Swapping Radiator
Discussion in '1st Gen Tundras (2000-2006)' started by Splashbrother13, Apr 19, 2024.
  1. Nov 10, 2024 at 6:26 AM
    mthoodbill
    mthoodbill New Member
    Mt Hood, Oregon
    2000 Tundra SR5 Access Cab 4x4, 2025 Wrangler 2dr manual
    Bilstein 6112, .5" front lift. 5100 rear. 17" FJ steel wheels Gofast topper
    Interested in that mishimoto too. Specs state it won't fit the double cab, so hopefully it's a bolt-in job for the access cab.
    Grizzld likes this.
  2. Nov 10, 2024 at 6:31 AM
    des2mtn
    des2mtn Barf me out, gag me with a spoon!
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    CSF 7030 aluminum radiators will fit double cabs.
    Grizzld likes this.
  3. Nov 10, 2024 at 7:32 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    CSF shows fitment for 00-06 Tundra, which would imply regular cab and access cab only - same as the Champion above. Have you installed the CSF 7030 into Double Cab?
  4. Nov 10, 2024 at 7:36 AM
    des2mtn
    Shady Grove
    Tonto cover
    Yep, I've had it for a few years now.
    Grizzld likes this.
  5. Nov 10, 2024 at 11:50 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Recall @JakeJake was looking at or had experience with the Mishi aluminum but I had determined their non-aluminum was not superior to a LAPS store rad, because although core appeared to be thicker like the Denso, their lifetime warranty on it was not straightforward like Orielley where you can just walk it in and walk out with replacement.
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-2231#post-3650232
    HBTundra[QUOTED] likes this.
  6. Nov 10, 2024 at 12:31 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I never pulled the trigger.
    The Denso unit from RockAuto I ended up with is a nice part, and I'm sure it will be just fine for another 200k+, but its plastic and has a finite life.
    A full aluminum radiator is almost infinitely repairable with a little tig welding, and are not prone to degradation and splitting like plastic tanks.
    I'll go aluminum next time, if there is one.
  7. Nov 11, 2024 at 5:01 AM
    Grizzld
    Grizzld New Member
    '05 2wd DC Tundra, '07 2wd Sequoia
    Nice, have any pics of the shroud-side, or install? Any issues w install?
  8. Nov 11, 2024 at 8:17 AM
    mthoodbill
    Mt Hood, Oregon
    according to specs the mishimoto core is much thicker than the csf. Overall size on the two is different as well. I'd love to hear if any access cab people have used them and if they had any install issues.
