GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Dec 24, 2023 at 3:30 PM
    #4141
    CYBERO24
    CYBERO24 New Member
    East Coast
    2023 Tundra Platnium
    SS3 Pods, SS6 Fogs, Talon Skid & Cat, Rays ALAP 07X w/ 285/70 Toyo OC AT3, TRD Pro fenders, beat sonic amp, Peragon Tonneau,
  2. Dec 24, 2023 at 3:34 PM
    #4142
    ReCKzX
    ReCKzX New Member
    2023 Tundra TRD Pro Ice Cap
    I think saw his TRD Pro and he has -10 offset. The only concern I have is that these may have a different bore size than the -10 offset ones.
  3. Dec 24, 2023 at 3:35 PM
    #4143
    CYBERO24
    CYBERO24 New Member
    East Coast
    https://www.tundras.com/threads/gen-3-2022-wheels-and-tires-photo-thread.101215/page-91#post
    edit: sorry yeah they’re -10 but as long as the bore isn’t smaller than the ones on the truck it should be fine since you can get hub rings, but I believe Toyota wheels are lug centric (correct me if I wrong!)
    looking on Rays website it looks like these wheels are bored to 112 for 17” in our lug pattern and the Tundra has a bore of 95 so you’d need to get hub rings: https://www.tundras.com/threads/hub-centric-rings-for-2022-tundra.114211/
    ReCKzX[QUOTED] likes this.
  4. Dec 24, 2023 at 4:08 PM
    #4144
    ReCKzX
    ReCKzX New Member
    Thank you very much!
  5. Dec 24, 2023 at 8:42 PM
    #4145
    Crunchy_PB
    Crunchy_PB New Member
    Paul
    Bend, Oregon
    2024 Limited TRD Off-Road
    TRD OEM 3” lift kit; Method 317 18” wheels; BFG A/T 35x12.5x18’s
    Took the front mud flaps off but the bracket is still attached.
  6. Dec 25, 2023 at 3:14 AM
    #4146
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Wow. That post seems like a decade ago. Not much to add from my original post. They were running a 2” leveling kit up front from the 2.5 Gen (this was all that was available early on), Fuel Vectors with a +18(ish) off meet if I recall. The tires were 295/70/18s, I believe.
    That build seems so tame compared to where I’m at today with my truck. lol
  7. Dec 25, 2023 at 2:35 PM
    #4147
    musiqmaker225
    musiqmaker225 8th tundra and lots of mods to come
    Fort Worth, TX
    2024 4wd Tundra SR5 with TRD Lift
    3 inch TRD Lift
    Freaking love your truck. I have a silver 1794 as well, but RWD. I can't imagine being able to fit those on my low ass truck haha. I am convinced the 4wd TRD sit higher I am sure.
  8. Dec 25, 2023 at 6:28 PM
    #4148
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    ICON Recon 17X8.5 +25mm offset wrapped in 37X12.50R17 Predator New Mutant X-RT.
  9. Dec 25, 2023 at 8:12 PM
    #4149
    Tho4x4
    Tho4x4 New Member
    2024 Tundra Limited Hybrid OR
    Great looking truck! Can I ask which front and rear bumpers those are?
    romanlegion[QUOTED] likes this.
  10. Dec 25, 2023 at 8:57 PM
    #4150
    tundznoff
    tundznoff New Member
    blk limited tundra
    TRD red axel swap Satin black wrapped fender flares Satin black wrapped bumper insert Icon stage 5 Icon 1.25 rear spring Drkdss panhard bracket Rave trd pro grill & lights 37” K02 17” 0 offset Nomad Sahara
    BFG KO2 37x12.5 on 17” Nomad Saharas 0 offset
    Thiccc
  11. Dec 25, 2023 at 9:20 PM
    #4151
    romanlegion
    Roman
    Katy, TX
    Thanks. They are Lil B's Hybrid Front and Rear Bumpers. I'm not sure if the rear bumpers are available already. You might have to call them.
  12. Dec 26, 2023 at 7:53 AM
    #4152
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    how much of a lift and which lift kit did you go with?
  13. Dec 26, 2023 at 8:01 AM
    #4153
    boomtime
    boomtime New Member
    I love the softopper. Had it on the tacoma and immediately got it for the tundra. I think FasTop has a new design that hides under a tonneau when folded down. I had no idea that existed and I think I would have given it a look but I know the softopper design is sound.
    On another note I might go back to the bigger tires you quoted in your response. I think the 275/70 r18 has a slightly harsher ride so ill go back to 285/75r18... to remedy the sway bar rubbing with the 285s I'm going to look into removing the sway bar drops or looking into the trd pro sway bar as I've heard it has a different bend to it but I'm not certain.
    Siopao likes this.
  14. Dec 26, 2023 at 1:31 PM
    #4154
    romanlegion
    Roman
    Katy, TX
    I have the ICON Stage 6 Billet UCA + 1" Cornfed front spacer lift. So, I have roughly about 4" of lift.
    Netmonkey[QUOTED] likes this.
  15. Dec 26, 2023 at 6:08 PM
    #4155
    Welshflynavy
    Welshflynavy Flyin Jets!
    Austin
    Pensacola
    24 MGM Limited TRD OR
    Just ordered 295/65/20 and 285/65/20 Toyo OC AT3s. Will keep whichever fits best
    4lo Toys and romanlegion like this.
  16. Dec 26, 2023 at 6:21 PM
    #4156
    romanlegion
    Roman
    Katy, TX
    What wheel size and offset will you be using?
  17. Dec 26, 2023 at 6:25 PM
    #4157
    Welshflynavy
    Austin
    Pensacola
    The stock limited TRD 20s
  18. Dec 26, 2023 at 6:30 PM
    #4158
    romanlegion
    Roman
    Katy, TX
    So, basically 20X8 +60 offset. Assuming you're Tundra is at least lifted 2.5", I think either size will not cause any rubbing problems. The 295 will probably look better in my opinion.
  19. Dec 26, 2023 at 6:33 PM
    #4159
    Welshflynavy
    Austin
    Pensacola
    Nope totally stock. There’s plenty of posts I’ve seen in this huge thread of dudes running both sizes with no issues. Once I get them installed in a week or so I’ll throw pictures up.
    the stock mildpeaks that came on the truck will not be great for driving through the cascades and Rockies this winter
  20. Dec 26, 2023 at 7:48 PM
    #4160
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    I am running 285/75/18 on stock 18" rims without any lift with no rubbing at all.
    Troyboy84 likes this.
  21. Dec 26, 2023 at 8:33 PM
    #4161
    Welshflynavy
    Austin
    Pensacola
    That’s good to hear!! I’m hoping the 295/65 fit but if not I’m getting the 285s
    romanlegion likes this.
  22. Dec 27, 2023 at 5:45 AM
    #4162
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    They should fit fine without any rubbing. I have also seen many reports of people here running 295/70’s with no rubbing at all on stock wheels. I have 295/70/18 BFG KO2's going on Friday on the stock SR5 TRD OR wheels.
  23. Dec 27, 2023 at 5:58 AM
    #4163
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    That’s what I have and they fit no problem. I have a 1” cornfed front lift but drove it without for awhile, no issues.
  24. Dec 27, 2023 at 6:04 AM
    #4164
    Welshflynavy
    Austin
    Pensacola
    Yeah I just hope there’s no issues with the TRD 20” wheels vs all the people running the 18s.
  25. Dec 27, 2023 at 6:10 AM
    #4165
    Netmonkey
    Georgetown, TX
    how are the cv angles?
  26. Dec 27, 2023 at 6:32 AM
    #4166
    Northern Toyota
    Tires and bilstein
    295/65/20 will be tight. I know my 295/70r18’s are fairly tight to the rear plastic wheel well liners.
  27. Dec 27, 2023 at 7:17 AM
    #4167
    Welshflynavy
    Austin
    Pensacola
    Might be tight but hopefully they work. Otherwise the 285s will still look great
  28. Dec 27, 2023 at 8:41 AM
    #4168
    romanlegion
    Roman
    Katy, TX
    I think they are fine. I already have around 23K miles on the suspension and everything works great. I think ICON's billet UCA design does a lot to compensate to correct the CV angle when lifting the suspension. I probably would not go any taller than 4" without using a crossmember on the subframe.
  29. Dec 27, 2023 at 8:50 AM
    #4169
    romanlegion
    Roman
    Katy, TX
    I think you did the right move by putting a 1" spacer up front. You may not need it when just driving around town, but having that extra clearance when on the trails gives you more confidence that you won't scrape. Plus, leveling the truck makes the stance look a lot better compared to when the ass end is up.
  30. Dec 27, 2023 at 9:01 AM
    #4170
    Welshflynavy
    Austin
    Pensacola
    Was the level spacer pretty easy to install ?
