Rough Country 6 inch lifted struts
Discussion in 'Suspension' started by jeremyd, Apr 3, 2019.
  1. Apr 3, 2019 at 4:50 PM
    jeremyd
    jeremyd [OP] 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I haven’t seen anyone post about these struts, so I’ll give them a try. They just came in today and I probably won’t get to install them for at least 2 more weeks. I’ll report back after installation is complete. My current setup is a 6 inch ProComp stage 1 which consist of a top hat spacer and a preload spacer. The new Rough Country 6 inch strut eliminates the top hat spacer and the preload spacer which should smoothen out the ride although it’s pretty smooth already. It does indeed utilize the OEM coil. I will easily be able to tell the difference due to driving around on my current setup for the last 5 years. 250 bucks seems worth it. This is definitely for me because I refuse to spend a 1000 bucks for other coils ! Lol
    Prostar 190 and Mnorris1206 like this.
  2. Apr 3, 2019 at 4:53 PM
    Mnorris1206
    08 tundra
    I have them on my truck no complaints here. Have had them for about 2 months now. The ride is nice. 20190306_143258.jpg
  3. Apr 3, 2019 at 4:56 PM
    Mnorris1206
    08 tundra
    Something else I did because of the time it takes to take them all apart I just got some take off springs from another truck. And powdercoated then got the new struts put together before installing. this was my old set up exactly what your talking about .
    jeremyd[OP] likes this.
  4. Apr 3, 2019 at 4:57 PM
    Mnorris1206
    08 tundra
  5. Apr 3, 2019 at 5:01 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I hate my N2.0 ones, but I've heard good things about those
    Mnorris1206 likes this.
  6. Apr 3, 2019 at 5:08 PM
    Mnorris1206
    08 tundra
    Yea idk the difference besides the numbers lol. But I have heard good and bad about the n2.0 I think one of the bad was from you. Didn't you put a bigger bumper on your truck and the shocks are not holding well ? Maybe I'm wrong may be thinking of someone else lol
    Berdine[QUOTED] likes this.
  7. Apr 3, 2019 at 5:10 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Did you split the bottom and remove the strut downward ? Or did you loosen the top uca bolt and remove the strut from the top ?
    Mnorris1206[QUOTED] likes this.
  8. Apr 3, 2019 at 5:14 PM
    Mnorris1206
    08 tundra
    Well about that these are a bit** to get in. The driver side we ended up pulling the CV axel out of socket ended up replacing it . big oops so I suggest at the very least to lossen the hub nut and free up that CV axel with pulling down the knuckle to get it in their. As for the pasenger side we just took all of it apart. Because at that point I had to get it re aligned. It was.not a great experience but now it was well worth it.
    jeremyd[QUOTED][OP] likes this.
  9. Apr 3, 2019 at 5:16 PM
    Mnorris1206
    08 tundra
    All in all if I was you I would split the bottom and just get it re aligned after.
  10. Apr 3, 2019 at 5:30 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    I have the RC struts. No issues so far. Let us know what you think.
  11. Apr 3, 2019 at 5:48 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I've watched both ways on youtube. It looks like splitting the bottom will eliminate the axle coming out. You just have to use a floor jack to raise the bottom control arm back into place. Thanks for your pics.
  12. Apr 3, 2019 at 5:51 PM
    Mnorris1206
    08 tundra
    No problem ! When are you doing them ?
  13. Apr 3, 2019 at 5:52 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
  14. Apr 3, 2019 at 5:52 PM
    Mnorris1206
    08 tundra
    Nevermind 2 weeks I see that well let us all know what you think. I believe you will like them
  15. Apr 3, 2019 at 5:54 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Good luck with it.
  16. Apr 3, 2019 at 5:56 PM
    Mnorris1206
    08 tundra
    O something else I did . I bought new top hats that's what I call them because I had new springs but you may want to get new ones just incase you cant get them back apart without cutting them.
  17. Apr 3, 2019 at 6:01 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    ok thanks, I plan to swap over everything to keep the cost at a minimum. Unless i run into a problem.
  18. Apr 4, 2019 at 2:00 AM
    Berdine
    Binghamton, NY
    Yeah it's me, still have them, just can't decide on what to go with.
  19. Apr 4, 2019 at 2:01 AM
    Berdine
    Binghamton, NY
    There's a guy running those and a cb shim for total 7". Said rides great, no issues
    jeremyd[OP] and Mnorris1206 like this.
  20. Apr 4, 2019 at 7:56 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Finished today ahead of schedule. My buddy bailed on me last minute, so I called him an asshole ! Lol, It’s a pretty easy job. I did not remove the top spindle nut because I did not want to take a chance on the axle coming out. I split the bottom at the two bolts and then removed the strut. Picture included. 4 bolts total, sway bar, bottom shock mount and the 2 bolts under the LCA. I have to admit, I’m impressed. Very Very smooth ! A quick trip to the alignment shop and the day was over. Definitely worth getting rid of the preload spacer for 250 bucks. And my buddy finally showed back up with Carne Asada burritos in hand !
    1111111.jpg 22222222222.jpg bolts.jpg IMG_4127.jpg IMG_4128.jpg IMG_4129.jpg IMG_4131.jpg 222.jpg
  21. Apr 5, 2019 at 4:03 AM
    Mnorris1206
    08 tundra
    Nice ! Well a much faster install then mine lol 2 days because of the CV axel oops but they make a huge difference dont they. Looking good. Now if your like me time to do something with the back. Mine is still stiff back their but it's a truck .
  22. Apr 5, 2019 at 4:08 AM
    Mnorris1206
    08 tundra
    Ok not sure it must be the different yrs between yours and mine but the spaces between each coil on th springs look more gaped on yours then mine. I'm starting to think mine I bought where after market . Screenshot_20190405-070500_Gallery.jpg Screenshot_20190405-070412_Chrome.jpg
    Berdine likes this.
  23. Apr 5, 2019 at 4:32 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Did you keep the top rubber piece? Looks like you didn’t and he has it on there.
  24. Apr 5, 2019 at 4:47 AM
    Mnorris1206
    08 tundra
    Yep I did that pic it was hard to see it. Screenshot_20190405-074705_Gallery.jpg
  25. Apr 5, 2019 at 5:01 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    @Mnorris1206 you original spacer pic definitely shows a thinner preload. Maybe that changed the spacing on the coils. Not sure if it matters but the bottom of your coil doesn't look like its back up against the metal stop.
  26. Apr 5, 2019 at 5:56 AM
    Mnorris1206
    08 tundra
    Nope it's not but after putting them together I figure they will move their eventually. I'm hoping so Haven't drove it alot sence they where put on. Sucks i dont drive my truck much maybe 8k miles a yr
  27. Apr 5, 2019 at 6:31 AM
    @jeremyd so it is a better ride?
    @Berdine you have the N2? So do I, but haven't put on, they look poorly made
    There is a website I'm trying to find it, they have Bilstein struts for a 4-6 kit
  28. Apr 5, 2019 at 6:41 AM
    Berdine
    Binghamton, NY
    Yeah, I've had mine almost 2 years now. The ride was ok at first, then slowly got worse. I added a bumper/winch and they're sagging now. I try to avoid bumps in the roads
  29. Apr 5, 2019 at 8:00 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    TXRailRoadBandit73 likes this.
  30. Apr 5, 2019 at 8:01 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I'm sure your fine, especially if your not having any issues.
