Icon 58650’s
Discussion in 'Suspension' started by LT75, Jan 19, 2019.
  1. May 16, 2019 at 10:39 PM
    #91
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This thread has a ton of really good data and experience in it. My truck is a 2wd and now I’m really wondering what springs my icons have. My truck has always ridden way too hard. If I have 650’s I’ll be glad to step down to 600 with my lower weight
  2. May 16, 2019 at 10:45 PM
    #92
    jabula_za
    jabula_za New Member
    Shaun
    Sabre Springs, CA
    2017 Tundra SR DC 4x4
    Icon 2.5s with RR & CDCV, 17x8.5 Method MR316 with BFG AT K02 32.6x17x10.5. K&N Filter, Blacked out tailgate emblems.
    IVD-58650 2007+ Toyota Tundra Front Coilover Kit
    IVD-58750 2007+ Toyota Tundra Remote Reservoir Coilover Kit
    IVD-58750C 2007+ Toyota Tundra Remote Reservoir CDCV Coilover Kit
    These are the different part numbers not sure it indicates the spring rate but could be wrong
  3. May 16, 2019 at 10:51 PM
    #93
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Wouldn’t make sense that they use different spring rates depending on the reservoir. The spring is to hold up the truck and the truck weighs the same
  4. May 16, 2019 at 11:02 PM
    #94
    jabula_za
    Shaun
    Sabre Springs, CA
  5. May 17, 2019 at 7:08 AM
    #95
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    @Icon_Adrian
    Adrian, what springs are 286911? That’s the only markings I see on my coilovers
  6. May 17, 2019 at 7:25 AM
    #96
    LT75
    LT75 [OP] Seasoned Pro
    Saint Charles, IL
    No mods yet
    Stock springs on the 58650 are 600lbs.
  7. May 17, 2019 at 2:45 PM
    #97
    Amnesiac
    Amnesiac When I am king, you will be first against the wall
    PDX
    2019 Superwhite TRD Sport
    I emailed Icon about this exact question yesterday, below is the response I got. Both the 58650's and the 58750's use a 600lb spring and *should* net you 3-3.5" at max preload. Now, I have been doing a ton of research before I drop $4k + on a suspension and given what I have read I'm not going to risk needing to redo and deal with warranty claims. I'm sure it was just a handful of people that dealt with well below advertised lift, but I'm not willing to risk having to deal with that process.
    I need to call and verify, but from what I have read the Fox 2.5 coilovers use a 700lb spring and offer a 0-2" lift version or 3" lift version that requires UCA's. At this point I'm planning to go with the Fox 2.5 3" version when I do my suspension down the road.
    Redrider29 and monaco730 like this.
  8. May 17, 2019 at 3:22 PM
    #98
    LT75
    Saint Charles, IL
    No mods yet
    I would have asked if they knew about the Eibach spring issue that affected their coilovers.
  9. May 17, 2019 at 3:38 PM
    #99
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If fox uses a 700 lbs spring that would explain why a few guys have gotten a ton of lift out of their Fox coilovers lately
    monaco730 likes this.
  10. May 17, 2019 at 3:53 PM
    #100
    Amnesiac
    PDX
    So I just called Fox to verify. The 0-2" version use a 16" 600lb spring, and the 3" lift version use a 17" 700lb spring. He said that a lot of the feedback they have received matches what I have been reading here, people are experiencing a good deal more that than 3" advertised lift. Which honestly is kind of good know that you won't have to max out if you want a solid 3.5" of lift.
    @JNorman84 was nice enough to indulge me in answering some questions around his setup yesterday. And while he didn't take before measurements it certainly looks like he's getting more that 3" on his setup while running 20" wheels.
  11. May 19, 2019 at 2:49 PM
    #101
    jabula_za
    Shaun
    Sabre Springs, CA
    After installing my 58650’s yesterday I’m getting 2inches out of them at max preload (2 inches thread showing).
    Not stoked, I’m going to contact Icon on Monday to see how we can get this resolved.
    As stated before I have absolutely no weight up front.
  12. May 19, 2019 at 3:01 PM
    #102
    LT75
    Saint Charles, IL
    No mods yet
    Ask if they are aware of the Eibach spring issue. This is obviously effecting their coilovers as well.
  13. May 19, 2019 at 3:31 PM
    #103
    Amnesiac
    PDX
    That sucks, keep us updated with what they say.
  14. May 19, 2019 at 6:27 PM
    #104
    jabula_za
    Shaun
    Sabre Springs, CA
    Will do.
  15. May 19, 2019 at 6:29 PM
    #105
    jabula_za
    Shaun
    Sabre Springs, CA
    Yeah it does suck, getting some tire rub now at full lock with the 35,s I had on.
    Ordering the RXT soon so hopefully Icon will send me the 700lb coils and I will swap them out when I do the rear install.
  16. May 22, 2019 at 12:47 PM
    #106
    Keisuketak
    Keisuketak New Member
    Santa Cruz, ca
    2016 CM 4x4
    FYI
    I Installed the stage 4 yesterday I got 2.75” on the front with the 700 lb springs .
    I have a nfab bumper
  17. Jun 25, 2019 at 8:04 PM
    #107
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Is all this eibach spring issue fixed? I'm close to ordering icons, but reading several threads about this makes me wonder if I need to wait. I'd like to get 2 3/4 - 3 inches of lift. Are the 600 pound springs not up to the task? I spoke with icon today and they claim they are set at 2 inches and can be adjusted for 3 if I wanted. They said if I wanted a 700 pound spring, I'd have to buy eibach springs and have them installed.
  18. Jun 25, 2019 at 9:20 PM
    #108
    charliebison
    charliebison New Member
    From my recent experience, the 600lb springs were nowhere near getting me 3” and I had a stock truck. Ended up returning my icons, got Fox 2.5s, and never looked back.
  19. Jun 25, 2019 at 9:29 PM
    #109
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I’ve been debating this for a few weeks. They do not recommend using 700lb springs with the higher end stages. Because you loose adjustability
    Icon_Adrian likes this.
  20. Jun 25, 2019 at 9:30 PM
    #110
    TruckyTruck
    Gary
    Just when I think I have it all figured out
  21. Jun 26, 2019 at 3:34 AM
    #111
    LT75
    Saint Charles, IL
    No mods yet
    Icon doesn’t seem to want to remedy the spring issue. I luckily got them the give me the 700lb eibach springs but everyone else has been fighting with them. I would look elsewhere if they won’t give you the advertised height.
  22. Jun 26, 2019 at 5:06 AM
    #112
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Fox all the way.
  23. Jun 28, 2019 at 10:31 AM
    #113
    Icon_Adrian
    Icon_Adrian New Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    LT Front and Rear
    Eibach is a spring manufacturer for ICON but the springs are made to ICON's specs and are different than their standard production coils.
    There seems to be a lot of misinformation regarding springs. The principles that apply for Tacoma/4Runner/FJ coilovers do not cross over directly to the Tundra platform. A 700lb spring will not give you more lift than our production coil spring unless you adjust it past the max recommended thread showing, this can also be done with the production coil provided. Hence the reason there is no production ICON 07+ Tundra coilover with a different coil spring. The coil was designed to provide the best performance possible for the vehicle.
    It's becoming more apparent to the general public that there are differences in the vehicle from the factory. The differences are being accounted for and the changes (if any) that may need to be done will be thoroughly tested and researched before a product update happens. To go beyond the max thread recommendation you can use a bump stop spacer to prevent coil bind.
    51045 - TOYOTA .25” BUMP STOP SPACER KIT
    51046 - 07-UP TUNDRA/200 SERIES BUMP STOP SPACER KIT
  24. Jun 28, 2019 at 10:50 AM
    #114
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    I spoke with @sdhq_offroad about this issue and opted to go with a 700lb spring, and bump stop spacer kit. I'm not looking to go past 3 inches simply looking to maintain the lift I did accumulate along with the added weight of a winch and a plate bumper. Is this what the 700lb spring will do for me? Also, what is recommended preload for the 700lb spring? How many threads?
  25. Jun 28, 2019 at 10:54 AM
    #115
    LT75
    Saint Charles, IL
    No mods yet
    700lb spring should have 1” of thread showing. 600lb has a 2” limit. But as stated above, they are allowing customers to go past those limits now.
  26. Jul 10, 2019 at 8:05 PM
    #116
    Jaf3
    Jaf3 New Member
    Are there any updates on this from Icon? I purchased the 58750 and they sit about 1.75 inches of lift on my 2013 CM 5.7 at factory settings.
  27. Jul 10, 2019 at 8:25 PM
    #117
    TruckyTruck
    Gary
    I had planned for over 3 years to go with icon, but after all the threads on the spring trouble, I ended up going with Elka. Unlike the most rear suspension with reservoirs and adjusters, Elka's rear suspension works with up to a 2 inch rear lift. The company has finally settled on a 700 pound spring for the front coilovers, giving 2-3 inches of lift. I believe they offer a lower spring rate if you want less than 2 inches of front lift. The springs are not eibach, they are Elka's manufactured spring. Here is a very good thread on them if anyone is interested. However, the thread is from a first production run. Since, they have made some changes to dial in what tundra owners were asking for. I just found them unique to what's currently out there and a perfect fit for me.
    https://www.tundras.com/threads/everything-elka-and-how-they-compare.39659/
  28. Jul 11, 2019 at 3:47 AM
    #118
    LT75
    Saint Charles, IL
    No mods yet
    No they are not rectifying the situation with their springs. Just saying that results will vary and to crank them past the 2” point with use of bump stop extensions.
  29. Dec 20, 2019 at 2:36 PM
    #119
    slosquirrel
    slosquirrel New Member
    Did this ever get solved? I was about to order some Icon's, but am nervous about pulling the trigger now. I'd like ~2.5" out of the front, but don't want to max out my preload to get it.
  30. Dec 20, 2019 at 2:41 PM
    #120
    LT75
    Saint Charles, IL
    No mods yet
    Hopefully it did. They were in denial about the issue. At least toytec admitted the issue.
