off Road
    Toytec Boss Kit, Method Grids, 305/70-18 STT Pros
    So using this leads me to believe that a 12.50 wide tire with a +1 offset will set the tire 2.66 inches PAST the fender... Would this be the case? I don't math well and just trying to see if I'm on the right track...
    Formula I used... 317.5(12.50) / 2 - 1 -90
    Any help is appreciated as like I said before... I don't math well.
    Jsena likes this.
  13. Jul 5, 2017 at 8:10 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  14. Jul 5, 2017 at 8:19 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes, that's correct.
  15. Jul 5, 2017 at 8:22 PM
    Vancepp
    Vancepp New Member
    2017 TRD Off Road
    Thanks!
    joonbug[QUOTED] likes this.
  16. Jul 9, 2017 at 12:03 PM
    Vancepp
    Vancepp New Member
    2017 TRD Off Road
    Just because... are we talking about the top of the fender or the bottom? Sorry.
  17. Jul 9, 2017 at 12:27 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I would think the top of the wheel well.
  18. Jul 9, 2017 at 2:49 PM
    Vancepp
    Vancepp New Member
    2017 TRD Off Road
    That's what I assumed as well... but all the pictures that I see with a +1 offset and a 12.5 wide tire do not look like they are out over two and a half inches.
  19. Jun 3, 2019 at 6:38 PM
    ktmhauler
    ktmhauler New Member
    GA
    2019 SR5 Dbl 4wd 5.7
    So i'm thinking putting my stock 255/70-18 tires on some new method wheels that have a 0mm offset instead of a 60mm offset of the stock steel wheels.
    Seems that would make them stick out 37.5mm or 1.5in
    Would that cause rubbing in the front?
  20. Dec 27, 2020 at 4:48 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I've seen this thread pop up in recommendations for tire offset a few times now, so figured I'd give it the bump it deserves.
  21. Jan 8, 2021 at 5:57 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    You're right. Well deserved bump.
    This was extremely helpful. I usually just add "tundras" to whatever I'm google searching and find what thread I'm looking for, but never saw this one. Thanks!
  22. Apr 4, 2021 at 3:57 AM
    Bigdave
    Bigdave New Member
    Dave
    2016 SR5
    Lift, lights
    I have stock wheels on my SR5 2016, I want my tires to stick out 2” past fenders will a-24mm offset give me that??
  23. Apr 4, 2021 at 5:19 AM
    NoRcptn
    NorCal
    2017 Platinum
  24. May 17, 2025 at 1:57 AM
    Tundrav82019
    Tundrav82019 New Member
    Leo
    2019 Tundra Limited TRD Off Road
    I know old post, unsure if anyone could check my math.
    wheel is 18x9 with +20mm offset. Tires are stock 275/65R18.
    Calculation= 275/2=137.5, 137.50-60=77.5, 77.5-90=-12.5
    so my tire would be in fender well still?
    Other offset calculators show about 2 inch poke.
    help?
  25. May 17, 2025 at 8:07 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Nope. Swap the 60 in your calculation with 20, which is your wheel offset. Should poke about 27.5 or just over an inch.
    Tundrav82019[QUOTED] likes this.
  26. May 17, 2025 at 10:24 PM
    Tundrav82019
    Leo
    Ok sweet, here is new calculation.
    275/2=137.5.
    -20 (instead of 60) = 117.5
    117.5-90=27.5
    is the 27.5 in mm?
    if converted to inches 27.5mm in inches= 1.08 inches of wheel poke?
    Is this calculation specific for Tundras and our wheel wells?
    If I were to take a ruler and place on my wheel to get a general visual, where would I place it?
    Thanks again!
  27. May 18, 2025 at 9:52 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Here’s what 32.5mm (1.28 inches) looks like.
  28. May 18, 2025 at 10:12 AM
    Tundrav82019
    Leo
    what offset and tire size you running?
    looks good!
  29. May 21, 2025 at 3:03 AM
    Tundrav82019
    Leo
    Are you running a +20mm offset with a similar rim like me? 18x9?
  30. May 21, 2025 at 3:10 AM
    MRweeka
    MRweeka Validator
    Savvon
    Atlanta, Georgia
    2023 Tundra
    SDHQ Mounts Rough country Seats
