Lift / Wheels / Tires - What to do.
Discussion in 'Wheels & Tires' started by TTU19, Jan 26, 2017.
  1. Apr 25, 2017 at 9:16 AM
    #61
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    18 does
    TTU19[QUOTED][OP] likes this.
  2. Apr 25, 2017 at 9:33 AM
    #62
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Fuel Hostage , now I found these Hostile. Look bad ass..
    TTU19[OP] likes this.
  3. Apr 25, 2017 at 11:37 AM
    #63
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Man I'm at a loss on what to go with for my tires. True 35s, or something slightly smaller. Would a 33 or a 34.5 have be that big of a difference from the 35s. Any other benefits? Smaller tire is lighter so help with MPGs, not that it really matters, but I guess it could, huh?
    I dont know what I want. I just want it to stick out slightly, even with my flares or just a touch past them and look proportional and bad ass. This is all for street, nothing off road.
  4. Apr 25, 2017 at 1:25 PM
    #64
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Wes, first thing you need to determine is your offset. Go look at your truck and figure out how much more you want your tires to stick out than your stocks. This is a great formula to use...
    https://www.tundras.com/threads/tire-fender-overhang-formula.11063/
    Once, you know your offset, then you can decide on wheels and tires
  5. Apr 25, 2017 at 1:29 PM
    #65
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    And give us a pic from the front and rear of your wheels and flares. An angle like this...
    PermaFrostTRD likes this.
  6. Apr 25, 2017 at 1:42 PM
    #66
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Just when I think I know what I want in offset and someone tells me, someone else follows behind them that completely contradicts what the other said, ha. I'm still not sure which sticks out further, the +18 or +20. Which I guess is about where I want to be.
    I'll try to get a photo later.
  7. Apr 25, 2017 at 1:50 PM
    #67
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    the +18 sticks out further but by only 2mm. You won't notice the difference. I think that would be a good offset for you with the flares.
  8. Apr 25, 2017 at 1:52 PM
    #68
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I think @r4z0r51o has +18, and should have his flares on by now. Maybe Dave has some pics.
    r4z0r51o likes this.
  9. Apr 25, 2017 at 4:02 PM
    #69
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Unfortunately, I still do not have my flares officially on (still looking into getting my fenders clear bra'd before committing to it). But, Wes I can tell you that +18's will stick out 2mm's more than +20's. I've got +20's and I think it looks great combined with 295/60/20 (33.9"x11.6") without flares and it clears the cab mount by about 1/2 inch. However, since you're using flares I think with the +20's you'll want to run 12.5" wide tires to have them stick out just alittle bit more (Unfortunately that probably means you'll have to do the CMC). Another option that you can go with is to use +1 offset with 295 tires (but that might also require a CMC)
    Take a look at post #126 on my build thread for pics of when I test fitted my flares with the 295's (I'm more than likely staying with this combo after I install my flares for good, but only until I wear the tires down and will replace them with 35"x12.5" Nittos)
    https://www.tundras.com/threads/r4z...tallic-crewmax-5-7l-trd-4x4-build.6014/page-5
    @AriMiko43 has 35"x 12.5" tires on his +20's ... checkout post #472 and 474 for pics of his set up.
    https://www.tundras.com/threads/silver-sky-metallic-picture-thread.6356/page-16
  10. Apr 25, 2017 at 5:46 PM
    #70
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Thanks Dave. So you say in ur post that you'd for sure go 35s next time? Why?
    Yours looks good but I think I'd like mine to stick out just a touch further. So with a 35 and +18 I think I'd be good. I'll probably obviously have to do the CMC but that doesn't seem as bad as it sounds.
    I did like the other guys and he said he only gets a little rub. Not sure what lift he has but those wheels are like what I want, so they look bad ass on the truck!
  11. Apr 25, 2017 at 7:01 PM
    #71
    r4z0r51o
    Dave
    Wes, you basically hit on exactly why I want to go to 35's ... to make my tires stick out just alittle bit more. Honestly, if I could do it over I'd buy +1's (didn't think I was going to add flares) and either do the 295's or maybe still go 35's.
    Miko is on a LRO 3/1 lift, 20x9 +20's with 35"x12.5". Those Fuel Assults look great and the Fuel Pumps look pretty nice too. You couldn't do wrong either way.
  12. Apr 26, 2017 at 6:20 AM
    #72
    TTU19
    Wes
    Tx
    2021 TRD Sport
    I was talking to a guy who sales those wheels last night, and he doesn't have them in +18, but he does have +1 and he recommended them. I need to see what the actual distance difference is between +18 and +1. I dont want to stick out too far and look goofy. Which level do you have Dave?
  13. Apr 26, 2017 at 7:45 AM
    #73
    r4z0r51o
    Dave
    I don't believe that the Fuel Assaults or Pumps come in a +18. The only positive offsets I see are a +20 and +1 ... if you look at both mine and @AriMiko43's pics, the +1's are about 3/4" further out when you compare rim to rim not tire to tire (that is if you're thinking about a 9" wheel). If you want my opinion ... if you're going with 9" wheels, get the +1's and go with 295's minimum. If you're afraid that's stick out to much go with the +20's and get 35x12.5" tires. The difference between those two sets ups is about 1/4". If you want an even more aggressive look go with the +1's with 35x12.5" tires (that would be about 3/4" wider than AriMiko43's). Just keep in mine the wider and taller you go, that CMC will come into play. My level is 3/1 ...
  14. Apr 26, 2017 at 8:01 AM
    #74
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    .668"
  15. Apr 26, 2017 at 9:15 AM
    #75
    TTU19
    Wes
    Tx
    2021 TRD Sport
    I know you have a 3/1, but is it the Toytec Boss? I think that's what I'm going with, even though it's so damn expensive, ha.
    Yeah, I think I may just do that and go 295's and the +1 offset. For sure want 18x9. Tires wont be as big around, but with them sticking out a little further, they will still look really aggressive and a good look for the truck. At least I think that sounds like a good idea, ha. I dont want to be like you though and wish I had just gone 35s. Hummm..
    I dont think I'm as afraid of doing the CMC as I once was. Doing more research on it, it looks pretty simple. Another option is going with a new front bumber, ha. I've had my eye on that Go Rhino bumper. From the looks of it, it should alleviate the need to do the CMC.
    r4z0r51o[QUOTED] likes this.
  16. Apr 26, 2017 at 9:18 AM
    #76
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    csuviper and d0zer like this.
  17. Apr 26, 2017 at 11:20 AM
    #77
    TTU19
    Wes
    Tx
    2021 TRD Sport
    As you can see, it's pretty terrible, ha.
  18. Apr 26, 2017 at 11:38 AM
    #78
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Oh yeah, you need a good 2.5". That's gonna put you around 0 offset. Then assuming you get a 3" lift, it's going to be tough getting a 35" tire in there with that offset.
  19. Apr 26, 2017 at 11:57 AM
    #79
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Yeah, so we'll see. Can't wait until I can get it done. Going to run me about 4K just for the lift, wheels, and tires. Not to mention shipping, tax, install labor, alignment, CMC, and who knows what else.
    joonbug and Jsena like this.
  20. Apr 26, 2017 at 12:03 PM
    #80
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    $5500
  21. Apr 26, 2017 at 12:03 PM
    #81
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    That's the price I've been getting now. Not bad tbh
  22. Apr 26, 2017 at 12:05 PM
    #82
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I think I got mine done for around $4500. But that's with 5 wheels and tires.
    Jsena likes this.
  23. Apr 26, 2017 at 12:07 PM
    #83
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    But if I had to choose between the Lift and tires and all my other mods... I'd definitely choose the lift and tires.
  24. Apr 26, 2017 at 12:07 PM
    #84
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    That's a good ass deal then.. how much was your lift??
  25. Apr 26, 2017 at 12:15 PM
    #85
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Yeah no kidding.
    Toytec Boss: $1,700
    Fuel Assault: $250 x4 = $1,000
    Tires: $307 x4 = $1,300
  26. Apr 26, 2017 at 12:19 PM
    #86
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    I get what you mean, I am also looking at 4 grand for lift/wheels/tires.
  27. Apr 26, 2017 at 12:28 PM
    #87
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    pretty much like this...
    Toytec Boss: $1,700
    Method NV's (5): 900
    Tires, Tpms (5): 1800
    Jsena[QUOTED] likes this.
  28. Apr 26, 2017 at 12:41 PM
    #88
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    6112/5160: $882
    TC UCA's: ~$700
    CB Shims/Shackles Diff/Carrier Bearing: ~$400
    295/70R18 ST Maxx: ~$1,000
    SCS Ray-10's: ~$1,000
    joonbug[QUOTED] likes this.
  29. Apr 26, 2017 at 1:23 PM
    #89
    TTU19
    Wes
    Tx
    2021 TRD Sport
    I wish I could just do it all now, but may have to keep waiting.. blah. At least I kind of know where I want to be now and get.
  30. Apr 26, 2017 at 1:41 PM
    #90
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    The only thing I know I am guaranteed to do on that list this year is the wheels and tonneau cover, since its makes most sense to jump on them in the G.B. Otherwise it all depends on how my side woodworking business goes.
