Lift / Wheels / Tires - What to do.
Discussion in 'Wheels & Tires' started by TTU19, Jan 26, 2017.
  1. Jan 26, 2017 at 10:17 AM
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    So I mentioned in another thread the other day about what would be some lift options, and got a lot of good info. I wanted to start a new thread though so I could easily go back and find that info. Anyone who can offer more input or advice, I would greatly appreciate it.
    What I want to do:
    I'd really like to go with 35's as my tires. I wasn't sure what size lift I'd need to do though so I wont have to chop anything up. Several guys suggested just going with the 3/2 level and a slightly smaller tire, I believe a 34.5 or so. So I guess my lift options are the BOSS or Bilstein.
    I guess my question now is, how do you go about getting a good offset? Is that done just through the rims you go with? I dont want to have spacers on it. While on that subject, not sure if I want to keep the 20" or go with an 18" wheel. What wheel size and bolt pattern and offset should I be looking for?
    Sorry to be such a newb at this. I'm pretty good with everything, but the lifts and things blow my mind, ha. I dont want to walk into a shop and get my eyes poked out just to get the look I want.
    geno0506 likes this.
  2. Jan 26, 2017 at 10:22 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    offset is determined by the wheel you choose. You definitely want to stay within the +18 to +35 The smaller the number, the more the wheels will stick out.
  3. Jan 26, 2017 at 10:24 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Wes, go with 18's at a 18 mm offset and you'll be good to go. They'll ride smoother (and look better) than 20's.
    295/70/18s will fit without a CMC at that offset if you run the boss kit
  4. Jan 26, 2017 at 10:26 AM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    Definitely will keep an eye on this thread. I'm new to the shocks and lift stuff as well since I've only ever had sports cars before this.
    As far as your wheels go, your offset and backspacing is based off of your wheels. On our trucks around +35 offset gets you about even with the side of the truck. The +18 or +20 puts you even with the fender flares if you have them.
    Wheels run a 5x150 lug pattern.
    And as far as whether to stick with the 20s or 18s, it's all personal preference. If you're doing off-roading, a lot of guys like running the 18s because they can get more rubber aka cushion for their wheels. Although a 20" wheel is still capable off-road. Personally, I like the balance of a 18" wheel with 33" tires and a 20" wheel with 35+" tires. But that's just my preference.
    r4z0r51o likes this.
  5. Jan 26, 2017 at 10:31 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Yeah, I have the fender flares, so I want an offset that is just beyond that I think. Much more than that and I think trucks look goofy, ha. I wont be doing any offroading, so either one will work for me. I was just thinking 18s because a lot of people go that route, but they are also usually a little cheaper than the 20s. Ha.
    zcarpenter92 likes this.
  6. Jan 26, 2017 at 10:32 AM
    joem1cha3l
    Albany, NY
    My offset on my wheels is +12. Set me flush to the outside of the fender flares before I removed them
  7. Jan 26, 2017 at 10:32 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Here is my truck for reference:
  8. Jan 26, 2017 at 10:56 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    18"with +18 offset. No flares.
    TTU19[OP] likes this.
  9. Jan 26, 2017 at 11:06 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I think with fender flares, 18 mm is a good offset. It will get you roughly even with pocket style fender flares. If you want the tires to stick out more your will have to get lower offset wheels. Then the chances are you will be getting a smaller tires. 0 mm offset, for instance, pretty much maxes out at about 33 inch tires. This is assuming that you don't want to cut anything serious on the truck.
    Zharris likes this.
  10. Jan 26, 2017 at 11:08 AM
    chphilo
    Western PA
    Double post. Sorry, it's pain to try to post things on a iPad (I am so used to doing everything from my Computer)
    18s will give you more comfortable ride. More rubber also means less chance of wheel damage. Cheaper to boot.
  11. Jan 26, 2017 at 11:26 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Thanks..! So in looking at wheels on 4 wheel parts for instance, I look for those with a 5 on 150. Is it an 18x10 or an 18x9? What is the difference? haha.. In Fuel, I'm seeing offsets of 20, 1, -12, -24. I guess I'd want to go with 20, huh?
    GNTundra likes this.
  12. Jan 26, 2017 at 11:28 AM
    Zharris
    Zharris Merica!
    18x9 or 18x10 is the width of the wheel. I think most people run the 18x9, which is what I have. It depends mostly on what tire you're going with. When you research the tire it will give you a list of approve wheel widths which is usually from like 8-10, so you should be good either way. I think the 9" is most common though. And yes, the +20 would be your best bet out of those options.
    TXMiamiFan likes this.
  13. Jan 26, 2017 at 11:29 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    If you're keeping your flares, +18 is probably good. Remember, the more it sticks out, the more you're going to rub and either you have to get smaller tires or have to start chopping. As far as lifts go, these were the options I considered, depending on budget.
    cheap- go 5100's all around
    economical- OME lift
    medium- Fox or Toytec Boss
    baller- Icon or Kings
    And I would try to stick to about 3"/1" to 3"/1.5". I think 3"/2" has way too much rake.
    zcarpenter92, WatTundra and Zharris like this.
  14. Jan 26, 2017 at 11:32 AM
    Zharris
    Zharris Merica!
    I think the 3/1.5 is the best look on a lift. Eventually, that's what I'm putting on mine.
  15. Jan 26, 2017 at 11:32 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Try to stick with 18x9. 18x10 will just add unnecessary weight on your wheels.
  16. Jan 26, 2017 at 11:34 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    I was thinking that I'll probably go for the BOSS lift, but I'm not sure what the Fox lift costs. I want a really good ride, smooth like it is now. I think with one of those, you can adjust the back to be either of those settings, right? Yeah I want to keep the flares and really dont want to chop anything.
  17. Jan 26, 2017 at 11:35 AM
    Zharris
    Zharris Merica!
    If you buy the shackles for the rear you can adjust it from 1" to 1.5"
    I've been pricing some of the Fox stuff and it looks like the complete set of Fox would wind up costing around $2500. As best I can tell anyways.
  18. Jan 26, 2017 at 11:35 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Is there a certain Hub Bore that I need to be looking for? They all seem to be different.
  19. Jan 26, 2017 at 11:36 AM
    TXMiamiFan
    Jose
    I got the Boss and it's getting installed tomorrow. Got UCAs to go with it and I'm chopping the cab just in case; better to do now then worry about it later and miss another day at work for it. Staying with my 18x9 with +18 and going with 35s.
    joonbug and TTU19[QUOTED][OP] like this.
  20. Jan 26, 2017 at 11:37 AM
    Zharris
    Zharris Merica!
    110 for the hub bore
  21. Jan 26, 2017 at 11:38 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
  22. Jan 26, 2017 at 11:39 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    110mm bore size
    TTU19[QUOTED][OP] likes this.
  23. Jan 26, 2017 at 11:40 AM
    Zharris
    Zharris Merica!
  24. Jan 26, 2017 at 11:41 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    I'm sure you will, but you'll have to let me know how it comes out. I'll probably be doing something very similar.
  25. Jan 26, 2017 at 11:42 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Yup that one looks good. I have +25 offset so my wheels are tucked in 7mm more than those +18's. I personally don't know how that'll affect rubbing. You may want to wait til @COMiamiFan does his to order your tires. You're going to be really close to having to do a CMC.
  26. Jan 26, 2017 at 11:43 AM
    TXMiamiFan
    Jose
    Yep. Will be posting. Won't be until Saturday as I don't get mine done until EOD Friday. So will be late to post pics. But drive home will be 40 miles so good chance to check the ride on the highway.
  27. Jan 26, 2017 at 11:43 AM
    Zharris
    Zharris Merica!
    Just a heads up, if you run 35's I think everyone has had to do some minor trimming or heating and restructuring the front liners on the truck. I don't know how much you'd wanna trim.
  28. Jan 26, 2017 at 11:44 AM
    TXMiamiFan
    Jose
    I'm doing the CMC. Might as well bite the bullet now . . .
  29. Jan 26, 2017 at 11:45 AM
    Zharris
    Zharris Merica!
    I don't blame you. But the OP said he didn't want to do any chopping or anything. So I was just letting him know about the trimming and stuff. Didn't know what all he wanted to get into doing.
    TXMiamiFan[QUOTED] likes this.
  30. Jan 26, 2017 at 11:45 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    I've still got a little while before I can pull the trigger on everything, but I wanted to start researching it. Find what I want, price things out and go from there. Need to pay off some other stuff first, then figure out what to do so my truck can stay covered. With the lift and tires, I'm afraid I might have to modify my garage entrance to fit along with a new garage door, or build a carport over my storage garage to park under, haha.
