Least liked feature about your 2nd Gen Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by bleach, Jan 11, 2021.
  1. Jan 26, 2021 at 6:57 PM
    #91
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    It functions as one or the other
    It won’t switch between the two without going through the setup to switch
    bleach[OP] likes this.
  2. Jan 26, 2021 at 7:00 PM
    #92
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I see what you mean. That would suck. My Kenwood eXcelon is pretty seamless in that respect.
  3. Jan 26, 2021 at 8:30 PM
    #93
    ACDC2ZZTop
    Travis
    Oregon
    I have a new jvc head unit waiting patiently on my workbench to be installed...was going to happen soon since I just cleared out space in my garage to work out of the elements until it became a storage unit for one of my adult kids for the next 3-4 months
  4. Jan 27, 2021 at 12:53 PM
    #94
    bleach
    bleach [OP] MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    There's another thread out there about the TPMS system so I'll include it in the disliked features about our trucks. It is a pain to deal with when you need to replace the sensors. It really doesn't tell you which tire is low and it's obvious which tire is low when it does finally light up. Luckily there is a simple wire splice that takes only a few minutes to "fix".
    https://www.tundras.com/threads/disable-tpms.1056/
    JBSTOY likes this.
  5. Jan 27, 2021 at 12:54 PM
    #95
    Rica25
    Ricardo
    Tulare
    Mine works perfectly fine. No issues
    bleach[QUOTED][OP] likes this.
  6. Jan 27, 2021 at 12:59 PM
    #96
    bleach
    DJ
    Battle Ground, WA
    I tried using it last Monday. I was behind a Sienna whose exhaust smelled like rotten eggs. I held the button on for several seconds but then it opened up a few minutes later and the smell was back. POS.
    Rica25[QUOTED] likes this.
  7. Jan 27, 2021 at 5:41 PM
    #97
    JBSTOY
    JBSTOY Was tired, so I woke up.
    Jack
    Unknown Origen
    2008 Toyota Tundra SR5 4x4 5.7litres of goodness
    Bilstein 6112s Front Bilstein Rear Fuel Rims
    I have not but I hear it is a pain too.
    bleach[OP], Rica25 and Black Wolf like this.
  8. Jan 27, 2021 at 6:14 PM
    #98
    It was 9 degrees this morning at 5am. I still didn't use the floor vents......:benchpress:
    bleach[OP] and Rica25 like this.
  9. Jan 27, 2021 at 6:17 PM
    #99
    It is a pain but not as bad as replacing the starter. Fortunately I've never had to replace either one......yet
  10. Jan 27, 2021 at 7:33 PM
    #100
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Trade for higher trim!
  11. Jan 28, 2021 at 8:50 PM
    #101
    bleach
    DJ
    Battle Ground, WA
    I usually only use the floor vents for heat. I don't usually like warm air blowing on my face. Warm air rises anyway. I still feel some heat blowing from the main vents even when it's set to just the floor vents.
    Terndrerrr and Rica25 like this.
  12. Jan 28, 2021 at 10:47 PM
    #102
    CM2007
    CM2007 New Member
    Northern California
    2007 CrewMax SR5
    TRD Exhaust, Dark Tint, Bluetooth (2020 or earlier) License Plate Camera (2021) Tyger T1 Roll Up Tonneau (2021) Loncky leather steering wheel wrap (2021) Dechromed with Plasti-Dip (2021) Osram Reverse Bulbs (2021) Bilstein 6112s up front (April 2021) 2022/2023: New Head Unit (Android?) Sliders/concealed running boards
    How about the RADIO randomly turning off and on.
    I had no idea this would be an issue. Sounds like it’s an internal problem with the OEM head unit (07). The only recommendation I’ve seen is replace the head unit.
    Rica25 likes this.
  13. Jan 29, 2021 at 3:49 AM
    #103
    If find that the cabin heats or cools quite quickly. I angle the vents accordingly. Much easier to do with my 14 vents than it was with my 07 vents since they wouldn't stay in position.
    Rica25 likes this.
  14. Jan 29, 2021 at 4:18 AM
    #104
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    My seat belt safety locks while trying to put it on. I must pull it too quickly for its liking.
    Mattyc and Rica25 like this.
  15. Feb 21, 2021 at 11:08 AM
    #105
    audiowize
    Paul B.
  16. Feb 21, 2021 at 11:21 AM
    #106
    cygan1008
    cygan1008 New Member
    “RIP” 2013 Tundra TRD Rock Warrior, 2018 TRD SPORT CM 4x4 SUPER WHITE Eibach Pro 2.0 275/65/20 Recon Grapplers
  17. Feb 21, 2021 at 12:40 PM
    #107
    CincYOTA
    CincYOTA New Number
    2012 Tundra SR5 DC 5.7 4x4
    I would love to change the setting on the automatic door locks. When I press the Setup button, it just changes the display between English and Metric (units). It does not cycle through the next item to customize. What am I doing wrong? I could not find a separate thread on this issue.
  18. Feb 26, 2021 at 9:24 AM
    #108
    bleach
    DJ
    Battle Ground, WA
    I also don't like the location of the manual shift indicator number on the gauge cluster. Most of the time the steering wheel obscures it.
    Rica25 likes this.
  19. Feb 26, 2021 at 9:39 AM
    #109
    Notarobot
    2013 CM
    The passenger A-pillar/mirror mount is a massive blind spot.
    pyrite808, Rica25 and bleach[OP] like this.
  20. Feb 26, 2021 at 3:15 PM
    #110
    Noob Saibot
    Noob Saibot New Member
    Lehigh Valley, PA
    2008 5.7 Crewmax Ltd
    I don't know if this counts since this is something missing (to me), but being new to the Tundra the only thing I am bummed about is the lack of bolt-on (i.e. no drill) attachment points for a roof rack like there are for the Taco.
    pyrite808, bleach[OP] and Rica25 like this.
  21. Feb 27, 2021 at 9:11 PM
    #111
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Still scrolling but the answer to why cars auto lock is for crash safety. Unlocked doors under impact can open witch is a big no no due to occupants safety an removing a structural item for body while it continues get impacted or rolls. The locked door adds that safety rating an will save your life in the event of a like crash.
    Wynnded and bleach[OP] like this.
  22. Feb 27, 2021 at 9:14 PM
    #112
    NueveTundra
    Planet Earth
    If you leave your headlights on all the time they turn off after 30 seconds of being lock or off instantly with double locking.
    Notarobot and bleach[OP] like this.
  23. Feb 28, 2021 at 8:46 AM
    #113
    bleach
    DJ
    Battle Ground, WA
    It can also hinder rescue attempts if it can't be unlocked because of a crash. I want to be the one in control of any safety device. My wife's '06 Acura does not automatically lock. You have to lock yourself in manually, which we do.
    fixnfly and Rica25 like this.
  24. Mar 1, 2021 at 6:39 AM
    #114
    TXTundraFan
    TXTundraFan New Member
    My only gripe on my 2010 SR5 Crewmax would be the headlight intensity being so bad. Then again our RAV4 and Corolla Hatch have LED headlights. Other than that I love the truck! The MPGs suck but then again it's a heavy large V8 powered machine, what would you expect? :). 217.5k miles and I'm hoping I can make her last 5-6 more years at least. I average about 13-13.5 with pure short city stop and go trips. Maybe 4-5 miles round trip tops.
  25. Mar 1, 2021 at 7:14 AM
    #115
    bleach
    DJ
    Battle Ground, WA
    The lights are great compared to the Ford's I moved on from. I swear even their high beams wear only as bright as my Tundra's low beams. And that was even with new OEM headlights!
  26. Mar 1, 2021 at 7:27 AM
    #116
    idiggplants
    idiggplants New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels softopper ditch lights
    agreed. my 2009 f150 had these massive headlight housings, and a dual purpose hi/lo bulb. complete garbage. even my fathers 2012 f250 has a dual use bulb.
    moving to the toyota was a huge upgrade. 2 separate bulbs for high/low.. not sure i would need more than that. sure, led and projector headlights are all great and all, but they werent really a common thing in 2013. if i was buying a 40k 3rd gen, id see it as a significant annoyance.
  27. Apr 27, 2021 at 10:24 PM
    #117
    ACDC2ZZTop
    Travis
    Oregon
  28. May 4, 2021 at 11:09 PM
    #118
    xunil76
    xunil76 New Member
    TX
    2008 Toyota Tundra Crewmax Limited 4x4
    my least liked feature (aside from the fuel economy, obviously) is the total absence of the option of having a rear diff lock. sure, i'd love to have a manual transmission, but i can deal with automatic. sure, i'd love better MPG's, but i can tow 10k lbs. but seriiously, no locking rear diff option in the 4x4 model? c'mon Toyota......
    oh, and the 2 valve springs that broke on my engine this last November when i was still 3 hrs away from home, just cruising down the highway, no towing or load of any kind....yeah, that also sucked major donkey balls.....
  29. May 5, 2021 at 12:57 AM
    #119
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Our 2008 sequioa does the same. Very annoying. Scary at times to be hit with blaring music while rolling 55 in an otherwise quiet occupant area.
    I've only read about this issue sparsely as it doesn't seem to be too common. The fix is as you said based on readings "replace radio."
  30. May 5, 2021 at 6:39 AM
    #120
    xunil76
    xunil76 New Member
    TX
    well i personally recommend replacing the stereo anyway, even without such problems...i've yet to hear or use any factory stereo system where i thought to myself "hey, this isn't half-bad, i think i'll keep it". no...i doubt factory systems will ever compare to even a good budget aftermarket build, much less if you actually put some time & effort into the build.
    sound system replacement has always been my first mod in any vehicle i've ever owned, and well worth the time & money.
    bleach[OP] and BlueCrushSC16 like this.
