Oil change tips
Discussion in '2.5 Gen Tundras (2014-2021)' started by TTU19, Jan 12, 2018.
  1. Jan 12, 2018 at 12:09 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  2. Jan 12, 2018 at 12:40 PM
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    Negative on the ATF....That's an old school trick from back in the day.
    I use Mobile-1 0W-20 like the book says.
    Filter is on you, but it is a cartridge type not your typical screw on filter.
    You do need the filter wrench as well as a new oil pan washer and all the rubber washers that come with the filter.
    DO NOT reuse the old washers.
    There are plenty of videos on YouTube that will show you the step by step for an oil change.
    Good Luck and God Speed young man!!!
    Okie1, TTU19[OP] and avgasman like this.
  3. Jan 12, 2018 at 12:44 PM
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    So if I get the Fumoto, I obviously can only install this once I've pulled the drain plug the first time. So install that, use the lever clip to lock it in during driving. Do I still need that oil filter drain, or just add the hose to the fumoto? Or does the oil filter drain hose go to something else?
  4. Jan 12, 2018 at 12:45 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    That's why I was asking about the ATF fluid. He uses it and I'm just like.. ooook. Ha.
    jfrd30 likes this.
  5. Jan 12, 2018 at 1:00 PM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
  6. Jan 12, 2018 at 1:00 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    How many QTs should I need of the oil?
  7. Jan 12, 2018 at 1:11 PM
    I’m going to assume your 16’ was purchased new. Even if it wasn’t, I’m positive that your engine isn’t all sludged up.
    This is what people did with old school motors 60-70s that had a really poor service life with 100k+ miles, and wanted to clean out a gummed up engine. Some would put in a quart, idle the motor for 10 min and drain oil, and then replace with fresh oil. Never drive an oil change cycle on this.
    Here is an article on the topic:
    https://www.amsoil.com/newsstand/dr...ticles/transmission-fluid-as-an-engine-flush/
    Personally, I would never do it.
    I would just tell your FIL that you're going to follow the recommended service schedule via your service manual. Toyota/Lexus employs some of the best engineers that spend millions on testing. This is your truck, and it is awesome he is coming over to help you out. Some good bonding time.
    The next time your hands are all greasy and dirty, try this: over a oil catch basin, pour some ATF in one hand and then rub together like you would soap to remove grease. Your hands will be so clean in seconds. Now wipe hands off with paper/shop towels. Works like a champ for that old, black sticky grease that never wants to come off.
    On a side note, this is exactly why I normally buy brand new vehicles. People doing stuff like this just scares the crap out of me. Look into used 5.7L motors. Here is a remanufactured long block, not even complete: $6231.00
    https://carpartplanet.com/2013-toyota-tundra-5-7l-23391.html
    Now the the parts swap from your motor to the long block, and then do remove and replace cost.
    You will be close to $9000.00 when this is all done. Food for thought.....
    Here is a complete motor with 50000 miles for 4800.00 + shipping.
    https://m.ebay.com/itm/ENGINE-5-7L-...pDilAQptdRfFZ-TN&_trksid=p2489528.m4335.l8656
  8. Jan 12, 2018 at 1:48 PM
    jfrd30
    2013 TRD Tundra
    8 qts
  9. Jan 12, 2018 at 1:49 PM
    jfrd30
    2013 TRD Tundra
    Have you looked at the YouTube video's yet??
  10. Jan 12, 2018 at 1:52 PM
    Tommy's Tundra and jfrd30 like this.
  11. Jan 12, 2018 at 1:55 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Nope, I can't, I'm still at work, ha. We can't go to YouTube.
    jfrd30[QUOTED] likes this.
  12. Jan 12, 2018 at 1:56 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Agreed!!
    The ATF thing is very old school. A lot of early model Miata owners do it once in awhile because the lifters are very sensitive to oil changes and tend to not pump up if you neglect to change the oil. ATF WILL clean the heck out of the inside of the engine though.
    Look up "2 twisty flush" for more info.
    avgasman[QUOTED] and ColoradoTJ like this.
  13. Jan 12, 2018 at 1:58 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    You still need the plastic tool to drain the oil out of the filter location and it will come with the factory filter . The tube is for the fumoto valve IF you want it. I am lifted and didn’t use the tube. I can just sit under my truck and adjust the drain pan... can’t speak for stock guys.
    There is a sweet YouTube video that shows you stick the plastic tool into the filter then use an empty bottle(video shows Vodka I think) and that will save from a huge mess from the filter drain.
    You can do the fumoto later. It’s just a nice piece to have not a requirement.
  14. Jan 12, 2018 at 2:31 PM
    jfrd30
    2013 TRD Tundra
    When you get a chance, look at the vid. It will explain a lot of what everyone is trying to impart to you. An oil change in a Tundra is a bit more tricky and complicated than you would imagine. Once you see the vid, all this will make much more sense.
    ColoradoTJ and Black Wolf like this.
  15. Jan 12, 2018 at 2:41 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Yeah, it's beginning to all seem a little too crazy. Humm..
    Eclipsed & Floating and jfrd30 like this.
  16. Jan 12, 2018 at 2:44 PM
    jfrd30
    2013 TRD Tundra
    Hahaha.....I've got several oil changes under my belt and all this talk is confusing me.....LOL! Let us know how it goes when you get to it. Oh, and let us know how your father-in-law responds to the oil change. I'm sure there will be several choice words and some head scratching......possibly even a WTF or two!
  17. Jan 13, 2018 at 6:00 AM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Follow torque specs. Be prepared to mess up the ribs on filter cap when removing. But a metal one.
  18. Jan 13, 2018 at 6:04 AM
    netranger6
    Jeremy
    I used amsoil filters and their signature grade. Change both o rings. And a filter wrench won't do shit but piss you off. Get a good cap socket. If the last guy that changed it torqued it down too much there' a ood chance you'l snap a rib on the filter cap. And it will leak. Be ready to call Toyota for another or have one in hand.
    Ericsopa and Slayer like this.
  19. Jan 13, 2018 at 3:58 PM
    #49
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Changed the oil today and was very easy! I was afraid to tackle it based on what everyone said but it was simple. Thanks for all the help everyone!
    nvrgvup444, Okie1, Abrams65 and 5 others like this.
  20. Jan 13, 2018 at 5:47 PM
    #50
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    Oh hell no! Transmission fluid is way too thin. My father has owned his own shop for forty plus years and never did anything like that
  21. Jan 13, 2018 at 5:55 PM
    #51
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    I was worried all those suggestions to put extra stuff on the vehicle would scare you away! (You don't really need them.)
    My only suggestion is to always use good oil filter...I always pick up the OEM's at the dealer because if you buy 3 it's only $12 (Used to be $10 but still a good deal for OEM) Don't EVER buy Fram filters.
    71_340 and TTU19[QUOTED][OP] like this.
  22. Jan 13, 2018 at 8:53 PM
    #52
    71_340
    71_340 The German
    Hans
    FLW, MO
    Lots of good advice here. Bottom-line is to use a quality filter and the correct viscosity synthetic oil (I only use Mobil 1 in all our vehicles and I think that is what the Toyota dealer uses).
    One thing I like to add is to make sure your oil is at operating temperature and change it as soon as you can after turning the engine off, that way if there are any contaminants they are still suspended in the oil and drain out. Since my truck is under Toyota Care I will use the dealer but will make an appointment and will show up shortly before the scheduled time and my oil will be hot.
  23. Jan 13, 2018 at 8:55 PM
    #53
    Great advice there.
    This is where a Fumoto valve is awesome.
  24. Jan 13, 2018 at 9:03 PM
    #54
    71_340
    71_340 The German
    Hans
    FLW, MO
    Never had a Fumoto valve or similar device, I imagine it will come in handy. Unless the vehicle is under warranty I do my own oil changes and burned my fingers many time using my method.
    Eclipsed & Floating likes this.
  25. Jan 13, 2018 at 10:50 PM
    #55
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    No, never heard of this. :eek:
  26. Jan 25, 2018 at 1:03 PM
    #56
    Noodle
    Noodle That Guy
    Files creek
    2016 Tundra Limited TRD DC Inferno
    So I’m in the middle of my oil change , purchased the metal oil filter housing off Amazon. There is a difference in heights of the vent tube inside my new housing. Do I need to swap the tube from my old plastic housing? Not trying to have any leaks, it looks like a simple deal if necessary. Anyone else have this issue?
    4A290F43-1D84-4559-BDC7-241665575DE6.jpg F462BE02-5710-4A64-853A-7D51557BEAC6.jpg
  27. Jan 25, 2018 at 1:15 PM
    #57
    15whtrd
    15whtrd Mr. Blonde
    You definitely need to change the tube over. It has to match the length of your filter.
  28. Jan 25, 2018 at 1:47 PM
    #58
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    The one you bought is for smaller Toyota engines. My wife’s Highlander has that exact canister.
  29. Jan 25, 2018 at 1:50 PM
    #59
    15whtrd
    15whtrd Mr. Blonde
    Yeah I think they put it on the Venza too. Same canister you just need to swap the tubes.
  30. Jan 25, 2018 at 2:03 PM
    #60
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Back in the '40s (and maybe the '60s) and before, oil was a bit of a crap shoot. Valvoline and Amalie were paraffin based and would quickly gum up an engine. I helped tear down an engine once that ran Valvoline exclusively and was religiously changed every 3000 miles. We had to use putty knives to scrape out the crud. The old mechanic I was helping said he'd seen that on every Valvoline and Amalie engine. Lots of tricks were used to prevent that. Some would even drain the crank case and fill it with diesel or kerosene once a year and use that to clean the sludge out of the engine. Now, modern oils have all of the detergents needed to prevent that. Adding transmission fluid just reduces the lubricating qualities of the oil, and will probably void the warranty if there's a problem.
    TTU19[QUOTED][OP] likes this.
