OEM radio
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenTundra1867, Sep 4, 2021.
  1. Mar 19, 2023 at 2:37 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Have you tried holding the cassette in the palm of your hand, then "smacking it smartly" against a flat surface? I don't know why this would work, but it's the advice Books on Tape would offer.
  2. Mar 20, 2023 at 7:18 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    What's a tape? :D
    tvpierce likes this.
  3. Mar 21, 2023 at 2:11 AM
    w666
    Maryland
    I would have said "what's a book"...
  4. Mar 21, 2023 at 7:25 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    It’s an analog version of the mp3.
    If you don’t know what “analog” means, you can get an overview from a book on tape.
    artsr2002[QUOTED] likes this.
  5. Mar 21, 2023 at 4:27 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    I have one you can have. 2006 DC JBL.
  6. Mar 21, 2023 at 7:33 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    06 and 01 radio opening width is different.
    Jack McCarthy likes this.
  7. Mar 21, 2023 at 10:00 PM
    artsr2002
    'Yonder
  8. Mar 22, 2023 at 6:42 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Isn't the OP's truck an 06? I just skimmed and threw it out there...
  9. Mar 22, 2023 at 8:06 PM
    NickB_01TRD
    Nick
    KY
    Op, yes. The guy who is asking the most recent questions about the tape player, no
  10. Mar 22, 2023 at 11:40 PM
    Legionnaire
    Legionnaire New Member
    Tucson, AZ
    2001 Jade Tundra AC 4x4 v8
    I have an 01 and bought another radio on eBay. It doesn't play in slow motion like the last one, but there is still a loud buzzing noise. The seller said it worked perfectly. I might look around for loose grounds. The buzz sounds very mechanical though. The music sounds PERFECT just this loud loud buzz/rattle.
    Video: https://photos.app.goo.gl/gQ77hwM1mGapwwNKA
  11. Mar 22, 2023 at 11:44 PM
    artsr2002
    'Yonder
    Sounds like a gear slipppppping
  12. Mar 24, 2023 at 7:57 PM
    Legionnaire
    Tucson, AZ
    Hard to investigate because you can't plug it in to see it working while it's actually turned on. Will report back if I ever fix it...
  13. Mar 25, 2023 at 4:34 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I agree with @artsr2002 -- sounds like a plastic gear slipping/grinding.
    Is the buzzing sound coming from the head unit or the speakers.
  14. Mar 25, 2023 at 11:52 AM
    Legionnaire
    Tucson, AZ
    It's 100% coming from the head unit itself. Hard to look inside to see the mechanisms moving
  15. Mar 25, 2023 at 10:35 PM
    artsr2002
    'Yonder
    As bad as it sounds it's bound to have some wear on the gear. Maybe you can take it apart and see which gear it is.
  16. Aug 20, 2023 at 3:11 PM
    srsupertrap
    srsupertrap New Member
    2001 Tundra Access Cab SR5 TRD V8 4WD
    Don't mean to jump the thread but looks like both the Op & Legionnaire's issues have been resolved. :thumbsup:
    I just picked up my 2001 Tundra with a Tomtom Navigation installed which nixes my previous 2001 Tacoma CDs collection. That is a problem in the Colorado backcountry or at least I think so. I am interested in installing a Tundra Gen 1 OEM radio/CD/cassette too. My vehicle spec sheet shows under Comfort & Convivence
    • POCKET W/CLTH INSET & ARMREST DLX AM/ FM ETR/CASS W/4 SPKRS CFC-FREE A/C/TILT
    • Is the DLX AM/ FM ETR/CASS W/4 SPKRS the stereo with amplifier or no amplifier?
    Since the Tomtom Navigation is installed, and when I purchased the truck it did not come with the original radio. My question is about the part number. Should I be looking for a 86120-0C030 with the amp mounted in the dash?
    Not sure whether later run Gen 1 OEM radios like 2004 - 2006 would plug into the factory harness or more correctly there would be no 2001 harness connector for JBL systems.
    Thanks,
  17. Aug 20, 2023 at 6:10 PM
    Best thing to do is to pop off the dash bezel and look to see if you've got the amp.
    We can speculate all day about what's on the sheet. I would expect a base model if only 4spk, i.e. no door tweeters, but let's just say ... the build sheets aren't always accurate.
    I recommend hitting THIS THREAD and scroll to the "Audio, audio upgrades and cameras..." section, there's directions there on how to find your amp. You have earlier model, so it'll be in the dash. That thread links to a spot with pics of where it'll be, what harnesses to use for bypass etc.
