Scangauge 3 Available
Discussion in 'General Tundra Discussion' started by Bergy24, May 19, 2022.
  1. Feb 8, 2023 at 1:28 PM
    #151
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    No issues. I replaced the magnetic disk that came with the ScanGauge with the plate that came with the mount and it’s been holding strong for several months now.
    Lodge14[QUOTED] likes this.
  2. Feb 26, 2023 at 9:25 AM
    #152
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    just remembered to update my SG3 via wi-fi
    I was on 1.12....jumped to 1.2
    NWPirate likes this.
  3. Mar 24, 2023 at 10:11 AM
    #153
    What length arm and magnetic mount did you purchase? I am still trying to find a permanent spot for mine.
    Edit...this one? https://www.tackform.com/products/magnetic-vent-mount-for-toyota-tacoma-and-tundra
  4. Mar 24, 2023 at 2:41 PM
    #154
    jackienguyener
    Jackie
    2016 Tundra 1794
  5. Mar 24, 2023 at 3:25 PM
    #155
    Thanks
  6. Apr 24, 2023 at 5:05 PM
    #156
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Finally ordered one of these. Pretty pumped to be able to see so much more info at once, especially TC lockup and current gear when towing. 9 gauges at once will be awesome. Any reason I can’t do: Gear, TC lockup, IAT, Trans temp, coolant temp, Average MPG, MAF, fuel remaining, cat temp?
  7. Apr 24, 2023 at 5:14 PM
    #157
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    I've been on the fence about ordering one. I'd like to see all the info as well but I don't like how big it is. Are you planning to use the windshield suction cup?
    Silver17[QUOTED] likes this.
  8. Apr 24, 2023 at 5:19 PM
    #158
    Silver17
    Eastern PA
    Not even sure. Going to see what it comes with for mounting, and if nothing included works I’ll get creative.
    V10Ace[QUOTED] likes this.
  9. Apr 24, 2023 at 6:28 PM
    #159
    It comes with the suction cup...it will stick in the cup holder that is at the front edge of the console.
  10. Apr 24, 2023 at 6:29 PM
    #160
    Saltyhero13
    Saltyhero13 Throbbing Member
    It is fully customizable and to my knowledge no monitor is mutually exclusive with any other monitor.
    The touch screen is pretty responsive so you can always swipe to a second screen
  11. Apr 24, 2023 at 6:30 PM
    #161
    I can take pics tomm of all of the x-guage commands that it pulls.
  12. Apr 24, 2023 at 6:32 PM
    #162
    Saltyhero13
    Tundra234[QUOTED] likes this.
  13. Apr 25, 2023 at 5:28 PM
    #163
    Silver17
    Eastern PA
    Got the SG3 today. Haven’t had too much time to play, but I’m really liking it so far. It’s come quite a long way from the 2. I set alarms for cat temp, coolant temp, trans temp, LTFTs on each bank below - 10%, maybe something else too. I used the fuel remaining X gauge but even after filling up and topping off it only went to 34.7 instead of 38. I guess I’ll get the fuel consumption dialed in using the “fill up” function like the SG2 and hope it gets dialed in. It seems surprisingly close though so far without making any adjustments.
    Really like the current gear and TC status for towing. Seeing 9 parameters at once, and at the push of a tab up to 18 more is awesome.
  14. Apr 25, 2023 at 5:39 PM
    #164
    It has some neat features. I use the 2 finger swipe for dimming quite often. I posted the full manual in this thread also.
  15. Apr 26, 2023 at 3:25 AM
    #165
    nobodyintexas
    nobodyintexas What?
    South of Houston
    LTFT's...please expound on this item.
    and set an alarm for MAF max. I think I have mine @ 500.
    Saltyhero13 and Silver17[QUOTED] like this.
  16. Apr 26, 2023 at 4:05 AM
    #166
    Silver17
    Eastern PA
    Long term fuel trims. Most of the time they’re +\- 5% since being tuned. I Set the alarm to go off if they’re less than -15% (leaner than usual) as to indicate a fuel system issue. On the MAF, since mine has been rescaled for the bigger intake I think the highest value on the MAF table I saw in HPtuners is in the mid to low 400s, so that one shouldn’t be a concern for me I’m thinking!
  17. May 25, 2023 at 12:25 PM
    #167
    NWPirate
    Zach
    WA
    First time towing with the SG3, I'm loving all the data.
    Curious what is considered high trans temps with the factory cooler?
    Silver17 likes this.
  18. May 25, 2023 at 12:51 PM
    #168
    Silver17
    Eastern PA
    I don’t bother monitoring the TC, but my pan fluid temp I’ve never seen over 225-230ish towing my 7k TT in the harshest of conditions.
    NWPirate[QUOTED] likes this.
  19. Jun 6, 2023 at 4:26 PM
    #169
    Jongie123
    Jongie123 New Member
    Johnny
    2022 Midnight Black Metallic Tundra 4x4
    Anyone that has it mounted on a 3rd Gen Tundra want to share mounting locations . It seems any place I try to install on the windshield it covers way too much of my view .
  20. Jun 17, 2023 at 6:22 AM
    #170
    Silver17
    Eastern PA
    Does anyone know if you can monitor engine oil temperature? I didn’t see it anywhere.
  21. Jun 17, 2023 at 6:27 AM
    #171
    Let me look at mine real quick
  22. Jun 17, 2023 at 6:29 AM
    #172
    Saltyhero13
    I don't think the Tundras have an oil temp sensor, only coolant temp.
  23. Jun 17, 2023 at 6:32 AM
    #173
    I don't see it in standard or xguages. Now that I'm thinking about it, it wouldn't unless you had an aftermarket temp probe installed?
  24. Jun 17, 2023 at 6:39 AM
    #174
    Silver17
    Eastern PA
    Thought that might be the case but wasn’t sure.
  25. Jun 18, 2023 at 4:23 AM
    #175
    Silver17
    Eastern PA
    I saw a post on a tundra FB page, a guy was showing his temps from pulling his trailer. He had engine oil temp displayed via OBD fusion on his 2019 so there has to be a sensor and a way for the SG3 to read it I would think.
  26. Jun 18, 2023 at 7:55 AM
    #176
    Saltyhero13
    ODB fusion lets you derive temps using formulas and other temps. Oil temp isn't on the CANBUS but you might be able to read and get the actual reading using Techstream. Available codes are listed here:
    https://www.scangauge.com/support/x-gauge-commands/toyota-lexus-scion/
  27. Jun 18, 2023 at 9:52 AM
    #177
    Saltyhero13
    @Silver17 if you do figure something out with SG let us know. I've been interested in monitoring this but didn't want to add another gauge to the cluster.
  28. Jun 21, 2023 at 5:17 AM
    #178
    Latest firmware version is 1.21 if anyone is curious.
  29. Jun 28, 2023 at 2:47 PM
    #179
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Anyone looked at the Banks iDash? Seems like a viable alternative and it'll fit in any standard 52mm pod mount (A-pillar). Works with the Pedal Monster. Has an SD card slot and smaller footprint too. Pretty slick lookin.
  30. Jun 28, 2023 at 3:04 PM
    #180
    One of the guys on here has one and found out that the Tacoma vent mount fits the Tundra. It would be an option if I didn't have the SG3 already.
