GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Sep 7, 2022 at 9:12 AM
    #1321
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    do you have any photos of 35s on your factory platinum tires?
  2. Sep 7, 2022 at 10:15 AM
    #1322
    22platitundy
    Love this set up and the truck overall! How does the ride quality compare to stock?
  3. Sep 7, 2022 at 1:05 PM
    #1323
    RealTruck
    RealTruck New Member Vendor
    Axe Offroad Chaos wheels in a 17x9 with Mickey Thompson mud terrains 35x12.50. These were tricky to balance since the caliper is so close to the wheel.
    Mountun Goat likes this.
  4. Sep 7, 2022 at 2:44 PM
    #1324
    4wd TRD PRO
    4wd TRD PRO New Member
    Its crazy what just some tires can do for the looks of a truck. looks great man!
  5. Sep 7, 2022 at 3:56 PM
    #1325
    4wd TRD PRO
    how's the sway on those tires on the highway?
  6. Sep 7, 2022 at 4:04 PM
    #1326
    Dakota5556
    Dakota5556 New Member
    Sunny
    2022 Wind Chill Pearl Tundra Platinum
    GFC Camper, Baja Design Ditch Lights, Switch Pro, SDHQ Ditch Brackets
    BFG ko2 285/65/18
    Method bronze 305. I don’t like that water gets stuck in the lip of the rim
    Sisu87TRDOR and Yaboy like this.
  7. Sep 7, 2022 at 8:27 PM
    #1327
    9OH1
    9OH1 New Member
    Memphis, TN
    White Crewmax Limited LB w/ TRD Off-Road package
    I haven’t particularly noticed any sway on the highway, it feels just as planted as stock in my opinion and I’ve had it around 90mph indicated on the speedometer at 36psi for a smoother ride.
    4wd TRD PRO[QUOTED] likes this.
  8. Sep 8, 2022 at 1:49 PM
    #1328
    Toyota1990
    Toyota1990 New Member
    Anyone by chance have a set of factory chrome lug nuts for factory aluminum wheels?
  9. Sep 8, 2022 at 1:54 PM
    #1329
    cholloway
    cholloway New Member
    Corey
    New here and have enjoyed seeing everyone's setup. Figured I would throw mine up.
    Tom976, Yaboy and 9OH1 like this.
  10. Sep 8, 2022 at 10:05 PM
    #1330
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Welcome…now that you showed us you got to tell us a little bit about your components
    -Lift height/type…looks higher than the typical 3/1 we have been used to
    -tire size and wheel combo
    -anything else
  11. Sep 9, 2022 at 7:39 AM
    #1331
    cholloway
    Corey
    I can't remember the metric size on the tire but it is basically a 34.8 inch x 11 tire. The wheel is an 18x10 -24 and the lift is a 3.5 inch rough country. That is all that's done to the truck other then tint of course.
  12. Sep 9, 2022 at 9:46 AM
    #1332
    Ssteinkritz
    Ssteinkritz New Member
    Scott
    22 windchill white
    I've got a WCP Platinum with retractable running boards. I've got the Wescott 3/1 ready to be installed, will go with BFG KO2's probably and am trying to figure out which offset to go with. I'm worried that any poke is going to result in the sides of the truck getting peppered with rocks and road crap. I've heard the WCP is a beatch to repaint if needed. Anybody have experience or thoughts? Sounds like +35 has little to no poke but I like the look of 18 and 20 also.
  13. Sep 9, 2022 at 12:40 PM
    #1333
    cholloway
    Corey
    WCP is extremely difficult to match if you need to repaint. I would agree with that statement. You could clear bra the rockers and then you should really need to worry about it that much. I know with my -24 setup I had to remove the front mud flaps. Makes me a little nervous but I was going for a certain look. My truck is a lease truck and so I am not as concerned. In three years I will build another and will probably be a little more conservative with my fitmant.
  14. Sep 9, 2022 at 5:56 PM
    #1334
    bigjuice
    WA State
    2024 Terra TRD Pro
    Looks very nice.
    Sounds like you might be a 285/75/
    18…the skinny 35’s as they call it
    DesertGorilla likes this.
  15. Sep 9, 2022 at 6:02 PM
    #1335
    bigjuice
    WA State
    2024 Terra TRD Pro
    I have +12 on this truck and +18 on my last truck (2015 Tundra)…I drive (slowly) on gravel once per week and normal driving the rest of the time.
    My off-road is about once every 2 weeks currently and once per week on the last truck as travel to my Mt. Bike spots…I can’t say that I have experienced any issues that caused me to think that my limited poke caused those issues.
    You may use your truck differently that warrants your concern but I would say to pick your +18 or +20 in your rim of choice and you should be ok/happy
  16. Sep 9, 2022 at 6:08 PM
    #1336
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    OVERLAND.OFFGRID has a nice set up with some DIY Husky Liners. Not a bad idea to tame down the rock slings. Opens up your options to the more aggressive offsets.
    porterbc likes this.
  17. Sep 10, 2022 at 8:22 AM
    #1337
    AND
    AND New Member
    Washington, PNW
    Does anybody have 35x12.5r18 on these wheels, or does anybody know if they will fit without rubbing?
    I believe I read somewhere that they'll rub on the UCAs, can anybody confirm that?
  18. Sep 10, 2022 at 8:37 AM
    #1338
    Odithtfg747
    Odithtfg747 New Member
    2022 SR5
    I’m currently divided on just replacing stock 265/70/18 on my sr5 or increasing size to 275/70/18 but don’t want to mess with replacing the spare or going with load E and the mpg hit that will come from those extra 10lbs per tire.
    Does anyone know of a non-load E 275/70/18?
  19. Sep 10, 2022 at 9:00 AM
    #1339
    AND
    AND New Member
    Washington, PNW
  20. Sep 10, 2022 at 10:35 AM
    #1340
    Odithtfg747
    2022 SR5
  21. Sep 10, 2022 at 10:39 AM
    #1341
    cholloway
    Corey
    I did run my 35's on those wheels before purchasing my current wheels. I run (like was stated above the skinny 35) so not 12.5. They rub pretty bad on the stock wheel. They hit the sway bar and shorten you're turning radius
    AND[QUOTED] likes this.
  22. Sep 10, 2022 at 10:40 AM
    #1342
    cholloway
    Corey
    Yes I believe that is correct. I was going to look to confirm but forgot.
    AND likes this.
  23. Sep 10, 2022 at 2:12 PM
    #1343
    bigjuice
    WA State
    2024 Terra TRD Pro
    You can run 295/70/18 with no problems though…vary from about 34.4-34.6 depending on brand and around 11.8 or so.
    I did those on bone stock wheels/suspension and you have full turning radius and no rubbing
  24. Sep 10, 2022 at 3:04 PM
    #1344
    AND
    AND New Member
    Washington, PNW
  25. Sep 11, 2022 at 8:19 PM
    #1345
    Tundra17944Ever
    Tundra17944Ever ‘16 Limited to ‘23 1794
    Tom
    GA
    2023 Tundra CrewMax 1794 TRD 4x4
    Fuel Rebel 6 Bronze 20x9 +20 Nitto Recon Grappler LT295/60R20 PRO fender flares color matched and wired Fox suspension from TRD Pro TRD Pro shift knob Grille surround color matched CBI Covert bumper with bull bar Rear bumper arms color matched BakFlip MX4 tonneau cover WeatherTech mats Gloss black window trim TT cat shield Black TRD grille Tufskinz tailgate letters Tufskinz TRD logo and stripes Tufskinz door sill protector Center console safe TWC 5” exhaust tip TWC slip-on exhaust TWC titanium valve stem caps Beat Sonic amp TRD air filters Diode Dynamics amber fog lights Color matched digital camo fog light bezel OEM Dashcam
    Check out post #13 of this thread. I don't think you will have an issue. I'm waiting on set of Fuels +20 offset as well.
  26. Sep 12, 2022 at 6:56 AM
    #1346
    porterbc
    porterbc New Member
    Brandon
    2022 Tundra Crewmax Limited TRD OFF-ROAD
    This is the cat ass! Maybe it will stop the sand blasting on my bed sides this winter from all the sand and salt on the roads
  27. Sep 14, 2022 at 1:01 PM
    #1347
    crowdedstr
    crowdedstr New Member
    Northern WI
    Ok my turn... sorry for the dirty truck! I put General Grabber ATX 285/60/20's on my SR5 TRD Sport w stock rims, no lift or level.
    Really happy with the results... looks great and the ride height and feel while driving is much better than before, feels a lot more like a truck! Used a GPS speedometer on my phone on the way home and there was literally no variance from what the vehicle displayed whether I was highway or town, but lost about 2.5mpg on the trip computer.
    Thanks to all who share their knowledge around here, very good and helpful forum. There aren't a lot of 285/60/20 photos on this thread, so hopefully this helps someone along the way.
    MRJD, user4892, Crews44 and 12 others like this.
  28. Sep 15, 2022 at 10:45 AM
    #1348
    TheSS712
    TheSS712 New Member
    Shayne
    2022 Army Green Tundra Limited
    @crowdedstr - Looks good! I may have to just get some new tires like that for my truck to look better. lol No rubbing anywhere? I have the 4x4 Limited and it needs to look a little beefier. I wanted to get the factory TRD lift kit but, I have the rear leveling air. I am sure all the front components would be fine. It's those damn air springs/ bags...
  29. Sep 15, 2022 at 10:55 AM
    #1349
    crowdedstr
    Northern WI
    Thanks it definitely makes for a better looking truck! No rubbing anywhere... these are 33.5", many people on this thread running 34-35" without rubbing or lifts as well.
    TheSS712[QUOTED] likes this.
  30. Sep 15, 2022 at 2:35 PM
    #1350
    Toyota1990
    35 inch nitto ridge grapplers on stock 1794 wheels. Readylift 3 inch lift with control arms and icon rear shocks. Still averaging about 16mpg. If I drive 50-55 easy I can hit 18mpg. Not bad for 35s. None believes its an SR base model.
    dugout68, Boerseun, Henry1jg and 3 others like this.
