OEM radio
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenTundra1867, Sep 4, 2021.
  1. Sep 4, 2021 at 2:11 PM
    FirstGenTundra1867
    FirstGenTundra1867 [OP] New Member
    Ron
    So. Cal.
    2006 access cab Limited V8 Auto trans 4x4 Tundra
    Removed aftermarket Pioneer unit and re-installed OEM 6 disk radio/cd/cassette unit.
    My 2006 Tundra Limited Access Cab has an after market radio in it and I want to replace it with the correct OEM radio. Problem is, I'm not sure which radio is correct for the 2006. The two types I've seen for sale on eBay are am/fm with cassette and CD players, and radios with all that but NOT the cassette player. Can anyone bring me up to speed on which is correct for my 2006 Limited? Thanks up front! Ron...
  2. Sep 4, 2021 at 2:30 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  3. Sep 4, 2021 at 2:42 PM
    shifty` Countin' and breathin', disappearin' in the fade
    There were at least three stereo setups for these trucks: Non-JBL stereo with no amplifier, Non-JBL stereo with amplifier, JBL with amplifier.
    I have a 2006 Limited Access cab with the non-JBL tape + CD combo I've removed from my truck and won't be reinstalling if it's interesting.
    I have the 6 speaker system, 2 in each front door, one in each rear door. My truck had a amp under the rear passenger seat which I also have in-hand.
    I have the original speakers as well, they've been for sale in the 1st gen sales forum for quite a while now.
    Can you check to see if there's an amp under a fabric cover in the passenger side cubby under the rear seat @FirstGenTundra1867 ?
    DaWhiteTundra and BubbaW like this.
  4. Sep 4, 2021 at 2:49 PM
  5. Sep 4, 2021 at 3:09 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    His is a Limited, which came standard with JBL with amplifier IIRC.
    Ron, if you go to Tundra Owners, create an account, input your VIN #, it should show what came with your vehicle.
    Toyota Owners Registration
    I will give it some thought but I might consider getting rid of mine out of my Limited along with the amplifier !
  6. Sep 4, 2021 at 3:22 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Mine has been sitting in my closet for the last 15 years. I'd give it away for free but one of the amps has a bad solder joint and cuts out intermittently plus its an 02.
  7. Sep 4, 2021 at 3:38 PM
    FirstGenTundra1867
    Ron
    So. Cal.
    Bubba: I've never used a forum format like this one, so I hope this gets to you. I don't know if we have a private conversation going here, or if it's an extension of my original post. It's going to take some getting used to. Please let me know if you get this. Thanks, Ron (FirstGenTundra1867).
  8. Sep 4, 2021 at 3:54 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Hey Ron, look up in right corner of page, select Inbox, sent you a conversation !
  9. Sep 4, 2021 at 4:06 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    I have a radio with tape and CD just like that image from my 2002 tacoma. If you want it let me know I am SO. Cal as well
    1lowlife likes this.
  10. Sep 4, 2021 at 4:08 PM
    SiberianTundra
    Greg
    War Machine
    2002 tacoma sr5 radio with cd and cassette
    I replaced it with after market unit
  11. Sep 4, 2021 at 4:39 PM
    FirstGenTundra1867
    Ron
    So. Cal.
    Thank you for the offer, but my Tundra is a 2006, so I'm unsure if your 2002 radio would be a true bolt-in. Do you happen to know the part # on your radio? As far as I can determine, the correct one for my truck would be #86120-OC100. Thanks, Ron (Near Pasadena, CA.).
    SiberianTundra likes this.
  12. Sep 4, 2021 at 4:46 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Do your have JBL on the speakers ?
    Have you created an acct at Toyota Owners and inputed your VIN # ?
    Have you located your amp, possibly where @shifty` mentioned ?
    My Limited had the amp behind the driver side rear seat behind the wall trim panel !
  13. Sep 4, 2021 at 5:04 PM
    FirstGenTundra1867
    Ron
    So. Cal.
    Hey, this is working! Lol. Re the Account at Toyota Owners--please let me know exactly what "Toyota Owners" is: A service offered by Tundras.com, or a Toyota Motor Co. website, or? As to my speakers, I just went back out to the truck and looked at them again but none of the 6 have the JBL logo. However they all look original to the truck, and are the same as the ones I had on my 2004 and 2005 Tundras, so I'm sure they are OEM. No sign of an amp in the location Shifty gave me, i.e., inside the storage bin under the rear passenger seat.
  14. Sep 4, 2021 at 6:05 PM
    So is mine, eh. Unless I'm reading wrong, we both have '06 Limited AC. But there's no JBL branding on anything in my truck, I've had all of it out, and my VIN doesn't come back with JBL anything.
  15. Sep 4, 2021 at 6:13 PM
    You don't need to create an account. Just use the link I gave. Plug in your VIN. It'll barf back the details on your truck and let you download a PDF with 'all specs'. That's where my image came from.
    The amp - you won't see it directly in the bin. The bin has a fabric or mesh liner in the bottom. You need to pull it up, amp should be underneath with the later-model access cabs, IIRC. You won't just see it inside. Let me see if I can find pics. I wish I'd taken some on my installl.
    Note he has a Double Cab, and the amp mounting place is different. Some earlier models had amps in the dash also. The one thing I think is being missed here is there are two different amplified systems. One is JBL. The other isn't. Crutchfield actually recognizes this as I recall, and I didn't know until I started plugging things into their site.
  16. Sep 4, 2021 at 6:20 PM
    Ok, so I can't find a pic online. But basically, my amp was under the carpet somewhere in the vicinity of the red arrows. I can't remember if there was a plstic piece covering it or not. The blue line was the basic path the wiring ran up to the head unit. Look round underneath that grey carpet.
  17. Sep 4, 2021 at 6:34 PM
    SiberianTundra
    Greg
    War Machine
    You can pick up the radio and give it a try if you like
    here is image of same head unit as mine (I stole image form eBay) But its identical
  18. Sep 4, 2021 at 6:48 PM
    @BubbaW This is how you know you have a JBL system.
    In this video, a DC like yours, with the amp on the back wall.
    https://www.youtube.com/watch?v=zMbZNdReTOw
    Notice when they get to the amp, JBL brands ALL of their audio equipment, you can see the orange JBL logo on the amp here.
    In addition to that, if you look closely at your old OEM head unit, there should be a JBL logo on it as well, likely in the same location.
    Here's my radio and my amp. Clearly - no JBL logo on the face. No JBL branding at the sticker. Toyota catalog doesn't say "JBL" for this part number. Same with the amp it clearly says it's made by Panasonic!
  19. Sep 5, 2021 at 3:53 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    It is Toyota Motor Co. and while you can get the Veh specs by simply putting your VIN # in, by creating an account, you can also see all Service History performed on your truck done at a Toyota Dealer !
    shifty` likes this.
  20. Sep 5, 2021 at 4:38 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    You can also enter your own service records as well as work you've had performed by third parties!
  21. Mar 18, 2023 at 2:50 PM
    Legionnaire
    Legionnaire New Member
    Tucson, AZ
    2001 Jade Tundra AC 4x4 v8
    I am looking to buy the OEM deck for my 01 Tundra AC. Here is a pic of my current deck. I have a lot of cassettes and mine just happens to be broken!
    Here is my spec sheet info
  22. Mar 18, 2023 at 4:00 PM
    Jack McCarthy
    Bill
    North of Boston
    Does the tape not advance when you put it into there radio? I’ve repaired quite a few boomboxes and most tape decks have a rubber belt that needs replacement when they break. The good news though is a lot of the belts are the same size so they can generally be replaced with a generic belt unless Toyota is devious enough to make it non-standard. Won’t know unless you open it up.
  23. Mar 18, 2023 at 4:17 PM
    Legionnaire
    Tucson, AZ
    Yeah I heard all those belts just turn to goo from the 80s Marantz decks and stuff. Good call, my symptoms are a big buzzing noise and the tape plays at about half speed. That probably is just the belt eh? I'll crack it open and report back.
  24. Mar 18, 2023 at 4:26 PM
    Jack McCarthy
    Bill
    North of Boston
    Check for a loose ground wire as well because they’ve been known to be culprit to noise.
  25. Mar 18, 2023 at 5:09 PM
    Legionnaire
    Tucson, AZ
    Took the radio apart, the speakers sound good. My CD plays crystal clear I think the tape deck just isn't engaging it flush to the winders.
    Here is an album with some photos and a video: https://photos.app.goo.gl/wRzXgUuXVBZJRJf59
    It grabbed it pretty flush in the video, but when you spin the decks manually if the tape isn't engaged down the little gears barely make contact. It's hard to test it without it moving, I tried to wire it back up as a carcass to watch it, but it's tough to hold all the pieces. The belt looks pretty good, but maybe it just needs to be newer and tighter.
  26. Mar 18, 2023 at 5:23 PM
    Jack McCarthy
    Bill
    North of Boston
    I can’t get the video to play even if I wait for it to “get ready to play” for some reason. Is the back plate holding the gears in place? Taking it off might give you a better look to see what’s happening physically.
  27. Mar 18, 2023 at 5:40 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Agree that the belt looks fine and appears to be properly taut. At the 1:00 mark onward it appears to work properly. I would blow it out good., lubricate those places that need lubricant and go from there. I'd even consider trying other cassettes.
  28. Mar 18, 2023 at 5:54 PM
    Legionnaire
    Tucson, AZ
    Thanks for the push to investigate y'all! Will do all that and then put it back together and if it's still problematic lemme know if anyone has one for sale ;)
  29. Mar 18, 2023 at 6:05 PM
    Jack McCarthy
    Bill
    North of Boston
    Finally got it to play. The video is very helpful.
    Something isn’t right about that mechanism. Normally when the tape is in there it should automatically lock into place (you shouldn’t have to push it down manually). I’ll have to take a look at mine since I haven’t played around with a car tape player setup.
    I’ll go check to see if it’ll load mechanically or if power is required for that task.
  30. Mar 18, 2023 at 6:52 PM
    Jack McCarthy
    Bill
    North of Boston
    Looks like the 02s use the same radio and the tape player needs to be powered to load the cassette. Jeez, it’s been a while since I’ve used one of these things.
