Rough Country 6 inch lifted struts
Discussion in 'Suspension' started by jeremyd, Apr 3, 2019.
  1. Oct 2, 2019 at 4:12 PM
    #61
    Tookooltundra
    Tookooltundra New Member
    2016 TRD PRO
    Rough Country 6" lift
    Thanks... ride is better.. that I got rid of 2.5" stacks
  2. Oct 2, 2019 at 4:17 PM
    #62
    Mnorris1206
    08 tundra
    For sure that helped my ride alot now I have my eye in the new rear shocks they just cam out with.
  3. Oct 2, 2019 at 4:18 PM
    #63
    Mnorris1206
    08 tundra
  4. Oct 2, 2019 at 4:53 PM
    #64
    Tookooltundra
    2016 TRD PRO
    Ok... I didn't know they have rears... I have to check those out... it definitely will be easier than the fronts..
  5. Oct 2, 2019 at 10:11 PM
    #65
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    Basically just lifted my truck (pro comp 7”) but i think i want a cleaner look without the spacers. Is it set at 6”? Because like the height at 7”
  6. Oct 3, 2019 at 2:35 AM
    #66
    Tookooltundra
    2016 TRD PRO
  7. Oct 3, 2019 at 5:55 AM
    #67
    jeremyd
    jeremyd [OP] 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    It is non adjustable. You could stick in a 1 inch spacer on top of the coil and it would still ride better then what you have because the preload spacer would have been removed..And then you could retain your 7 inches.
  8. Oct 3, 2019 at 6:14 AM
    #68
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    I'm running these with a 1/2" shim on the low side and 1/4" shim on the high... Leveled her right up. Ride is awesome, they've been on since May, no issues and a great ride. BTW, I've been selling a ton of these lately, and have not had one customer complaint yet.
    jeremyd[OP] likes this.
  9. Oct 3, 2019 at 6:18 AM
    #69
    jeremyd
    NV
    2014 SR5 CM 4X4
    You ain't the only one ! I'm at 7 inches and I still made it inside of my garage. Lol
  10. Oct 3, 2019 at 6:22 AM
    #70
    1BadTundra
    Clinton
    Too Much to List
    Those are the exact shims I used. I machined 1/4" off of one to level it out, side to side.
  11. Oct 3, 2019 at 6:24 AM
    #71
    1BadTundra
    Clinton
    Too Much to List
    Oh yea, she still fits....
  12. Oct 3, 2019 at 6:24 AM
    #72
    jeremyd
    NV
    2014 SR5 CM 4X4
    Truck looks sweet ! I never had the drivers side lean.
  13. Oct 3, 2019 at 6:25 AM
    #73
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    Do you have control arm relocation kit installed? 6” without lowering the lower control arms places the control arms at severe angles.
  14. Oct 3, 2019 at 6:25 AM
    #74
    1BadTundra
    Clinton
    Too Much to List
    Thanks, it was ever so slight, less than a 1/2". Shims straightened her right out though.
  15. Oct 3, 2019 at 6:28 AM
    #75
    jeremyd
    NV
    2014 SR5 CM 4X4
    Nice !
    Bigboitundra likes this.
  16. Oct 3, 2019 at 6:30 AM
    #76
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    How are you guys getting away with the stock UCAs? I would think there would be no way to get alignment specs right.
  17. Oct 3, 2019 at 6:31 AM
    #77
    jeremyd
    NV
    2014 SR5 CM 4X4
    It's a bracket lift, What are you talking about ??
    @Keithbickford , Didn't mean to come off as negative..These are meant to be used with 6 inch bracket type lifts that are utilizing spacers. They will not work as a stand alone lift.
    Keithbickford[QUOTED] likes this.
  18. Oct 3, 2019 at 11:56 AM
    #78
    Mine don't fit :(
    jeremyd[QUOTED][OP] likes this.
  19. Oct 3, 2019 at 1:14 PM
    #79
    Keithbickford
    Keith
    Seattle
    I guess that’s what it’s called. A bracket lift. Right on.
  20. Oct 3, 2019 at 1:58 PM
    #80
    jeremyd
    NV
    2014 SR5 CM 4X4
    Lowers the control arm to maintain the correct angles.
  21. Oct 5, 2019 at 6:12 PM
    #81
    1BadTundra
    Clinton
    Too Much to List
    I'm on RC UCA's
    BTBAKER[QUOTED] likes this.
  22. Oct 10, 2019 at 3:36 PM
    #82
    Tookooltundra
    2016 TRD PRO
    I have these Fuel wheels for sale..4 wheels only... no tpms.. 20x10 ... 18offset. 500$ ship at buyers expense.. will post better pics in next coming days..
  23. Mar 14, 2020 at 7:20 PM
    #83
    iRenaissanceMan
    iRenaissanceMan New Member
    Sorry to resurrect an old thread. I've read the entire thread and sounds like you're all running procomp 6+" lifts. I have the same installed, but was curious about lowering it. Due to the install, the cross member was cut. I don't have the original piece to weld it back. Any way to get this down to a 3 or 4inch lift?
    Thanks
  24. Mar 18, 2020 at 5:51 AM
    #84
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Looks killer...Congrats
  25. Jul 2, 2020 at 12:04 AM
    #85
    DanielsTrundaSlow
    DanielsTrundaSlow New Member
    2012 tundra
    I’m new to all these lifts and stuff. But could I just put the 6in lifted strut and a rear block to get a 6inch lift?
  26. Jul 2, 2020 at 5:32 AM
    #86
    jeremyd
    NV
    2014 SR5 CM 4X4
  27. Apr 9, 2021 at 8:42 AM
    #87
    PayItOff428
    PayItOff428 New Member
    Jake
    The United State of Texas
    2012 SR5 Double Cab 4X4
    I bought these the other day and I to do not want to risk the axle sliding out. When you say you split the bottom two. Lots what two were you referring to?
  28. Apr 9, 2021 at 8:52 AM
    #88
    jeremyd
    NV
    2014 SR5 CM 4X4
  29. Apr 9, 2021 at 8:59 AM
    #89
    PayItOff428
    Jake
    So jack it up, support the frame, place jack under control arm, remove those two bolts only, lower the jack slowly until the coilover has no stress, remove coil, and then repeat those steps in reverse to put everything back together? Thanks you so much! That’s a lot easier than the damn instructions!
  30. Apr 9, 2021 at 12:10 PM
    #90
    jeremyd
    NV
    2014 SR5 CM 4X4
    yes, exactly
