Scangauge 3 Available
Discussion in 'General Tundra Discussion' started by Bergy24, May 19, 2022.
  1. May 19, 2022 at 12:57 PM
    Bergy24
    Bergy24 [OP] New Member
    2021 Cement Crewmax Limited TRD 4X4
  2. May 19, 2022 at 1:20 PM
    5N0W808 and texasrho83 like this.
  3. May 19, 2022 at 1:54 PM
    5N0W808 and WVI like this.
  4. May 19, 2022 at 1:56 PM
    Retired...finally
    Same price that I paid for the older version in Sept '21. I'm impressed with mine. A must for towing.
    5N0W808 likes this.
  5. May 19, 2022 at 2:11 PM
    I like this SGIII. It autoscans for vehicle protocol and X-Guages as well. Should find stuff like trans temp and TPMS easily.
    5N0W808, nobodyintexas and TheBeast like this.
  6. May 19, 2022 at 5:53 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Ordered one last Friday. It shipped quickly and had it early this week.
    Only had a chance to run a quick Op Check on another vehicle. Couldn't test the X-Gauge autoscan since it doesn't support my test vehicle's make for this feature. NOTE: It does support Toyota and Lexus for X-Gauge autoscan
    Looks like it merged the functionality of the ScanGauge 2 and Scan Gauge E which is a plus for me since I ran both on my Tundra. You can't daisy chain these since it only has one port but you wont need to since you can track all the same data available to both.
    As far as data viewing, looks like it lets you store three or four pages of parameters to track with 6 metrics on each. So you can swipe or select tabs of what you want to monitor. It also has a predesigned fuel tab if you need to track those metrics. Overall the quality looks nice, it comes with a suction mount with a magnetic holder, good if you want to hide the gauge from thieves. The ODB cable looks to be the same as the older models and runs about the same length.
    Will provide more feedback when I get my Tundra back from the shop next week.
  7. May 19, 2022 at 5:55 PM
    It looks like it's worth the money. I just have to figure out where I would put it since it probably won't fit where my SGII is.
  8. May 19, 2022 at 6:04 PM
    Saltyhero13
    I had my original set up by the vanity mirrors/visors at the top of my windshield. Drawback is it made my visor unusable. I originally had it mounted above my mirror but this gauge is taller, about three scan gauge 2s high. Correction 2 gauges high.
  9. May 29, 2022 at 11:35 AM
    nopsFU
    nopsFU New Member
    2019 Tundra TRD Pro
    Can anyone give me an idea how quick the update rate is on the screen of scan gauge 2 or 3? I'm thinking of engine speed and percent load. I'd like to see something quicker than every 1/2 second for those signals. Thanks.
  10. May 29, 2022 at 12:41 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I’m setting up mine now
    Has everything I need
  11. May 29, 2022 at 12:55 PM
    Where are you mounting it? This is where my SG2 is.
  12. May 29, 2022 at 1:56 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    My scanguage was mounted in the same location
    have not decided on the new location
    considering the window mount
  13. May 31, 2022 at 11:21 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Eibach pro 2.0s, toytec progressive mini AAL, ARE CX cap, Airlift bags, Harrop Supercharger, 650cc injectors, 77.5mm pulley, TRD Dual exhaust, J&L catchcan, Powertrax LSD, RRW RR7-H, 305/70r17 Toyo AT3s
    Figured this was a good recent thread to ask this question. Does anyone know of the codes for the Scangauge to display torque converter lockup? I’m not positive that it is capable of showing it, but I want to say it should be possible.
  14. May 31, 2022 at 11:29 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Silver17 likes this.
  15. May 31, 2022 at 11:42 AM
    Silver17
    Eastern PA
    Thanks! I’ll give it a try and report back.
  16. May 31, 2022 at 1:22 PM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    About time linear logic updated the design. I ditched my SG2 for an Ultragauge like 10 years ago. I'm in a different truck and still use it. These little digital gauges are must haves.
  17. Jun 2, 2022 at 5:34 AM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Dang this new one looks nice. I’ve been considering ordering the SG2 to add some more monitoring to my LS swapped CJ with adding a bunch of gauges. Might have to get the SG3 instead.
  18. Jun 2, 2022 at 5:37 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'm on the back side of adjusting it to the fuel usage rate - due to the tune/injectors.
    I like the alarms you can set. i.e. I get a buzz if I go over 500 on the MAF. also if I go over 205 on the trans.
    I'm still learning tho'...
    Retired...finally and Roselaker like this.
  19. Jun 3, 2022 at 6:46 PM
    Roselaker
    Roselaker New Member
    D
    2021 SR5 CM (trail edition)
    Just received mine today. Does anyone know if it's supposed to come with a user manual, or just the quick start guide?
    I ordered a magnetic ball mount from 67d, to fit the 20mm arms I used on the Rago dash plate. I will post pictures once it's mounted.
    Now, time to figure it out..
  20. Jun 4, 2022 at 4:15 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    with scanguge 2, it modified the fuel usage % when you did a fill up.
    with SG3, it appears you have to go to setup & modify "fuel flow" in the setup menu
    with my tuning (650cc injectors), I'm at ~41% positive adj. or thereabouts. LOL
    If I'm doing this wrong, someone holler. I did the fill-up thing, per instruction, to no avail.
    other than that...I like this new version.
    I wish it dimmed with the dash.
    Saltyhero13 likes this.
  21. Jun 4, 2022 at 4:13 PM
    Saltyhero13
    It is disappointing to hear they changed this. Hopefully they change this with an OTA update.
  22. Jun 4, 2022 at 4:32 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    The directions say it works the same.
    It must be me.
    I’m still dickering with it every 1/4 tank
    I would suspect it would recalibrate when I put in the gallons at fill up
  23. Jun 6, 2022 at 9:38 AM
    I haven't purchased one yet but I did reach out to them to see if an actual user manual is available yet. They only have the quick user guide available on the site.
  24. Jun 6, 2022 at 5:34 PM
    The reply regarding a user manual.....
    Roselaker and Saltyhero13 like this.
  25. Jun 9, 2022 at 3:03 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I still have not gotten the mpg to adjust to the 650cc injectors.
    however...I think i know what the problem is. ME.
    when you input the gallons, the way to exit is not intuitive. and I am exiting the screen that says "exit without saving?" and I'm saying yes. I just noticed that. I assumed it said save changes.
    next fill-up next week...I bet it works then.
  26. Jun 9, 2022 at 10:50 AM
    Saltyhero13
    What fuel cut off are you using? I vaguely remember 24 when I set up my first gauge.
  27. Jun 9, 2022 at 10:55 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I have not even fiddled with fuel cutoff.
    when I used the SG2, i just let it calc via the fillups.
    I did try to change "fuel flow rate", but that made no diff.
    I think the issue is me....when you fill up, the question is "end without saving?" i chose yes.
    it should be "save changes"
    I'll give it one more fill up before I gripe.
    I'll be that guy in the Costco gas lane sitting in my car after I fill up - pissing everyone off.
    Retired...finally and gabex35 like this.
  28. Jun 12, 2022 at 9:47 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    All right. I did the correct fillup
    and it did not change the mpg rate
    I will now contact scanguage
    WinterWarlock21 and Saltyhero13 like this.
  29. Jun 12, 2022 at 12:24 PM
    Saltyhero13
    Sweet @nobodyintexas. I ordered a few different mounting solutions to test placement. So far it is looking like 12 o'clock behind the wheel.
  30. Jun 12, 2022 at 12:28 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
