Gen 2 is snappier than my Gen 2.5, why?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by JohnWhicker, May 24, 2024.
  1. May 24, 2024 at 8:19 AM
    JohnWhicker
    JohnWhicker [OP] New Member
    So I have a 2013 with 125K miles on it and a 2021 with 5000 miles. My son is now driving the 2013 after my 2021 purchase in Nov last year. I just took the 2013 in for maintenance and as I am driving I just realized that the 2013 feels snappier, quicker on the gas pedal when I accelerate. Is it just me or the gen 2 is programed differently? I really can notice the difference
  2. May 24, 2024 at 8:30 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Throttle map is a lot different. Later years sometimes have really weird sensitivity that is gear specific, instead of the earlier trucks where it's one throttle curve for every gear too.
  3. May 24, 2024 at 8:34 AM
    QuicksandPNW
    QuicksandPNW New Member
    Kevin
    Washington State
    2020 Quicksand Tundra SR5
    Bed Rail System Tonneau Cover
    I notice the same thing when I drive my dad’s 2012. However Tow/Haul is more jumpy with my 2020. My assumption is that Toyota may have changed some gearing in the transmission in the 2.5’s
    AZBoatHauler and 1lowlife like this.
  4. May 24, 2024 at 8:43 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    They changed the throttle response due to folks complaining about the pedal being too jumpy
  5. May 24, 2024 at 8:44 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    2.5 gens throttle mapping is kina lazy. Tow/Haul button or any of the pedal commander boxes will bring back the snappy feel. Or just press more on the go pedal.
    BoxersBrew and AZBoatHauler like this.
  6. May 24, 2024 at 8:59 AM
    brodesiansneverdie
    brodesiansneverdie New Member
    2020 White Tundra SR5 CM
    Toytec Aluma 2.5/2.0 SPC UCAs U748s Method 705s Toyo AT3 285/75r17 RCI Aluminum skid OTT tune Softopper Decked V2 Diode Dynamics
    Definitely the throttle mapping. That's why the Pedal Commanders/OTT tunes etc. are becoming so popular when there's little to no actual power gains to be had on a stock truck.
    BoxersBrew likes this.
  7. May 24, 2024 at 9:18 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    There was a sudden unintended acceleration fiasco years ago resulting in a lawsuit and couple recall fixes and I think the throttle was de mapped at some point on Gen2s built After this.
  8. May 24, 2024 at 9:25 AM
    JohnWhicker
    OK, so I wasn't crazy then. I remember some tuning threads related to 2.5. Any safe / reliable tunes I can push to my gen 2.5? And I hope it won't void my extended warranty?
  9. May 24, 2024 at 11:56 AM
    brodesiansneverdie
    I can't speak to warranty safety, but I've got approximately 20k on an OTT Tune and am very happy with it on 34s.
  10. May 24, 2024 at 12:07 PM
    JohnWhicker
    How does this works? I have to put the truck in "Tow/Haul" mode? Never heard of it, never done it. Would it break or impact anything?
  11. May 24, 2024 at 12:09 PM
    brodesiansneverdie
    I believe only trucks with the tow package came with this. It's a button to the right of the steering wheel that changes transmission and throttle mapping with the push of a button.
  12. May 24, 2024 at 12:29 PM
    Tundra1D6
    Throttle mapping? My 2008 has the stock gas pedal, I removed the shim from up top for free to help it not be so sensitive.
    People buy different pedals all the time for this but you can add or remove the shim.
  13. May 24, 2024 at 12:31 PM
    brodesiansneverdie
    I can't tell if you're messing with me or not, but the 2nd gen Tundra has electronic throttle control; there's no mechanical connection between the throttle body and the gas pedal. The sensitivity of the throttle is controlled by the computer.
  14. May 24, 2024 at 12:46 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
  15. May 24, 2024 at 1:01 PM
    JohnWhicker
  16. May 24, 2024 at 1:08 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Tow/haul on the 2.5 gen makes the throttle mapping feel more like the 2nd gen. On my 2010 the pedal sensitivity was indistinguishable between normal and tow/haul. On my 2017 it’s a huge difference between the two. And no, tow/haul won’t hurt a thing.
  17. May 24, 2024 at 1:10 PM
    Tundra1D6
    https://www.tundras.com/threads/touchy-gas-pedal.29361/
  18. May 24, 2024 at 1:30 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
  19. May 24, 2024 at 8:55 PM
    Tripleconpanna
    Same; just the buttons are in different locations....
    My '08 and '21 will both toggle through the options; dash lights look a little different though. As already stated, my '08 doesn't feel much different in throttle response, but the '21 definitely 'wakes up'. No more HP or TQ just a more responsive pedal :thumbsup:
