Oil change tips
Discussion in '2.5 Gen Tundras (2014-2021)' started by TTU19, Jan 12, 2018.
  1. Jan 12, 2018 at 9:18 AM
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Going to attempt to change my own oil tomorrow. My father-in-law will be helping which he does his own oil all the time.
    Any tips at doing it on the Tundra?
    What oil does everyone like to use, Brand, weight? Any certain oil filter?
    Thanks..!
  2. Jan 12, 2018 at 9:39 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    It’s easy. Mobil 1 0-20.. I use genuine Toyota filters. It’s a cartridge style. I get them off Amazon.
    BenAZ and Bear like this.
  3. Jan 12, 2018 at 9:42 AM
    Mobil1 0W20 OEM oil filter...get a Fumoto valve to slap on your oil pan no mess with the tube and the other valve that connects to the oil canister drain no mess either
  4. Jan 12, 2018 at 9:43 AM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Mobile 1 0w20 ... the stuff made for Toyota.
    Stock filter.
    Too make it easier for future uses look at fumoto valve for the drain plug. The Toyota specific filter wrench for the filter housing cap. Now if things get a little messy(which they may) I always like to clean up with some cans of brake cleaner and paper towels. That way there are no drips in the driveway later.
    nk1794 and NewImprovedRon like this.
  5. Jan 12, 2018 at 9:46 AM
    https://www.ebay.com/ulk/itm/121924002137
    _Jim_, TheDude80, nk1794 and 3 others like this.
  6. Jan 12, 2018 at 9:51 AM
    BWinter
    BWinter New Member
    Central California
    2018 White 1794, TRD Off Road, 4x4
    Do you have the oil filter wrench for the oil canister? Oil filter is inside a cartridge and not a "normal" spin on type.
  7. Jan 12, 2018 at 9:54 AM
    Napa put one out... but I don't know the part number to it
  8. Jan 12, 2018 at 9:56 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Hummm.. Looks like I may not be doing this tomorrow then. I can't just get it at the local auto store and have to order parts online.
  9. Jan 12, 2018 at 9:57 AM
    Fumoto valve ordered online less u go on ther site see to find a dealer locally...other valve order online
  10. Jan 12, 2018 at 10:01 AM
    Same part# for a 2016
  11. Jan 12, 2018 at 10:09 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Ok, so I need that wrench and the tube thing. Where is the best (cheapest) place to get the filter? You wouldn't recommend a different well known oil filter brand, just the Toyota?
  12. Jan 12, 2018 at 10:13 AM
    Lots of members on here go with OEM... I've seen one member on here use a K&N cause he posted a pic of it
  13. Jan 12, 2018 at 10:16 AM
    And also I've seen other's on here mention the canister the one we have is plastic there is one off Amazon that it aluminum or metal type the tube deal is if you don't want a mess it's really up to you
  14. Jan 12, 2018 at 10:19 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    What about the TRD High Performance oil filter? Is that different from a "regular" one. It's only $12
  15. Jan 12, 2018 at 10:21 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Also, my father-in-law, a long time car guy, swears by putting a qt of transmission fluid in with the oil. He says it helps keep it from gumming up. Anyone else do that?
  16. Jan 12, 2018 at 10:23 AM
    Juanjoolio007
    Oregon
    You could get the filter from Toyota and maybe the wrench. Or get that filter wrench from Napa. You don’t need the Fumoto valve to get your oil change done.
    You can add that later at anytime. Even when not wanting to change the oil. You just have to use the old vacuum trick. Stick the hose end of a vacuum over the fill neck and turn it on. Then pull your drain plug and insert the fumoto valve. The vacuum will hold all the oil and not let any drip out or suck it up through the motor.
    Ideally yes gather your supplies and then change the oil if you have the time. I get the filters off Amazon. Oil from Costco or Walmart when on sale.
    TTU19[QUOTED][OP] likes this.
  17. Jan 12, 2018 at 10:23 AM
    Never heard of that?!?!? I know I wouldn't do that
  18. Jan 12, 2018 at 10:24 AM
    Not sure on that one maybe someone else chime in on it
  19. Jan 12, 2018 at 10:28 AM
    Juanjoolio007
    Oregon
    I don’t think that’s necessary. Maybe in the days of 10w40 or 20w50 but not with 0w20 oil. It would basically act as an engine cleaner if it was used in thicker oil.
    This one time(about 15 Years ago) I did an oil change on a customers car on another Tech’s rack. His trans fluid and oil guns were reversed from mine. I didn’t notice and sent a car out with 100% atf in it. It came back 6 months later just fine.
  20. Jan 12, 2018 at 10:28 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I'm not an expert by any means but just use what is recommended for oil type. Todays vehicles are made to use specific types , weights, etc. Oils cheap new trucks are not. stick to the book.
  21. Jan 12, 2018 at 10:34 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I’d just take it to the dealer mine charges like $54,really not much savings doing it myself less mess less hassle.
  22. Jan 12, 2018 at 10:37 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Anyone use ramps or is there enough room under there?
    Prostar 190 likes this.
  23. Jan 12, 2018 at 10:38 AM
    Cfincke
    San Antonio
  24. Jan 12, 2018 at 10:43 AM
    Cfincke
    San Antonio
    Since you do not have the Fumoto valve installed, be prepared for the oil to shoot out at the inside of your passenger tire and on the ground. I made a huge mess the first time i changed the oil
  25. Jan 12, 2018 at 10:47 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    me either but why would you even think about it with syn?
  26. Jan 12, 2018 at 10:59 AM
    I don't but... I have a 6" lift:D I us Mobile 1
    0-20w and Toyota filter or Wix gold
    Bear likes this.
  27. Jan 12, 2018 at 11:08 AM
    avgasman
    avgasman New Member
    It never ends does it?
    Do not do this /\ - you'll dilute the additive package in the synthetic oil .
    Maybe in the 60's you'd add some ATF to cure a noisy hydraulic lifter but them Magic Mystery Oil is the go-to for that issue.
    Tommy's Tundra, tye and Taco-Blender like this.
  28. Jan 12, 2018 at 11:50 AM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
  29. Jan 12, 2018 at 12:06 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I recommend having the oil filter wrench on hand, sometimes that cartridge canister is B to unscrew.
    I use Mobile1 High Mileage 0w-20. I use an OEM filter.
    I have heard of adding a Qt of ATF to motor oil but only on older vehicles that required more viscous (thicker) oil. It should not be necessary on the Tundra.
    I also top off the grease zerks every time I change my oil. Toyota says this is supposed to be done every 5k miles. On the 2007 Tundra (4x4) I have, there are only 5 grease zerks and they are all on the driveshafts.
    tehiv likes this.
  30. Jan 12, 2018 at 12:08 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
